Some other people, and some companies, have also added displays to their lights. The Nitecore TM26, for example. I don’t recall offhand what the others were though. The idea seems to come and go periodically.
Thanks for the review, i just got mine in cyan with xpl hi.
When the tailcap is tighten, there are two blinks, I’m not sure if this have any other meaning or just a notification that it is ready to turn on. If it is just a notification, it would be much better if the blinks indicate the battery level, like 4 blinks if battery greater than 75, 3 blinks if greater than 50. So you know the battery level everytime you unlock the flashlight, without having go to battcheck mode and count 12 blinks (for example if battery is 3.9 volt, and don’t know 3.9 volt mean how many % left ).
Also two method of showing battery level is also great. Please let me know if you think this is a good idea
On my firmware, the “power is connected” blink is much faster so it doesn’t really take any time. The slow blink was there because that’s how Tom likes it.
It could display remaining charge then, but it’d greatly slow down the process of physically unlocking the light for regular use. It also would need to wait a bit for voltage to stabilize before doing the measurement.
If this is a thing you want though, the firmware is available for modification. The simplest way would probably be to use Anduril, edit the setup() function to go into battcheck state instead of the “off” state, and edit the battcheck code so it’ll go to “off” state after one loop. And probably change the battcheck style to 4 blinks instead of volts+tenths, and perhaps speed up the blinking.
Another option is to make it do this only if the button is held at boot time. There is already a clause to handle this differently, though it isn’t compiled in by default. Usually I use “hold button at boot” for a different purpose though — factory reset.
I think 4 blinks can be made short enough that not to cause any discomfort when we want to turn on the light after tightening the tailcap and we are fast enough to count.
I agree with you that on the d4 the default two-blinks is quite long.
You maybe right that the light need some long time to measure the battery level right after tailcap is tighten
D4Ti, C type (purple), and F type (golden-blue) are back in stock, with very limited numbers.
The D type (purple-blue) is out of stock and discontinued.
The colorful version D4Ti will not be produced again when they are sold out.
It would probably not be easy to physically modify the driver to reduce FET current, but maybe one could reduce contact to just one leg of the FET’s ground pads? I’d suggest using thinner wires from driver to MCPCB instead.
Holy cannoli those new D4’s are stunning! I put one in my shopping cart just to pretend I could afford one of those raw titanium ones. $100 for one of those really is a great deal for what you’d be getting. I’d love to see how much of a difference the copper head makes on those hot rockets. I just got a D1 (thanks bansuri) and it gets super hot. Makes sense though because it shines farther than any other light I’ve had the pleasure of using.
Got my 219c with 18350 tube. Running 30Q and vapcell 18360.
I both love it and feel frustrated at the same time. It repeatedly steps down at 100% 7135 level at room temperature of 22C / 72F. Even at lower output levels. This is starting with a cold light and the thermal reset to 65 degrees. Is this typical?
No, that’s not typical. It sounds like it either thinks the battery is low or its thermal sensor is way off. I haven’t heard of one being that far off before though. Being off by as much as 15 degrees would be normal, but 40+ is way out of spec. I’d double-check the batteries and make sure the parts are screwed together firmly.
In some newer firmware, the thermal floor is higher (about 150 lm), and the user can calibrate room temperature to avoid issues with hardware variations. So maybe that could be a solution too.
I pulled mine out of my backpack to find a crack down the middle of the glass, I must have dropped my bag on tiles or it landed awkwardly or something.
I work away from home for weeks at a time so dont have the ability to measire it, as it still works so I’m reluctant to open it up.
Any lens measurements or links to buy replacements greatly appreciated!
