OK, I decided to discuss some of the design decisions. I recognise that some that I mentioned here are totally uncontroversial and that others lack that luck. But they all have some tradeoffs involved and I wanted to bring them closer.
1. Triple
less output than quad
more peak cd than quad (though if the leds were driven to the same level they would be about equal)
with linear driver, marginally less sustained lm
more sustained cd
quad optics could be lower
lower cost
less board space taken
OK, I just wanted something throwier than a quad
2. Khatod TIR lens
unknown efficiency, probably lower than that of reflector
seeing the CRXed cups , I suspect that efficiency is quite low
it nevertheless gives much higher cd/lm than f.e. Ledil Cute
it is very low for the diameter, reducing the light’s size
nice beam profile
available in pebbled and frosty variants too
alternative: Chun Kuang M312
0.9 mm shorter
smaller cups
less throw
not CRXed - better efficiency?
clear, pebbled, frosty - whatever
alternative: Ilenstech ILENS61-S34
1.3 mm shorter
1 mm smaller diameter
siamesed a lot - good throw at the expense of beam shape?
3. Without glass in the front
more prone to scratches
but AR coating scratches too
anyway, it is replaceable
less prone to breaking
3% higher output
1.5 mm shorter and over 4g lighter
does any flashlight come with antistatic and/or hydrophobic coating? This possibility is lost.
4. 21700
alternative: 26700
would be smaller than the head too, but thicker, heavier, worse for EDC
for max power, compatible with 21700
alternative: 26650
as thick as 26700, marginally lighter
no 21700 support
with DQG tail it’s not any shorter than 26700
alternative: 18650
less comfortable to hold
a little less size, weight
would enable 18350 support
18350 unibody + 18650 extension?
resign from unibody?
much smaller capacity
4. Dedomed LH351D
fairly cheap
single chip (good beam shape)
non-flipped chip (no tint shift, good throw when flattened)
the most efficient non-flipped single chip that we know
though XHP35 deserves a mention as optically it works as if it was a single chip. And at high power levels it’s more efficient than LH351D.
nice tints
available in wide range of colour temps and CRIs
high Vf
lower peak output, especially with weak battery
fairly high efficiency with linear driver
better sustained performance
falls out of regulation quickly
but thermals make it drop output quickly too
since it’s a triple, Vf is actually not that high
fairly small footprint for the performance
5. DQG tail
light length changes with battery length - never longer than needed
large battery contact - minimal resistance
no spring and related resistance
~2 mm shorter than PCB + spring, several grams lighter too
some are worried of battery safety
I’ve heard about some problems with Tinys, none was battery-related
TorchLAB ZeroRez is somewhat similar
battery rattles slightly when physically locked-out
6. Texas Commander / LD4 style driver
low height
little board space taken
fairly low cost
OK efficiency
unmatched regulated power for the price
unmatched regulated power for the size
very high unregulated power
7. Driver + LEDs on a single board
smaller!
short thermal path from LEDs to MCU
though some drivers shorten the path with extra thermometers on the MCPCB
some driver components need good cooling too
but other need to be rated for high-temperature work
Driver plus LEDs on a single board isn’t hard. Some manufacturers do it to make the lights more compact and/or for other reasons. I’ve even made a few drivers with LED pads on board. Isolating stuff is just a matter of “drawing it that way” when designing the PCB. If your design is very complex or needs to cram a lot into a tiny space, you can get extra routing room by using four-layer boards instead of the normal two-layer boards used by most drivers. It does cost significantly more, though.
A hole through the middle of the shelf. Press-fit plastic ring with a large brass button in the middle.
Fat wire (AWG 16? Gross overkill but why not?) from the button to the positive pad on the driver.
That’s just the first thought. There are surely other ways.
Here comes A1, a thrower sized between C8 and Emisar D1.
The host has the same basic architecture as A3. And the same major features.
It’s just 1 LED and a reflector instead of 3 LEDs and a TIR.
Reflector has exactly the same dimensions as Phoenix Electroforms PA19.01, so for the big budget users there’s an easy upgrade path.
This part costs $45 when buying 1 piece or $35 when buying 100. So manufacturer could offer it together with UCL2 window as a $50 option. Expensive…but I’m sure there would be buyers willing to pay so much for ~15% higher performance.
I got troubles picking LED for it, there are quite a few good options.
