I’m on the list and received PM with the price, so everything is OK for me! :+1:
I have a “request” though, about the “spare” emitters (if there will be any for sale). Earlier on the thread I mentioned I would want 1.
IF - but only IF - there are other spare emitters, I would like to add another 1 (total 2 + the TO46R I subscribed for).
This explains why the tint shift on the TO46R I measured was worse than on the TO10R and the output less than expected. The silicone dome was nowhere to be found…
The board, emitters and optics are identical so there should be no difference in the beam. Tint will always vary a bit but three emitters will probably even it out a bit. So I’d consider my TO10R tint measurements more representative of both lights.
Thanks for the explanation and tests maukka!
The thing I found most “annoying” with these LEDs was that even without the optics and lenses, there was a huge green “shift” (?) !
Hopefully that will be corrected with these new emitters
That’s what I’ve done too, and it improved the beam a lot.
It lost some meters in distance range (mostly outside) but specially indoor, it became much better!!
