*** NEW *** Haikelite MT09R Monster lights *** Update *** 2018-07-03
214 posts / 0 new
hIKARInoob
hIKARInoob's picture
Last seen: 3 hours 25 min ago
This is not a step down from turbo related phenomenon. It’s about what the battery indicator does as a function of cell voltage, and on what level of output you are. The battery indicator should be blinking blue below a certain voltage, but remains solid when in turbo. It’s supposed to be blinking too.
sherman2k
I know my order was shipped 2 weeks ago. I have the tracking number. How do I track it? Where do I go?
Newlumen
Newlumen's picture
Last seen: 27 min 19 sec ago
I guess you open the google, paste the tracking number, then search..
hIKARInoob
You can use this one for example.
https://www.17track.net/en
sherman2k
Thank you. I didn’t know it’s coming from the Netherlands.
sherman2k
Is Charger going to ship out soon?
hIKARInoob
I hope so, but I do not know. Perhaps Terry knows more.
NOT Haikelite U...
Last seen: 7 months 2 weeks ago
hIKARInoob wrote:
This is not a step down from turbo related phenomenon. It's about what the battery indicator does as a function of cell voltage, and on what level of output you are. The battery indicator should be blinking blue below a certain voltage, but remains solid when in turbo. It's supposed to be blinking too.
If you are in Turbo at cell levels low enough to already be giving a warning, then chances are you are also kicking it back into turbo past the 55 degree C stop down. (Not saying you are just that there is a good chance of it with most) It will allow you to bypass that feature including any power requirements needed. That I am aware of it will not flash at all in turbo. If the cells are already low enough begin flashing, then you are below any level that should be attempting to hit 15 to 16 thousand lumens.
So when I said it will allow you to keep kicking it into turbo until you either can’t stand the heat or you kill your cells I meant that literally. It was designed to use turbo ay anytime… And if you are getting a blue flash you are between 50 and 9 percent. Why try to go to turbo once that warns you that you could possibly be as low as 9 percent already.. This would mean it is time to stop and charge or change the cells.
The instructions even tell you that it will not ready correctly in turbo.
https://i.imgur.com/JJjIU8L.jpg
He Said She Said Sales
Skype Terrywhite1@live.com
NOT Haikelite U...
Nothing will ship out until after the Holiday.. I will ask for a more detailed answer later when I talk to Dale..
hIKARInoob
I see. I thought it meant voltage readout is not accurate due to voltage sag on turbo (high current). Alright then.
Boro
Last seen: 1 day 2 hours ago
Does the term “ alarmist “ mean anything to you ?
NOT Haikelite U...
It's not that bad lol.. It is really simple it just means that when in turbo mode do not depend on the voltage flashes because the light will stay a solid blue while in turbo...
Pushing far enough to go all the way until it actually turns red and steps down to a moonlight mode should only be in a serious situation and you have no other choice. It should not totally kill your cells, if it reaches that point no other mode can be used because the cells are too low.
FindThisHumerus
FindThisHumerus's picture
Hey guys, I’m very late to this thanks to my work schedule. Any chance I can still get one of the Navy Blue XHP70.2 versions?
Bored med student
Winston Wulf
Winston Wulf's picture
Last seen: 3 months 14 hours ago
Ask Terry – the post directly above you. He makes the sales for the US. If he got one, he will sell it to you.
By the way, I have been asked to collect all our information about the two flashlights in another thread outside the GB – so let me sum up the actual situation:
- in the beginning of February the first lights have been sold by retail – the result for the 70 is as expected (a little below spex as usual in the flashlight business, but the babe is a real a$$-kicker), but the one for the 35 is bad – less than 50% of the formerly defined lumen.
In the fact, the first beamshots were really sad:
http://budgetlightforum.com/comment/1277432#comment-1277432
- a couple of days later we had the possibility to get the first one of the GB-35 in our hands – the results were better, but still no 7.500 lm:
http://budgetlightforum.com/comment/1283124#comment-1283124
In that time the official output of the 35 was decreased to 7.000 lm. The only problem: the measurement of the GB-version done in an ULLBRICHT sphere is around 4.000 lm…
Actually some of the problems can be pointed down to the batch number:
- the 35 with “21K” at the end is below 50% of the specified lumen. Those lights are actually sold by distributors for much less than the list price with an actualized lumen value.
- the 35 with “28K” is the one from the GB, measured at around 4.000 K
- other versions with “24K” seem to be in the market, but no measurements up to now.
While having the 70 on the secure sight regarding lumen – as I said, some 10-15% less is not too bad in the flashlight-business -, the problems keep on coming. Actually the issues mentioned are as follows:
- the 35 has an output far below spex regarding lumen
- no discharge battery protection – in a test it went down to 2,49 V with the light still at Moonlight, so take care with unprotected batteries
- no temperature control – a GB-delivery was measured with 100 °C while running shortly below Turbo
So: feel free to discuss all of these points in this thread and let us know what you think.
