Thanks for the review!
i just bought my D4 with the XPL-Hi 5D, i’m wondering why the xpl-hi is $18 more expensive, i dont think there is that much difference in led prices
Yes, but lack of throw is my only reason to prefer a similar light with one LED.
D1 is similar to that, but its reflector is large enough to make it bad at close distance.
I want light that’s OK up close, but not a thrower. There is no Emisar like that.
A typical EDC light has a beam shape of about 8-12 cd/lm. Ish.
The Emisar line comes in ~4 cd/lm, ~33 cd/lm, and ~100 cd/lm.
None of the options fit the EDC beam style. That’s why I want a single-emitter light like the D4. It’d probably be the most useful variety for general purposes. Also, a single-emitter version should be cheaper and a bit smaller.
these will run the D4 XP-L’s for 15-20 seconds on TURBO before triggering the thermal protection set at 65 degrees. which is more than enough time for spotting a crashed UFO at a considerable distance.
No, the replies were informing that even a protected (longer than normal) cell wont fit, so therefore a USB rechargeable (also longer than normal) cell won’t fit either.
The USB rechargeable cells may not be protected, however I’m not aware of any High Drain USB rechargeable cells, and a High Drain cell is what allows the D4 to reach it’s full potential.
If reaching full output is not something you’re concerned with, you may be able to use a USB rechargeable cell by doing the copper ring mod described in the German forum.
Also technically all 18650 cells are “rechargeable” to avoid possible confusion the cells you’re referring to would be better described as “USB rechargeable” cells.
Thanks, I’m happy someone else agrees, I actually felt kind of anal by pointing it out because I figured most readers understood what he meant, but it was my own slow working brain that had a duh moment when I first read his post, took me a few minutes to realize he was referring to USB cells :person_facepalming:
Ahah, so both we have slow working brains mate, worry not
I was also confused at first, but then perceived the intention! :+1:
Anyway, I don’t think that USB rechargeables will fit, and mostly, they probably won’t deliver the maximum energy that this light needs to be “a hot rod”!
I received my Emisar D4 with High CRI Nichia from Hank. My first one got lost in the mail, and he was very professional in getting me a replacement. I am very happy with his service, and I am happy with the light overall, but my only complaint is that the lowest lumen setting is not low enough for me. I like the sub lumen settings of the Zebralights, and the Emisar won’t go that low. Are there any plans to change this in the future?
