Sorry, exaggerated for clarity. “Mini energy drink can” is more like it.
The LVP, higher PWM frequency, and reduced size of this one is hard to beat.
Don’t use aliexpress much so I’m loading up the cart.
Aliexpress is like ebay. Many stores under a common payment system. So you can buy a lot from a single store and it should ship together. If you buy from a lot of different stores, they will come from different locations and take different shipping times. Some stores are more reputable than others.
In case you didn’t know.
Last time I ordered about 6 items and every one of them require a signature, so a trip to the post office very time. Will try to avoid that this time.
Any idea if there’s room for a magnet in the tailcap?
Wonder if repeated removal from holder will make it lose its grip.
What? Every one of my orders got delivered to my mailbox. I’ve never had to sign for anything from AliExpress.
I guess you could add a thin magnet in the tail cap as long as you use a short battery. Also, it may not screw on enough to cover the O-ring.
The headband holder is rigid plastic so it shouldn’t get soft over time.
(this is a repost, I was in the RJ-02 topic)
I have finally try the latest boruit
I was pretty convince the first day…
only work when charging now… don’t know why……
anyone ever had the same fail as me?
headlamp working only when charging?
light is back, it was in something like a “backpack lock”, put pretty unusual to undo (still don’t know how I’ve done…)
So it’s working fine now?
Tighten the ring around the button more tightly.
Hmm . . . I wonder too. That would make for a nice added feature! I have one of those Convoy S2 type magnets I could check.
-Garry
It would need to be as thin as possible to fit inside the tail cap. I think the magnet you’re talkin about is the ring style which mounts on the outside of the tailcap. If you don’t mind a magnet on the outside then there are several different sizes to choose from.
Ah, ok. I haven’t even looked at the magnet next to a light to see how it mounted.
-Garry
nope, it has return in this “lock position ” few times, but I was able to return to normality, by randomly clicking, now it’s lock again……
already tight, thanks
How do you know it’s not a battery connection problem?
That seems much more likely than an undocumented lockout mode.
because I have “unlock it” several times without touching the battery/screwing, sometimes I see mild light flash, it’s maybe juste the board who fail… In fact I don”t know what it doesn’t work sometimes, and work the other, everything look fine
ok, so when I place a wire between the micro usb (exterior part is that the +?), and the aluminium body, the headlamp work, do you know where the electrical connection between the board, and the aluminium body should be? a bit of soldering will maybe the solution….
ok, so when I place a wire between the micro usb, and the aluminium body, the headlamp work, do you know where the electrical connection between the board, and the aluminium body should be? a bit a soldering will maybe the solution….
The only thing I can think of is unscrewing the driver retaining ring around the green button, look inside, then retighten. It is a reverse thread. Maybe this will make the driver get better contact.
If that doesn’t work I would have them replace it.
thank you, I tried it before, it didn’t work, now I retried with a better tool and it worked
:)… Glad to hear you fixed it .
I was happy with my soup can size R2’s …But now you guys had to show off your new headlamps huh ?I found a big rubberized magnet that had a peel and stick …double stuck it to the flat end of the R2 ( it looks like it was made for it.)
At $6-$7 I bought a handful and use a couple not as a headlamp but rather as an area light .Got one stuck to the range hood over the stove and another buried in an amateurish paracord jumble . I’ve been on a little bit of a headlamp buying spree and am ever so grateful that you guys make me have to buy yet another Boruit. The fact it has no nasty low PWM and is moddable makes this light very attractive …
Finally got a couple ordered, thanks for all the info and modding tips.
Had been looking for stuff to add to the order because the last time I ordered there was all kinds of cool stuff at great prices.
Haven’t been on aliexpress for a while and since joining BLF I’ve really gotten spoiled by the great deals offered in the forums, so just the headlamps.
