Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
Just to make sure I understand correctly TA.
  • YOU will tell us when & how to make payment (downpayment / prepayment).
  • You “might” offer a ‘tube’ large enough to accommodate a GT sized light.
Is this correct??
Thank you TA……… :+1:
Yep, pretty much. I just want to nail down the final details to make sure there are no surprises before I start taking money.
This is much larger then I first planned on and the costs are higher as well. So having to re-figure some things and make sure I can get the quantities I need.
Count me in.
Terry
Boaz is selling DC-Fix Here and he has mentioned that he has some other materials including some that are thicker/stiff that he needs someone to test. Maybe you could help him out with testing, and it might be similar to what you’re using for this tube or even the same material. I don’t know what price you paid for yours, but I think you should check with him.
Yeah, I got my DC-Fix from him myself. I was planning on using it for the sphere but it would of needed a separate piece of glass to mount it on.
The biggest reason I want more of this particular diffusing sheet is that stacked in the right order it gets the sphere within about 5-10% off the bat, which is much easier to fine tune then something that is further off.
I am pretty sure I saw another half sheet of this on a shelf when I got this but I didn’t worry about it since I didn’t think it would be needed. I plan to stop by tomorrow and see if it is still there.
Sounds great TA, looking forward to it!!! :+1:
Looking forward to the option of the larger tube before I commit. Prefer the larger tube
I did some searching online earlier today and the larger tubes are only 5-6x the price online (each bench was $30-$50)
I know of a local specialty plumbing supply I plan to check tomorrow.
“Only” 5-6 times. LOL. I guess I will be buying the standard size!
What about using a 6 inch to 4 inch reducer on the regular lumen tube and then have a correction factor specifically for using that reducer?
That way it keeps the cost size and shipping weight down and only adds one extra piece to be used on rare occasions. The rest of the time you have the normal three and a half inch inlet and can read the lumens directly off the meter.
I have considered this as well but it would have to remain attached at all times, the calibration would change too much to be easily compensated for when it was added or removed I think.
Installing it on top would make it top heavy and I don’t think it would sit flat anymore.
Using a 6” to 3-4” 90* bend is another option I am thinking about but talk about expensive!
I will see what the specialty place has, if they don’t have it, then I don’t think I will be getting it.
Yeah, thats why I stuck with the 3.5” myself, it was just not worth the higher cost for the handful of lights that would need it.
Although I was looking at home depot before, I hope this plumbing store will have a better selection and pricing on the large parts.
Put me on the list for one.
Thanks for doing this!
Definitely interested!
Added!
So is that a request to be added to the list or just an “i’m watching this closely and thinking hard” post?
Please put me on the list for one also.
Interested so put me on the list. Wouldn’t it be cheaper to just ship the diffusers and meter then we can get the pvc long radius streets and the reducer ourselves?
No, because they have to be assembled in a very particular way, then calibrated to TA’s meter (through “magic”) to give accurate results. Like he said before, even the orientation of the diffuser panels can alter the readings.
I am guessing that once he has finished construction and made all the final adjustments he will glue the pieces together to lock them into place. Perhaps with the exception of the 90 that the flashlight head goes into. He can mark the position that the 2 pieces need to be, then rotate the end 90° so it can be boxed up flat. When you get it, you rotate it back into position and be back at accurate readings.
That is my understanding of it.
Keep in mind that even different batches of pvc pipe from the same company can exist which might throw off the readings. The white pigment could differ slightly, the surface finish could differ slightly, etc… By TA doing it his way, he can compensate for all this.
Thanks Jason for the explanation. Didn’t realize he has to calibrate each setup.
