Will there be a coupon for the Acebeam X45?
IMALENT RT70 XHP70.2 5500LM Magnetic Charging - PM for PREORDER deal
Features:
-Utilizes one American XHP70 2nd generation LED.
-Exquisite,powerful,long throw.
-Maximun output up to 5500lumens.
-Built-in intelligent temperture control module can automatically adjust the brightness output.Keep using camfortably.
-Built-in magnetic charging.Higt grade and portable.
Built-in multi-functional charging incicators:
-Function 1:Lower power warning.
When the battery voltage is lower than 3.2V,the red indicators will turn on.and if users try to activate turbo mode,the red indicators will flash three times to remind users battery too low to activate it.
-Function 2:Charging.
The indicators will be red when it is charging and turn green when it is fully charged to 4.2V.
Package included:
1 x IMALENT RT70 XHP70.2 5500LM LED Flashlight
1 x USB charging cable
1 x Holster
1 x Lanyard
2 x o-rings
1 x User manual
IMALENT RT35 XHP35 HI 2350LM Magnetic Charging - PM for PREORDER deal
Features:
-Utilizes one American XHP35 HI generation LED,with a lifespan of up to 50000 hours and a maximun output up to 2350lumens.
-6 levels which can be exchanged quickly and instant turbo.
-High efficiency caonstant current circuit will maintain constant brightness.
-Combination of toughened ultra-clear mineral and anti-reflective coating glass.
-Aluminium OP reflector.
Package included:
1 x IMALENT RT35 XHP35 HI 2350LM LED Flashlight
1 x Holster
1 x Lanyard
2 x o-rings
1 x User manual
XHP70.2 3500lm with Red and Blue Auxiliary LEDs 21700 Headlamp USB Type-C charging >> Luxurious setup
New Zanflare SB - 6039 folding Clover Solar Lantern - $14.99 ( $18.09 ) / Coupon: SB6039 / Store Link >>
Specifications:
- USB charging power: 5V
- Built-in battery: 3.7V, 680mAh
- 3 lighting modes: high mode, low mode, flash mode
- Solar panel output: 4.5V, 0.9W ( 0.3W of each piece )
- LED: 18 x 3528, white light, 6000K-6500K
- Fully charging time: 3.5 hours USB-charging
- High mode lighting time per full charge: 2 hours and more
- Low mode lighting time per full charge: 4 hours and more
- Flash mode lighting time per full charge: 4 hours and more
- High-brightness lighting time after 1 hour charging under sunlight ( 500W / m2 ): 15 minutes and more
- Low-brightness lighting time after 1 hour charging under sunlight ( 500W / m2 ): 30 minutes and more
Any idea on price or ETA on the Acebeam H30? Also, any new details on the Astrolux X? Thanks!
Not for sale yet.
interested in ODF30
thanks
Interested in XHP70.2 3500lm
Interested in acebeam XHP70.2 3500lm
Interested in acebeam 3500lm headlamp!
Headlamp interest….thank you
FLASH SALE
Fitorch M30R XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank - PREORDER >>> PM for Special DEAL!!!
Edit: Coupon fixed!
Features:
- CREE XHP35 HD LED, 50,000h life span
- 4 switches tactical &illumination modes Included
- Any time, tail cap tactical switches operates priority,one step action to shoot target
- Tail cap tactical switch lock function
- New FCD rechargeable & chargeable function
- Integrated aluminum housing design is to assure LOGO and patterns in line
- Smart temperature control system
- Smooth brightness mode change
- Harmony breathing blink beacon
- Battery detection
- Low battery Indication
- Constant current circuit without flicker
- High-strength aerospace aluminum body, Mil-Spec hard anodized for extreme durability
- Coated tempered resists impact glass In high light transmittance
- Metal filmed reflector to create a high intensity beam
Specifications:
- LED: Cree XHP35 HD
- Input: DC2.75V-6.00V
- Output: max 1800 lumen
- Reflector: precise metal filmed
- Glass: filmed mineral glass
- Material : HA-III military hard-anodized finish aluminum alloy
- Housing: Premium Type III hard-anodized anti-abrasive finish of black
- Switch: Side Switch and tail switch
- Powered: 1*18650 battery or 2*CR123A
- Size: Ø 1.44 inch/ Ø36.5mm, housing: Ø 1.1 inch /Ø28mm, Length: 6.26 inch/159mm
- Weight: 6.06 Ounces/169.8g (exclude battery)
The Nitecore LR10 code is not working anymore.
Sorry pal, we only have "BLF" coupon for 5% discount.
New products for the week.
Weekend Offer
Interested with Lumintop ODF30.
