M4D M4X deals - Astrolux WP1 and WP2 LEP
these Basens are good? quality…looks like Litokala…
Hello my dear friends!
new day – new deals!
SKILHUNT H03 RC
XM-L2 U4 1200LM NW/CW Magnetic Charging LED Flashlight Outdoor Headlamp Headlight
find the deal here
Jetbeam E01R
XP-G2 138LM AAA Mini Outdooors LED Flashlight
find the deal here
Convoy Tiny XP-E2
Stainless Steel EDC LED Flashlight AAA
Code: MCNTY price: US$ 9.97
Nitecore V2
6A USB Output In-Car Speedy Smart Battery Charger with 12V Adapter 2Slots 18650 26650 AA
find the deal here
LiitoKala Lii-S1
Intelligent LCD Display USB Battery Charger for 18650 26650 14500 21700 Battery
Code: MLKT1 price: US$ 6.99
new Fitorch deals: M30R & P26R (with free cell)
i managed to get two new deals for Fitorch flashlights:
Fitorch M30R
XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank
find the deal here: M4D M4X DEALS or ask me…
(pictures links to the shop for further info and specs)
Fitorch P26R +Fitorch 26650 Battery
XHP70.2 3600Lumens FCD Rechargeable Portable LED Flashlight +Fitorch 26650 Battery
CODE: MIHB2 drop the price to US$59.99
Interested.
Code
- Skilhunt H03F RC , H03R RC
- HC65
  • P26R
    Please. Thank You.
today i got a not deal for a great multi purpose light:
Rofis R3 only $56.99
XM-L2 U3 1250LM Magnetic Charging Adjustable-angle Head LED Flashlight Headlamp
Brand
model = my Link
Code (copy/paste)
price (US$)
Rofis
R3
0cad0e
56.99
Features:
-R3 is an innovative multifunctional magnetic charging LED flashlight with adjustable-angle head.
-Utilizing the XM-L2 U3 LED,it delivers the max output of 1250LM whten using 18650 Li-ion battery,compatible with 2*CR123/RCR123A battery .
-The head rotation structure combines with non-acute angle design stable and reliable,the head can rotate freely.The flashlight designs with magnetic tail cap and mental clip,it is conwenient for multifuntional use.
-With compact size.it can be used as headlamp while using with headband.
-The head and body of the R3 flashlight are connected by a stainless steel central axis,the head can be rotated and beam angle can be adjusted as well.
-The hard surface is made of aero grade aluminum alloy,premiun type III hard-anodized anti-abrasive finish.
-When R3 is used as headlamp,the user can put into silicone head caps without removing metal clip,which is easy to operate.It would work better with tail cap removed.
-According to the position of the switch and the roration direction of the head,it is recommended that the user use right hand to press the switch(Put the switch stay towards right above and rotates head into opproprate position to provide lighting).
-Angle surface with non-acute angle design,rotates smoothly;Ergonomic ratation design,one-hand operation.
-R3 comes with a detachable metal clip,combining with head rotation function,which enriches its usage scenarios.
-Powerful magnetic tail cap,can be attached to metal object,combining with head rotation,the application scenarios of R3 is greatly expended.
-With a set of high efficient constant current circuit,constant brightness,no flicker.Automatic contral of turbo mode,prevent from overheating.The built-in circuit has overdischarge function so as to take full use of battery capacity.
-The brightness range from 0.25LM~1250LM.It will meet the brightness demands in different environments.
Charging Indicator:
-Red light keeps on,means charging.
-Green light keeps on,means charging is completed.
-Red and green light blink alternately,means incorrect battery installation or no battery exists.
USB Magnetic Charging Funtion:
Parameters:Charging current:1.5A.
Charging time:about 3.5 hours.
(Note:Built-in ROFIS 18650 3400 mAh lithium-ion battery)
Battery power detection and low battery power reminder:
-Battery power detection:
After installing battery and screwing on the tail cap,R3 will automatically detects remaining battery power.
The green power indicator keeps illuminating about 2 seconds,which means that the battery power is more than 40%.
The red power indicator keeps illuminating about 2 seconds,which means that the battery power is less than 40%.
-Low battery power reminder:
With the light on,when the battery voltage is low,the red indicator will blink every second to alert user that the battery power is close to depletion and we suggest to charge battery promptly.
Package included:
1 x Rofis R3 XM-L2 U3 1250LM USB Magnetic Charging LED Flashlight Headlamp
1 x 18650 battery
1 x Headband
1 x Clip
1 x Charging cable
1 x Lanyard
2 x O-ring
today i bring you 5 new preorder deals:
contact me if you want to know the details or just CLICK HERE
Acebeam X80
19LEDs 25000Lumens 11Modes Super Brightness UV LED Flashlight
Acebeam L30
XHP70.2 4000Lumens 7Modes USB Rechargeable Brightness Tactical LED Flashlight
Acebeam K30
XHP 70.2 5200Lumens 7Modes Brightness LED Flashlight
IMALENT RT70
XHP70.2 5500LM Magnetic Charging Intelligent Temperature Control LED Flashlight
IMALENT RT35
XHP35 HI 2350LM Magnetic Charging Intelligent Temperature Control LED Flashlight
K30 ordered, thanks.
Interested L30.
NEW code available for
nitecore BR35
another 10 USD drop ;)
Interested Acebeam X80 , L30 , K30
Thank you.
I got new (lower) prices for them
I pm you asap
Hi Martin,
Do you see any chance to get coupon codes for following AceBeam flashlights, too?
AceBeam K70
AceBeam X65
Thank you!
sure ;)
as soon as they are ready to preorder
Thanks a lot! I just noticed that both flashlights are currently under restocking. So, hopefully they will become available soon again (along with a nice discount :smiley: ).
Is the BLF Q8 coupon expired? It said something about 700 users?
I let them fix that
Also the Convoy 20% brand code expired.
today i can offer you a nice deal from my partner HKEQUIPMENT.net (please use my link)
10% OFF any nitecore item with the code: cvhNC10cx
and
20% OFF nitecore items above $ 50.- with the code: cvhNC20cx
Code does not work on blf q8
Q8 deal is reactivated
20% Convoy code: M4Dconvoy
