TKās AndĆŗril UI is amazing. I have it running on several Q8s, an EagleEye X6R, and an Emisar D4, D1, and D1S.
I burn a Q8 in candle mode quite often with a warm diffuser. Itās quite realistic in person, and even has brightness adjustment to go from candle to torch.
Itās random. :+1:
TK has also mentioned adding a āsleep timerā to candle mode. I canāt wait!
That, is cool. One of the most realistic ones Iāve seen. Only possible addition I could see would be a circle of smaller LEDās around the main one to help simulate flame deflection.
I like that mode idea too, give the effect of a candle or classic kerosene oil lantern for those effects that we canāt get from any other LED lantern available.
Thereās so many aspects of this Iām stoked about. Iāve wanted a good lantern for years now and I feel like this is it, finally going to have a great lantern. The candle mode is honestly just a big bonus to me.
I should receive the Thorfire provided Q8 tomorrow in the mail, and plan to work on that for the new prototype base this weekend to get this project rolling.
UPDATES,April,20,2018 -:The Q8 sample/mule arrived for the updated prototype. I have already torn down the head, and have the driver out, and doing measurements of where to cut the head down to incorporate the new lantern shade/lens and center support post. First thing is i need some guidance on what to do with the Q8 driver to reduce its maximum output in all the high modes down to 1.5 amps possibly? I could leave it as s, but with the high output current in the lantern running continuous it would overheat the LEDs & lantern head very, very quickly and likely cook the LEDs or melt the lens attached to the solid aluminum head. I plan on the new prototype to run two down-firing LEDs on each side of the center support post/bolt instead of the single LED as in the 1st gen prototype. Also will use a frosted main shade/lens with no inner diffuser instead of the clear lens & inner diffuser as the 1st prototype does to reduce manufacturing costs. The lantern head I have already blue-printed and in thw works on the Q8 head design, right now i need to driver experienced team members ToyKeeper, DEL, and even possibly the original Q8 team to help directing me to modding the driver to reduce its peak current to the LEDs. As of now I will keep the current Narsil program in place for the first prototype lantern, using the #7 mode set. But we will look to Toykeeper to possibly add the extra good modes including the candle & sunset modes to the firmware later. More updates soon as i work on the structure of the Q8 head for the lantern
SECOND UPDATE:-After looking over & measuring the original Q8 copper 4-emitter star, I may build the V2 prototype lantern using that very same start & its emitters, as it already has a center hole, & can be actuall fitted to the same heat-sink head of the V1 prototype of the lantern, (further reducing costs? but unsure if it will be cheaper for the production model to use that Q8 PCB, or use two separate more generic 16mm copper single-LED stars.
So, 4 LEDs total? Could you just re-use the stock Q8 PCB but upside down? You could use the center hole in the PCB for the mounting post, and run the wires parallel or through that same post?
There are already lights that use a USB āOTGā adapter to do charge/powerbank from a single port. Granted you need this dongle but itās still 1 port.
This is awesome! Iām so glad to see the project getting some updates and action. Thank you all for your work, especially DBSAR, I really want this one to happen!
Iād suggest replacing the FET with a stack of 7135s, maybe start at four. Easiest way is to piggyback a generic 7135 driver onto the board, lifting the control pin from the piggyback board MCU and connecting it instead to the gate drive of the Q8 FET. I thought DEL had designed this already, heās the one to look too for advice.
That sounds like a plan. The Q8 MCPCB shouldnāt cost much, actually it should be rather inexpensive if Thorfire are to be the manufacturer. A new MCPCB supplier was brought on by the Q8 team, who I think have performed (not sure if they used the recommended supplier or did it otherwise, but these big technical parts are not expensive in volume) , possibly speak to djozz who I think set this part up.
