Group Buy: Wuben TO10R and TO46R (real 90+CRI triple XP-G3) - CLOSED!!
I’m interested in one of each light, depending on price.
Interested in the TO46R depending on price! One please.
Had some time today to tinker with the samples..
Emitter board is copper and DTP.
Dimensions 20mm dia x 1.8mm thickness.
TO10R can be "easily" modded to fit 18350:
..and the heads are interchangeable => Modded TO10R body + 18350 IMR + TO46R head = Nice pocket rocket. :)
TO10R can be “easily” modded to fit 18350
They should have done that in the factory already.
Not everyone has access to a lathe or knows how to use it…… :frowning:
Grtz
Nico
I agree WRT 18350. Especially since the other end of the body is already wide enough to accommodate an 18mm wide cell. With a 16340, there’s a lot of extra room.
+1 :frowning: I wish it was so easy to widen the space inside the tube :frowning:
To make a 18350 fit would be a nice thing from “stock :weary:
Anyway, thanks for the inspiration and the work done withe emitters!
I will still try to use the 46R head on the 10R body :smiling_imp:
I fully agree. In fact, I have been trying (hard) to convince them into doing that at least for the GB lights.
So far the answer has been a firm NO, but let’s see what they say after seeing my mod. :slight_smile:
interested in TO46R
This is the 10R body from the tail view? The tube does not separate from the head?
Can anyone confirm this mcpcb will fit my Jaxman E2L triple? I believe it’s using a Carclo lens.
(I’m okay with sanding the edges a bit if needed)
You know, I had the same Idea with my E2L’s but I think these have to be sanded to fit a E2L.
beam0 & sovereignknight
The triple noctigon also has 20mm and you need sanding. So here, too, it will be required.
I had a feeling since it’s 20mm it will fit with sanding, I was more concerned if the layout/spacing of the emitters will fit the Carclo lens. I have a feeling it will but want to make sure it’s not something else (if there is something else!)
This is the 10R body (with a 16340) looking in from the tail? So the tube I.D. is wider at the tail than it is closer the head?
10R body from the head. There’s no tailcap.
Same as in my pic. Tube I.D. is wider at the head.
Actually, there’s a “tailcap”, but it’s only for removing the magnet if needed.
One TO46R please!
Interested! PM sent.
Dirty_Pierre made the same mod some weeks ago and I found it amazing! Here: Modding the Wuben TO10R from 16340 to 18350 Video. !
I don’t have access to a lathe or whatever other device that would allow the 16340 > 18350 transformation so…even if my TO10R was sent me by Wuben for a review, if they come to offer a tube for 18350’s, I will probably buy it! (if not excessively expensive, of course) :money_mouth_face:
I know that they are probably concerned with warranty and even internal functioning of the light (and they don’t make/sell 18350´s as well), but for those who are willing to try that “battery change” and don’t have a way to mod the tube, it would be a nice thing to have a “new” tube by Wuben!
One question for you _ the _: did your TO46R had the head glued? I asked this to other members in the review threads, and apart from 1 or 2 members that received early samples, all others were glued and hard to open…
Even if we don’t get a 18350 tube for the TO10R, I wanted to try the TO46R head on the short tube, hence my question and concern about being glued or not, and on how hard it would be to “unglue” it !
Thanks again for all your efforts on this :wink:
Here’s two pics of the tail section of TO10R, as requested.
1. Tailcap removed. It was glued and required some force to open. Note the solid end of body tube!
2. Inside of the tube with tail spring in place
