The sf14 is l>m>h no memory, no blinkies, pwm if any is not perceptible, imo the best of the list by far, the clip not being reversible is the only drawback I find
The sf12 is a thorfire tg06s clone, forward clicky, reversible clip, I particularly don’t like the build quality. H>l>m, don’t know if no memory or next mode memory, no blinkies, bad pwm, has trouble with protected 14500s width.
The sf10 is a “mini convoy s6”, no clip, h>m>l>ml, hidden strobe, no memory, also bad pwm, build quality better than the 12, not as good as the 14
The LMH and no-blinkies kinda sold me. Think it squeezes more lemons than the other, no? 500 or so.
This I remember seeing in someone’s review. Kinda struck that off my list.
Funny, ’cause that’s also why I didn’t grab any TG06Ses, because of the start-on-high and nomem. That would drive me batty.
Okay, so I guess I can strike this off my list, too. I hate H→L, even worse with nomem so that it always starts on high.
Thinking of giving away my Tool for starting on medium instead of low. Ugh. Beautiful light otherwise. Lotta OnTheRoad lights do that, too, if I recall.
Hmm, I don’t remember lumens, but the sf14 is definitely brighter than the tool AA using eneloops. Tomorrow I can compare all of them with each other with AA and 14500s
The sp10a/b are side e-switches, the sf models are clickies, but as far as I remember it’s close to the sf14, but I gave away my sp10a, so I can’t re-check. Build quality is good, but I find the switch a bit flimsy, good for the price thou
Actually, as someone who had an original ’10A and still a few ’10Bs, I think the 10s in general are the best of the bunch.
I like the doubleclick-to-turbo even from off (or on), and with true firefly mode (’though I’d want the 3 modes + turbo to be more evenly-spaced), and pretty-well-hidden strobe, plus lockout (’though for me a TCLO is more convenient and what I usually do anyway).
Still, for a pocket-light, it does everything from firefly to decent-brightness turbo even on an eneloop, so what more could you want?
SF10 and SF12 are about as bright as the Lumintop Tool AA, maybe a bit brighter, but the lumintop is floodier, so it’s hard to tell
The SF 14 is noticeably brighter than the previous 3, but for some reason mine starts blinking sometimes a few seconds after I set it on high with an AA, doesn’t happen with a 14500, weird, driver might be having some problem
The SF14 high is between the utorch UT01 high and turbo,
I have one, its very bright for it’s class, my only gripe is the tail switch is too sensitive, you can easily turn it off when tryting to switch modes.
i am thinking of ordering sp10b but if its brightness with eneloop is the same as sf10 maybe i give up…i am not a fan of side switch as well and many are saying they’re flimsy on sofirn…sf10 is even more waterproof being ipx8…and it’s half the cost of sp10b…on paper, i can’t say what’s the upgrade from sf10 to sp10b…?
The upgrade of SF10 is SF14: reverse switch on tail, 3 modes, no memory (always start on low), no strobes or SOS, XP-G2 Neutral white, provides a “long” distance illumination range (at least on 14500 batteries, near 60 mts), no visible PWM.
The SF10 is a nice host, but the driver and UI is not the best I’ve seen (according to my preferences, of course). If you can mod it, go for it, it worths a try, as host!
BTW, I’ll be grabbing a SP10A to replace my damaged “old” SP10B AliExpress anniversary is something that can’t be missed :partying_face:
to make things more complicated i have seen around something like sf10A? how about that i get mine couple of days ago so i think i have sf10A…i’ve seen some youtube clips where sf10 doesn’t have pocket clip, does have 4 modes instead of 5, and declared as 100 lumens on nimh…mine manual says 180 lumens with nimh…so, go figure…
btw, i don’t know what the package says but mine sf10 is neutral white as far as i can tell…
SF10’s, despite the drawbacks (for us flashaholics) stated above, make a nice gift to non-flashlight people. Super simple to use, always start on high (at least the ones I got)
