Thank you EasyB, you reminded me that I failed to include calculations. I’ll do that now.
According to The Driver, XHP35 HI has thermal pad of 4.11 mm²
I’ll use this number as I suppose it comes from polarity indicator. It’s not a big deal…
I wonder why did you use 50 µm? I have seen no data on what would be joint thickness and used to use the smallest recommended stencil-produced 70 µm. At this point I’ll use both numbers, I have no idea where lies the truth.
Let’s calculate temperature increase on the solder joint when driving XHP35 to its peak (note: peak with SnPb solder; a better joint should move the peak slightly).
With 50 µm bond thickness the temp difference would be:
49W / 4.11 mm² / 50W/mK * 50 µm = 11.9 K difference.
With 70 µm bond thickness that would be 16.7 K difference.
That’s assuming there are no voids in the joint. This is unrealistic. Let’s use 10% voiding and assume that thermal resistance scales linearly with voids (it’s probably worse than that). So the real differences would be 13.1 and 18.4 K respectively.
According to PCT, dropping temperature by 10 K (150°C->140°C) improves flux by 2.5% at maximum current that they specify. Let’s assume that improvements that we make are linear to this gain.
With 50 µm bond we can gain:
table(table#posts).
|Material|ΔT between LED and PCB|ΔT improvement over SnPb|output improvement|
|Sn63Pb37|13.1|0|0%|
|Indium|7.6|5.5|1.4%|
|Conductonaut|9|4.1|1%|
|H9890-6A|4.7|8.4|2.1%|
With 70 µm bond we can gain:
table(table#posts).
|Sn63Pb37|18.4|0|0%|
|Indium|10.7|7.7|1.9%|
|Conductonaut|12.6|5.8|1.5%|
|H9890-6A|6.6|11.8|3%|
Theoretically, a 10 µm bond of 9890-6A would bring improvement of 3.1% to 50 µm SnPb and 4.4% to 70 µm SnPb.
I am interested in continueing the discussion here. From a practical perspective I find the Indium solder much more interesting. The US company Indium offers several types of solder wire containing Indium, this is presumeably what Agro also found. Yes, it’s quite expensive, but a small amount would suffice for most people. The problem here is that only a very high Indium content actually allows for a better thermal conductivity compared to standard solder types (see values in datasheet ).
I have found a “cheap” source of Indium wire here in Germany. I guess you would need to add flux to solder with it.
Concerning voiding:
One property of Indium is that it fills voids. That is why it is used for sealing things.
I wonder if the reduced mechanical strength of the solders bonds compared to normal solder bonds really makes a difference when solderding LEDs. They really don’t weigh much.
So generally it seems that spending a lot of money on Indium is hardly worth it, but since we have found rather cheap sources, it does seem to make a little sense (because of the theoretical creeping effect in addition to the tiny temp difference). If you combine it with cherry picking LEDs, soldering under pressure and using liquid metal thermal paste under pressure, you might get noticeable gains. Cherry picking LEDs will probably have by far the biggest effect! If I were to reccomend one thing, that would be it.
Interesting 2010 paper from Luminus: http://www.nbetech.com/pdfs/Application_supplemental_3.pdf
They attach their dies with sintered silver.
An interesting note is that their process requires temperatures of ~260 °C. Probably for no less than an hour. Therefore such temps are not problems for LED dies. Is it for silicone? Is it for phosphor?
Also, saabluster used Diemat DM6030 with XR-E.
This glue requires curing at 225 °C for a quarter + 200 °C for 30 minutes + 175 °C for 45 minutes.
saabluster knows his stuff and if heating up like that reduced LED performance - he would probably find out.
So it seems that at least XR-E is resilient to prolonged heatup to 225 °C.
I’m somewhat puzzled as Nichia’s 260 °C is quite close.
Though if 200 °C is not a problem, pressureless sintering looks like the best way.
In this paper you can see a nice list of makers and users of this tech. It’s quite extensive.
OK, some details found on low temp pressureless sintering so far: Namics XH9889-2 offers 300 W/mK. With curing at 200 degrees. That looks like the top choice available.
But another interesting options is Nihon Hanada MAX 112. Cures at just 150 °C, that’s certainly safe. 182 W/mK ain’t bad.
But something tells me that this indium wire might be cheaper.
I was just thinking - why not just use SnAg solder paste (or wire)? Sn96.5Ag3.5 supposedly has a thermal conductivity of 78W/mK and a low melting temp of 220°C. It's important to differenciate between SnAg and SnAgCu solder. The latter has a lower thermal conductivity of around 60.
Some solder wire products I found:
Felder ISO-Core VA Sn96,5Ag3,5 (Sn96Ag4 according to DIN EN ISO 9453) (221°C)
Furutech S-070 SN96,0Ag4,0 High Performance Solder (220°C)
One thing to note when using solder wire with LEDs: one needs to put flux onto the contacts of the LED because the flux in the solder wire is probably gone when you put the LED onto the tinned pcb contacts.
I just noticed that I have discussed this topic before a few years ago (here).
Nope, I found nothing better for this kind of stuff.
There may be some improvements for lights that have bottlenecks down the path (f.e. DQG Tiny 18650), but I can’t add anything to improve on what’s said here.
It’s probably a bit related. Just got an IC Graphite thermal pad kindly shipped to me by zak.wilson. Here’s a quick test comparing it to the MX-4 thermal paste. No TIM for reference. It seems to suck heat off the MCPCB just as well as normal paste. It’s reusable too, and no cleaning required so perfect for LED testing.
Thanks for the test! That is indeed very interesting for lights which are modded vers often.
Could you repeat the test, but measure the brightness of the LED?
OK, so I got some Indium off AE (advertised as 99.99% pure….) and tried soldering it. While it’s very very soft, about as soft as pure lead, joint strength was surprisingly good. Two strips of FR4 PCB soldered together in an area of ~1cm² wouldn’t come apart until the FR4 itself was severely deformed. Wetting, as expected, was very good (I used some standard rosin flux).
I found one possible downside to pure indium though:
This could be an issue with ceramic packages, though I doubt it applies to any but the most expensive sources.
(This paper also somewhat relieved my concerns about creep failure though I’d take extra precaution not to stress the emitter via the centering ring, just to be sure.)
I just remembered an additional material upgrade. Normal dtp pcbs are made out of copper or aluminium. There is another possible material onto which the LED can be directly soldered which transfers heat even better than copper: silver. Basti in the German TLF forum made such a pcb a few years ago. He made it just for the looks though.
The thermal conductivity of silver is 7% higher than that of the best possible (most pure) copper. Most common copper alloys are not 99.99% pure though, making the difference for pronounced.
I asked him if he would make one for me for my big thrower when I was planning the build, but he is not an active flashahlic anymore.
