hkequipment – Manker MK36 Palm Size for 12,000lm. Can act as Power Bank...
Undelivered mail returned to sender…
I’ve been trying to send mail to cs@hkequipment.net for some time and it bounces back.
I still have a Ultratac K18 brass unresolved issue but can’t reach you.
Do you have an Opus BT-3100 v2.2 and use the ‘discharge’ test?
That “Powerfocus”, if I recall correctly, is the earliest re-badged 3100 v2.0 and has issues with capacity readings.
PowerFocus Test unit not v2.0, and it is latest version. Need check
It (the version) will show on the display immediately when plugged.
Can you please try a full charge, then do a simple Discharge?
ACEBeam X80UV with 8pcs NIchia UV…
Very cool X80, it would be even neater if they put a ZWB2 filter in front of that 276A-array. I would at least mod it that way if I could justify buying that light.
MecArmy SGN3 USB Rechargeable Flashlight with White/UV/Red light - US$29.90
MecArmy PS14 Dual Color Temp Flashlight
Something for clearance…
One more target for copper fans…Nitecore TIP Cu
Fenix TK45 Brand New with box
4000lm can be provide by palm size flashlight…ACEBeam EC65, take one 21700 only with USB-C fast charge !!
Has the HKE80 code expired? I tried to use it today but with no joy.
Yep expired since March.
Sorry about that. It may be system error. I just reset the coupon and work well now… Thanks for remind
Manker MK39 6000lm with handle!!
Nitecore Concept 2 6500lm - just half Can size!!
Sorry to bring back this issue in your thread, but i’m left with no other options as you don’t reply to my PMs.
That was on April 15…
The issue dates back from last December and is still unresolved.
What’s this?
I’ve never had such a non responsive CS. :rage:
Buy Manker MK35, MK39 or TimebackII - FREE Manker TACTICAL PEN
Hi HKEQUIPMENT,
I would like to buy a MANKER T01II, its’possible to have a good discount code? thanks.
ACEBeam X80-GT 32,500lm with HANDLE
