How would that differ from the Q8?
Single reflector with a 35 HI or other throwy led. In my mind that was implied, but my mind is not always clear.
I’m sure there are lights like that already out there, they just need a driver swap. Maybe a Haikelite MT07S or Klarus G35 with one of Lexels drivers.
When his boost driver comes out you could build an even smaller thrower using a 26650. Like the Utorch uto2 which is very cheap.
Don’t wait for BLF to make it. Make it yourself! Lol
I have a MK35 that I might upgrade with a GT/Narsil driver and a 4000K or 4500K led swap. Wish me luck, I’m goin in! The 4000K in the GT has gotten me hooked. I just bought a MX30L4Cvn with XPL Hi 4000K which is now my favorite balanced light.
. GOOD LUCK!!! . :+1: .
Extremely compact 21700 flashlight powerbank.
- USB type C
- Astrolux 22 mm quad lens
- Samsung LH351D, XP-L HI variants
- Texas Commander / LD4 style driver with FET on MCPCB, regulating the light all the way to peak output. Might place other components on MCPCB too it that’s needed to save space.
- Ramping UI
Initial, somewhat incorrect sketch:
I drew it without glass protecting the lens. I’m not sure it that’s a great choice especially that bezel blocks some light, just like it is with S2+ triples.
And there is no place to put threads between head and body tube, so this is a unibody light with press-fit driver. Not sure if that’s feasible with USB and maybe a button on the other side. You can remove the driver by poking it from the optic side.
Why did I say “maybe a button on the other side”? Because I’m wondering if a button assembly plugged into USB slot wouldn’t be a good idea.
It seems that “extremely compact for its battery type” is a very common desire. In general, I’d like to see more lights which are barely bigger than the fuel tank.
Unusually, I’d like to suggest not a from-scratch project but a special edition of existing light.
DQG Spy Ti which has low-bin XP-G2 replaced with Samsung LH351D. Warm CRI90. That’s it.
Well, extra points for shortening it to 10150 or 10160.
ADDED:
Or AR coated lens.
Or glow o-ring.
OK. There are a few things that could be done better.
But nevertheless this is a good light that’s extremely close to being a great light.
I’ve had the concept in my head for a long time…I made some drawings before…but just couldn’t make it right.
Now I managed to put all the pieces together.
Welcome A7, a pocket hotrod.
Features:
- 7 LEDs, XP sized. Dedomed Samsung LH351D would be my pick.
- Though XP-L2 would turn it to a 5-second light
- 21700
- Texas-Commander / LD4 style driver integrated with the LED MCPCB regulating the light to 10+ amps. With Turbo above that.
- Unibody
- E-switch
- DQG style tail cap
Here’s the drawing, next to a rough outline of Emisar D4.
Inspirations (alphabetically):
DB Custom’s Titanium X6, DQG Tiny 18650, DQG Tiny 26650, Emisar D4, Led4Power’s works, Zebralights
Do you have a bigger picture to share? (pm?)
No, I don’t.
I draw stuff pixel by pixel in gimp. This technique limits me heavily, but that’s what I’m capable of.
If you need larger, simply zoom it.
Why not use something like sketchup or solidworks…
Sketchup doesn’t work on FreeBSD. I contemplated learning CAD before but never reached that point…
If anyone needs me, I’ll be over here crying.
You could use Blender. Or FreeCAD. Or LibreCAD. Or OnShape. Or several others. If you don’t want to do a full 3D model, I find Inkscape is good for quick 2D stuff. Its grid options make it easy to build accurate scale models.
Yes…I know that drawing lights with 1 mm resolution is barbaric.
I just never got the motivation to learn something different.
After all, what I draw is good enough to show the idea.
It is good enough to make me encounter most problems.
Regardless what tool I use, if anyone was to actually manufacture one of those lights, they would CAD it anyway.
This is not good enough to draw an angle light though.
I need 3D to figure out internal layout. I’d like to draw one one day. Maybe then I’ll get motivated to learn some better tools.
When I see the word ‘Donation’ in the thread title, I remember the only flashlight I have seen in the Third World village near me.
It was a broken, stubby version of the now famous light we see everybody trying to sell,…this one with bulb battery, plastic zoom lens, gritty switch and corrosion from the penlight cells, (not even alkyleaks).
A foil covered piece of cardboard with a rusty spring on one side, an LED of sorts seemingly glued (?) to the other….it was the the owner’s pride and joy while it lasted.
Regardless what tool I use, if anyone was to actually manufacture one of those lights, they would CAD it anyway.This is not good enough to draw an angle light though.
Well, if you’re using GIMP, then you probably have a harder time penciling pixel-by-pixel than you would have just drawing a nice shape with smooth lines and curves.
Why are you not using windows…
Them’s fightin’ words ’round these parts.
