Interested in the X45.
Could you send me a code for the Nitecore TINI
Thanks
Robert
Done.
[ quote=Batch1]Could you send me a code for the Nitecore TINI Thanks Robert [/quote]
just ordered the S2+, great deal and if you combine it with the led tail cap kit, the kit is only $0.88.
ken
Me too.
Interested ODF30.
Thank you.
Post #1000!
(at the moment)
how much for the Lumintop ODF30 XHP70.2 3500LM?
Sent.
\ [quote=BEARS ARE PEOPLE TOO]
[/quote]
Can I get an ODF30 price?
NITECORE NEW Nitecore EC22 XP-L HD V6 1000lm infinitely variable brightness - $38 ( $49 ) / Coupon: MAP / Store Link
Will there be a coupon for the Acebeam X45?
IMALENT RT70 XHP70.2 5500LM Magnetic Charging - PM for PREORDER deal
Features:
-Utilizes one American XHP70 2nd generation LED.
-Exquisite,powerful,long throw.
-Maximun output up to 5500lumens.
-Built-in intelligent temperture control module can automatically adjust the brightness output.Keep using camfortably.
-Built-in magnetic charging.Higt grade and portable.
Built-in multi-functional charging incicators:
-Function 1:Lower power warning.
When the battery voltage is lower than 3.2V,the red indicators will turn on.and if users try to activate turbo mode,the red indicators will flash three times to remind users battery too low to activate it.
-Function 2:Charging.
The indicators will be red when it is charging and turn green when it is fully charged to 4.2V.
Package included:
1 x IMALENT RT70 XHP70.2 5500LM LED Flashlight
1 x USB charging cable
1 x Holster
1 x Lanyard
2 x o-rings
1 x User manual
IMALENT RT35 XHP35 HI 2350LM Magnetic Charging - PM for PREORDER deal
Features:
-Utilizes one American XHP35 HI generation LED,with a lifespan of up to 50000 hours and a maximun output up to 2350lumens.
-6 levels which can be exchanged quickly and instant turbo.
-High efficiency caonstant current circuit will maintain constant brightness.
-Combination of toughened ultra-clear mineral and anti-reflective coating glass.
-Aluminium OP reflector.
Package included:
1 x IMALENT RT35 XHP35 HI 2350LM LED Flashlight
1 x Holster
1 x Lanyard
2 x o-rings
1 x User manual
XHP70.2 3500lm with Red and Blue Auxiliary LEDs 21700 Headlamp USB Type-C charging >> Luxurious setup
New Zanflare SB - 6039 folding Clover Solar Lantern - $14.99 ( $18.09 ) / Coupon: SB6039 / Store Link >>
Specifications:
- USB charging power: 5V
- Built-in battery: 3.7V, 680mAh
- 3 lighting modes: high mode, low mode, flash mode
- Solar panel output: 4.5V, 0.9W ( 0.3W of each piece )
- LED: 18 x 3528, white light, 6000K-6500K
- Fully charging time: 3.5 hours USB-charging
- High mode lighting time per full charge: 2 hours and more
- Low mode lighting time per full charge: 4 hours and more
- Flash mode lighting time per full charge: 4 hours and more
- High-brightness lighting time after 1 hour charging under sunlight ( 500W / m2 ): 15 minutes and more
- Low-brightness lighting time after 1 hour charging under sunlight ( 500W / m2 ): 30 minutes and more
Any idea on price or ETA on the Acebeam H30? Also, any new details on the Astrolux X? Thanks!