Always be yourself. Unless you can be BATMAN.
Then always be BATMAN.
mortuus
mortuus's picture
Last seen: 5 hours 39 min ago
Terry any idea when u are getting some MT09R 35 to test ?
...where Frugal meets with Flashlight!
hIKARInoob
Since the main business of the 35 version is throw, why not post some lux readings?
Man Without Shadow
Man Without Shadow's picture
Last seen: 27 min 48 sec ago
Are others discovering thermal step down doesn’t work?
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
Winston Wulf
Yes – many.
But it’s mostly posted in the GB-Thread, so it get’s lost in between many other posts. ..
hIKARInoob
So far most people who test it say it doesn’t do what it’s supposed to be doing; the light gets too hot.
ssschen
ssschen's picture
Last seen: 3 weeks 4 days ago
hIKARInoob wrote:
Winston Wulf wrote:
Guys, I want to echo the sentiments expressed by arficus on this post.
Personally, I feel the mods should have stepped in several times when people are being labelled in a negative way.
I followed the other GB thread very closely since its inception and even expressed interest in this light as I really would love to add a “super” high lumen flashlight to my collection. But in the end, I chose not to proceed as >US$100 is a lot of money (my most expensive flashlight is the US$40 BLF Q8!) for me to fork out for a flashlight that noone has any real exposure to. TBH, I am glad I bailed since I am just an amateur when it comes to flashlights, and although I do have an electronic background and has done some soldering in the past, I am not sure if I am up to the task of taking a flashlight apart to replace driver/other components etc.
Anyway, this is just a post to say that I appreciate the tough questions you ask, and the inputs you provide. At no point, do I feel any of your posts to be offensive or deliberately negative.
Cheers and Happy Easter from Down Under. Smile
hIKARInoob
You really need to have followed all the related threads to have a proper understanding of what is going on. Thanks a lot for your support! And a happy Easter to you too!
ssschen
ssschen's picture
Apart from this thread and the GB thread on the Haikelite MT09R, are you saying there are other threads? I am rather OCD in terms of reading posts, so I do and have been reading every single posts on both threads.
I am tossing up between getting this light or the older Astrolux MF01 as my next light.
hIKARInoob
HaikeLite MT09R Group buy Feeler(First Beam Shots)12-29-2017 http://budgetlightforum.com/node/57927
Haikelite MT09R Test/Review Beam video footage. http://budgetlightforum.com/node/58445
I’ve got the MF01 too, the 219C version. Both are truly amazing lights, but once the MT09R has a solid TA driver then the Haikelite is the clear winner.
ssschen
ssschen's picture
Thanks, that is what I thought too after seeing all the recent posts by TA. I wasn’t so sure before that. Smile
I have read the other two threads as well. I have just forgotten that they exist as there aren’t as much updates on those two threads. All the updates seems to be mainly on the GB thread.
Man Without Shadow
OMG! This light is now a work of art after the Texas Ace upgrade/mod! Was just out in a field blasting 4000k 80cri’s…awesome tint (everything is brown here right now…took it up against another 9000lumen CW light I have and this thing had way more throw and the tint a nice natural yellowish, while the CW was certainly stark white and blueish. Could definitely tell Texas Ace’s light with its tint was a better light up than the cool white. CW was kinda washed out, glarey…while the 70.2 4000k 80CRI was much much brighter, but didnt seem to throw any glare. Almost a magical tint compared to some CW’s and NW’s I have. It almost did appear 3x brighter…if one can even see that…it certainly had way more throw and filled up a much bigger area of the field and trees I was at.
Thanks again Texas Ace for this upgrade…it is quite amazing! Be nice if Haikelite was putting these out for less than the $250 it cost me (base plus upgrades). If they could guarantee they were making the light Texas Ace sent me…they would knock it out of the park and light up the forums. Its like an insane Q8 now!
Ramping is perfect speed, and its so reassuring to watch it obviously step down as it gets too hot.
A+++++
FindThisHumerus
Second this – I got mine from TA about two weeks ago. It’s insane. I got NW 70.2 emitters, the tint is great and his Narsil UI is amazing.
Bored med student
hIKARInoob
MT09R with new driver is rated at 21000 lumens.
Source: https://world.taobao.com/item/569477082699.htm?spm=a211ha.10565794.0.0.2...
Nicolicous
Nicolicous's picture
Last seen: 2 hours 44 min ago
I hope we get new driver from Hakelite
Nico -.-
hIKARInoob
I think so Mr. Kangaroo… In the meantime I’ll just enjoy the MT09R with the stock driver. Cool
Nicolicous
nooo
i want the latest and greatest driver Big SmileCrazy
Waited for several months for the new driver is my greatest patient Davie
Nico -.-
