Jaxman has good tints but tend to use XPGās instead of XPLās, and they donāt like to drive their small lights too hard. So they end up wanting power modded. I think the E3 would be a much better overall light if it had itās current output levels, plus an added high/turbo level of 500-700lm
I have PKCell 14500 (which are flat-tops), and they work intermittently on my couple of UT01 (more often than not, the flat-top 14500 does not work, or if it worked, slight shaking the flashlight will turn it off and not work).
so many threads in so few daysā¦I cant read and reply smoothly, it will need too much time to read every threads carefullyā¦ā¦
the middle modes is powered by PWM which works at 500 Hz, and it will not be seen by your eyes. but maybe seen by a camera, and I think the middle mode will be seldom used in most time, so I choose PWM for a convenience. The low and high is not PWM.
hi, the design of anti-reversing of battery forbids full flat batteries to work.
So flat 14500 batteries can not be use in this flashlight. You can use 14500 with a little higher cap like AA batteries, and I have this kind of 14500.
if dears cant get the battery,I can give you as a giftāāneed you leave a word in your orderā-only few pcs this battery.
while,if you use 14500,the E3 will lost low and middle modes, it will be only one modeāhigh mode.
I am worry about if you can know what I am sayingā¦
I want learn a good English ability from all of you.
I found it is hard to get the truth ability of foreign languages if you are not live in the place of that language.
Ok, since all of us are the man who love DIY, I fully understand what dear all are thinking.
Host is not a problem. but need some time, now we are too busy to making business. Later, we will make a link for the host.
Thanks! Iāll likely order one and leave a message to request for button-top 14500ā¦ Hope shipping flashlight+battery to my country wonāt be a problem (unlike shipping of pure batteries)ā¦
It looks like the E3 is not as lean as the Tool AA but still ok, and it is pretty short.
With the Tool AA, and with my 4sevens mini AA I have the feeling that if I drop it they could deform and the threading gets stuck, the E3 can be overrun by a truck.