1. Dedomed LH351D:
Cheap, especially considering that it’s a part of A3 / A7 lineup already
High CRI throwers is untapped niche. LH351D enables the use of this LED
Available in warm white
untested throw
probably OK, but worse than any other mentioned here
2. XHP35 HI
very high efficiency at medium-high currents
possible high-cri
possible warm white
expensive
requires expensive driver
and actually a different driver, adding R&D costs
at peak power it’s going to oveheat quickly
3. Dedomed SST-40
quite cheap
good throw
quite efficient
only cool white
4. Osram Q8WP
moderately priced
extreme throw
low efficiency
only cool white
My choice would be to offer both Q8WP and LH351D. Q8WP is a really great thrower LED. LH351D covers the cases where it can’t do for minimal additional cost to the manufacturer.
Doing some performance analysis…let’s drive Q8WP to 7.3A to get round 1500 LED lm (note: this is Turbo mode, the light won’t sustain it). According to Enderman’s calculator with the upgraded reflector and UCL2-class lens this light gets 190 kcd and 1410 OTF lm. OK, minimal amount of dust and regular manufacturing tolerances will reduce it. Is 150 kcd and 1300 lm conservative enough?
With cheap alu reflector and regular AR coated glass calculations show 170 kcd and 1290 lm. Because of machining defects, the difference between calculations and reality is likely to be bigger for this one.
Dedomed LH351D should offer very roughly the same lm and half cd.
Today I drew an optional clicky tail switch, here presented with A1 but compatible with the other A* variants:
Technically the switch construction is based on GFS16 - FET (a necessity with 30T driving 7 LEDs), power indicator, its own li-ion battery.
This is not merely a mechanical lockout - UI should support changing modes with the clicky too.
If UI designer finds it beneficial to do a different UI for dual switch - it’s doable too as the driver can detect whether it’s powered with the switch or not.
How?
When turning on, the switch makes a quick pulse of power before actual full-on. This pulse can be detected by the driver (though this feature may somewhat increase the price).
A remote switch based on this one could be available as well.
Note: doing e-switch which would work like a clicky would make it like 4 mm shorter. But I guess dual-switch people don’t really want it.
I did some performance calculations for A1.
And received a quote for the electroformed reflector.
I’ll start with the latter…$45 one piece, $35 when buying 100. So manufacturer could offer it together with UCL2 window as a $50 option. Expensive…but I’m sure there would be buyers willing to pay so much for ~15% higher performance.
As to performance…let’s drive Q8WP to 7.3A to get round 1500 LED lm (note: this is Turbo mode, the light won’t sustain it). According to Enderman’s calculator with the upgraded reflector and UCL2-class lens this light gets 190 kcd and 1410 OTF lm. OK, minimal amount of dust and regular manufacturing tolerances will reduce it. Is 150 kcd and 1300 lm conservative enough?
With cheap alu reflector and regular AR coated glass calculations show 170 kcd and 1290 lm. Because of tiny machining defects, the difference between calculations and reality is likely to be bigger for this one.
Dedomed LH351D should offer very roughly the same lm and half cd. Hmm…maybe that option doesn’t really make sense?
I drew revision 2 of A7.
I didn’t like how it lacked the powerbank function, but was not sure if all components would fit on the MCPCB.
I did better calculations now and they should. But just to get extra headroom I increased the MCPCB size slightly.
Features (mostly repeated):
7-up TIR lens
either clear or pebbled (if there’s demand, frosted is not a problem either)
7 LEDs, XP sized.
Samsung LH351D
dedomed Samsung LH351D
Cree XP-L2 (pebbled lens only)
10 000 lumens for 5 seconds
21700
magnetic charger / powerbank
Texas-Commander / LD4 style driver integrated with the LED MCPCB regulating the light to 10+ amps. With Turbo above that.
I’ve been thinking about it for a while…and now I decided this is the way to go for the A family.
Let’s not make them 21700. But rather 21350.
Pros:
smaller by 1/3
Cons:
there are no 21350 batteries
So…it needs a little explanation.
First, there are no 21350 batteries now. But there are 18350 and 20350 now. And 21350 are likely to arrive eventually.
Why 21350 and not 18350 or 20350 then? Because it enables us to use extension tubes for 21700. And 21500 if they eventually arrive (18500, 20500 is available now).
21700 have 4600 mAh.
18350 and 20350 have 1100 mAh. And higher internal resistance which reduces performance.
Quarter capacity for 1/3 smaller size. Is that a good trade-off?
