pepinfaxera is currently tracking requests. They appeared suddenly from the ether when a need arose, and volunteered for a thankless tedious task. It’s kind of amazing.
… and I started writing a bot to try to do it, but I’ve been dragging my feet and it’s not ready yet.
Where is the new list? Is it the post linked above?
I don’t appear to be on it… that list is missing numbers between #360 and #760. I’m # 378 on the original list, 1pc.
i hope there will be a choice of emitters or ……….
after the first run is done, do another GB with a different emitter….
after that do xhp 50 and a reflector
While I don’t know what the emitter will be, I can at least say it won’t be XHP 50. The voltage on those is too high and the driver can’t convert it. That would make this a totally different light.
How many flaslights do you want in total? Total 8 flaslight The FW3A? … Total 12 flaslight The FW3A? … Total 16 flaslight The FW3A? …
Please, say: Total .x. torch; … Total .x. units; … Total .x. flashlight.
I understand why he might feel this way. The general design and UI are established, but the specifics are still elusive. Tapered or not? Bead-blasted or “right off the lathe?” Emitters? Options? Date?
