I was on the fence with this light. After this review I think I am just going to pull the trigger. Nicely done review. Thank you very much.
I’m close to pulling the trigger, I would just like to know the battery sizes it will accept. I’d like to use the Shockli 5500mah which is a bit wider than most. Is it possible to get an exact inside diameter measurement?
Nice review & pictures .
Great review and photos, mine is in the mail as we speak. Looking to run keeppower 6000 26650’s in it.
Outstanding review. Fantastic pictures! Thank you.
Thank you all friends!
Inside diameter is 26.6-26,7 mm
I really like your review! Great photos and helpful charts. I wonder how this compare with the TC20.
Very nice review with losts of great pics in nice surroundings, makes me want to go on holidays, with the ODF30! Thanks for taking all the trouble making the review. And welcome to BLF
Awesome, thanks for the great review with beautiful pictures, it reminds me to go outdoor right for the time, good job! :+1:
Nice review & great pics. I would appreciate if you could do compare beamshots between Rofis MR70 & ODF30. It is very hard to see actually Tint, brightness & a beam pattern without the comparison beamshot.
hi...you can see my review on CPF Italia of the Rofis MR70 Here . You can compare "Beamshots del Main LED (Low-Mid-High-Turbo)" of MR70 with "Beamshot #1" of the Lumintop ODF30.
Great review & pictures. Thanks
Thanks for the lengthy reviews and pics!
In my review I found that the parasitic drain was 0.05Amps. Could you check that? I just unscrewed the tailcap to meaure when turned off and measured between 0.02A and 0.05A.
Edit: I guess it's my reading... I just can't understand how to read my DMM.. It just says 0.05
ok i checked...the parasitic drain in my ODF30 is 51uA (0,051mA or 0,000051A) .
With a 26650 5200mAh battery the teorical runtime is 101960h (4248 days or 11 years) XD
Hmm. Maybe i jist didnt read it good enough. Are you sure it's not 0.05A? :)
XD...yes i'm sure...In the photo you can see the used scale in the multimeter (uA) and the measured value 51,2uA :)
Yep, seen it.. Need to double check it on mine...
Hi there, great review! I am keen on getting either the Rofis MR70 or the Lumintop ODF30. Wich one do you prefer, and why?
I am leaning towards the Rofis MR70 due to the USB port and the included battery. But it is more expensive.
I had an extremely negative experience with the Imalent DX80 so I avoid all Imalent and anything resembling Imalent. Rofis MR70 reminds me of Imalent. I would choose Lumintop ODF30!