It depends.
If you don’t need more than 1100 mAh anyway - yes, it is. And seeing how many people EDC lights smaller than 18650 - I believe there are quite a few who don’t. On a twist, capacity reduction turns it from good powerbank to bad powerbank. So for those who EDC powerbanks and tiny lights - they would still prefer 21700.
So the real pros:
smaller by 1/3 for those who don’t need more than 1100 mAh
(optionally) smaller by 1/5 for those who don’t need more than 2000 mAh
just as large for those who do need more energy
Cons:
slightly costlier
worse thermal transfer to the tail
stylistically challenged
when using smaller batteries - slight to moderate performance reduction (depending on model)
It has not because I neither have the capabilities to turn these drawings into real lights nor will have them in the future.
So these are just drawings and will remain so unless someone different from Agro will decide to make them.
Seeing how little response they generate I conclude there’s little interest. And find it extremely saddening. Because few times in my adulthood I was as convinced I did something right as with them. And if there’s no interest, they will never be made.
That said, I almost monopolized this thread. Again. The reason is that there are apparently few people willing to discuss the topic.
Is it right? Is it wrong? I don’t know, it is what it is.
I am willing to discuss and I intend to continue. Because even if I’m mostly discussing with myself - I want this to be public.
Yeah, these seem like very specific and customized lights, not something that can be mass produced easily and make tons of profit from thousands of buyers.
I would recommend modding or scratch building stuff like this yourself.
Sometimes building the stuff yourself gives more satisfaction than simply buying it
It’s not the time to buy a lathe. 3/4 of the lights which I tried to mod don’t work. Well OK, I broke 1 beyond repair, the others can be fixed, I just wait for tools / parts / motivation.
Anyway, lathe is way off. And I don’t expect I’ll ever be in the position when I’d consider it good.
I’m a bit surprised to read that these are very specific and customized lights.
Because I went out of my way quite a few times to make them more generic.
I did include some controversial stuff in them. This may be what you perceive as “specific and customized”. I pointed it out and presented the rationale. The purpose was to start a discussion. Because my point is not to have them made to my specs but to BLF specs. The discussion didn’t start.
Well first you were talking of a 21700 flashlight, a battery which almost nobody has, and now 21350 which doesn’t even exist.
Why would people buy a 21700 flashlight if they have plenty of 18650s and 26650s already, which are still better (power density) than any 21700 batteries that are available atm.
Stuff like dedomed LEDs, unibodies, magnetic chargers, etc. manufacturers simply won’t do for multiple reasons, the first often being cost.
Unless there is something special about the light, like super low cost, extreme throw, high lumen output, etc. it’s not going to draw in the thousands of buyers needed to create a new flashlight from scratch.
It needs to stand out in order for a manufacturer to jump on board with the idea.
It’s not cheap to bring a new product into production.
There is far more work involved than making a drawing a couple pixels big, and all the work needs to be paid off in sales.
If it can’t make the sales for whatever reason then you’re left with either building it yourself (like I do with my lights) or paying someone a lot of money for a one-off.
Just an off topic note:
Power density of current 21700’s is the same as the 18650 since it’s just a bigger version of it. The 26650 has lower power density since it’s not made by a major battery company.
The highest I’ve seen available is 4800mAh, which is lower power density than a 3500mAh 18650.
Also 26650s still have much more capacity than a 21700, so unless the goal is a super compact flashlight, if you care about runtime you will go with 26650 over 21700.
If you care about power density more than runtime then you would get an 18650.
I looked for 2 fairly new cells with the same continous discharge rates in order to make it as comparable as possible. Apples to apples, so to speak.
Samsung 48G – 4800mah 10A
This 21700 cell has a volume of 24.25mm3.
This equates to 198mah/mm3
LG MJ1 – 3400mah 10A
This 18650 cell has a volume of 16.54mm3.
This equates to 205mah/mm3
So they are pretty much the same – power density wise. The 21700 is about 47% bigger and has about 41% higher capacify. It’s not an exact scale up, but almost.
It seems Tesla is predicting their new 21700 will have a capacity of 5700-6000mah! I have not seen any batteries with that much capacity. Not yet, at least.
If this turns out to be true, then the power density will definetly exceed the 18650.
So far, I really like this quote from John Peterson.
“Batteries are chemistry in a can and changing the size of the can does not change the energy density or cost of the chemistry inside the can.”
