Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1289 posts / 0 new
beam0
beam0's picture
Last seen: 1 year 8 months ago
Thanks, that’s what I was thinking so the light could more usable.
I would compare the light to a Maglite, which I’ve seen modded with 3x xhp50 / 5000lm
https://asflashlights.com/led-upgrades-for-maglite/84-5000-lumen-2-d-siz...
But I also see it gets real hot, 225 degrees in 15min. http://budgetlightforum.com/comment/1307634#comment-1307634
Also there’s no 5050 16mm mcpcb with pads to mount the mosfet, so LD-B4HV can be used only with 20mm mcpcb, correct?
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
led4power
led4power's picture
Last seen: 4 hours 21 min ago
Yes, LD-B4(HV) can be used with 20mm boards, on 16mm there is not enough space for anything other than LED.
led4power
led4power's picture
Output test for OSRAM SFH 4715AS on CU MCPCB vs. mosX: http://budgetlightforum.com/node/60413
Lothar
Lothar's picture
Last seen: 2 days 10 hours ago
The_Driver wrote:
led4power wrote:
There are new OSRAM leds that should replace that led and black flat, so I think it’s a good idea to wait for tests.
Yes, definitely! A copper pcb for Osram 3030 LEDs make smore sense anyhow because it can be used for more types of LEDs (Osram Square, SSL etc.).
When can we expect to start seeing these LEDs?
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
The_Driver
The_Driver's picture
Last seen: 1 day 4 hours ago
Probably in the next 4-12 months, they are not in production yet.
led4power
led4power's picture
BLF Q8 4040/5050 copper DTP boards arrived:
I will send two to djozz to check if everything is ok.
Also, 20mm copper DTP 3535 board(70um copper,gold plated top,nickel plated bottom):
Price is: 1,17€/pc , I will list it on web tomorrow (contact for larger quantity discounts).
djozz
djozz's picture
Last seen: 47 min 12 sec ago
I can check the Q8 boards but I assume they are ok, they look good. I will check the Q8 board with Luxeon V’s, but I have only two left, could you send 2 Luxeon V leds with the boards? (I will pay for them).
I do not own SST40 leds but I can check the 5050 pads with XM-L2 leds if that is ok with you, for checking the function of the board that should be sufficient. If not I can order some SST40 leds but that will take a while.
contactcr
Last seen: 5 hours 30 min ago
exciting
vinte77
Last seen: 23 hours 22 min ago
Wow, that’s fast. I expected it that it would be a while before you had the Q8 boards ready. How soon can we expect the triple 4040 32mm boards?
led4power
led4power's picture
@djozz
I already packed 2 boards and 4 L1V1s. 5050 checking is not necessary, if 4040 are good, 5050 will be too.
led4power
led4power's picture
~3-4weeks,and not just triples.
vinte77
That’s some fast turnaround time. I guess I’ll be making another order in a month or so.
khas
Very nice looking MCPCB’s, looking forward to trying the Q8 with Luxeon V’s or one of my favorite the XM-L2 7A3 CRI90.
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 3 hours ago
@LED4Power, have you thought about doing Nichia 144AM MCPCBs?
I would love a 20mm Nichia 144AM MCPCB.
led4power
led4power's picture
I think BLF member clemence has those?
BlueSwordM
No, not a 20mm version yet.
led4power
led4power's picture
 I'm not sure about demand?
led4power
led4power's picture
Added new pcbs:
https://led4power.com/product-category/mcpcbs/copper-dtp/
Q8 pcb is out of stock until djozz checks if it's ok.
CRX
CRX's picture
Last seen: 5 hours 7 min ago
Nice.
led4power
led4power's picture
Also ordered one reel of Samsung LH351D 4000K 90CRI few days ago, they should be available in ~3 weeks.
giorgoskok
giorgoskok's picture
Nice ! I will get a good amount of them Smile
led4power
led4power's picture
I see in few BLF threads people expressed need for BLF GT XHP70 DTP MCPCB. I can make them,just like BLF Q8 PCB, is there bigger interest(100pcs+)?
If yes,I can make a batch, available in ~1month.
If there is any other interesting MCPCB, I can also consider it.
djozz
djozz's picture
As seen in his video, (at 1.45 minute) vestureofblood has used a prototype of such a board (with TA logo) in his XHP70.2 GT, the idea I think is that Lumintop at some point will come up with either a XHP70.2 GT or the loose board (and driver). There is no mention of a timeline for when things are happening but the question I guess is if there is a market for two sources for such a board. (perhaps you can contact Texas_Ace about what is going on) .
For me personally I’d be really happy if in a month or so there is a board ready, I have a driver and a led, I’m just waiting for a board now, and I’d be surprised if a Lumintop board will be ready a month from now.
Edit: Btw, I got the Q8 boards and leds in, just waiting for some time to swap them in a Q8 and check the fit and numbers.
djozz
djozz's picture
My family was gentle on me today and allowed some time to try the led4power Q8 board in a Q8. I posted it in the WDYMT thread. In short, it works fine and the Q8 with Luxeon V leds rocks!
lights_and _pieces
So I’m not up to date on the latest emitters, especially non cree emitters. There may be a better option coming soon. Seemed to be the case as I read some of the previous comments a day or two ago. I’m wondering however, if there would be enough interest in a 16mm board for the OSRAM black flat.
led4power
led4power's picture
djozz wrote:
My family was gentle on me today and allowed some time to try the led4power Q8 board in a Q8. I posted it in the "WDYMT thread":http://budgetlightforum.com/comment/1323811#comment-1323811. In short, it works fine and the Q8 with Luxeon V leds rocks!
Thanks djozz! That was quick, I sent boards 4 days ago.
I will update Q8 PCB listing today.
led4power
led4power's picture
I will make 16mm OSRAM mosX gen2 PCB (~4times lower thermal resistance compared to mosX), difference in output compared to copper DTP should be ~1.5 - 2% based on some calculations.
kiriba-ru
kiriba-ru's picture
Last seen: 1 day 11 hours ago
led4power wrote:
I will make 16mm OSRAM mosX gen2 PCB (~4times lower thermal resistance compared to mosX), difference in output compared to copper DTP should be ~1.5 – 2% based on some calculations.
Triple/quad? This is the only powerfull led that may help carclo 10mm optics work the way it was developed for.
led4power
led4power's picture
I have 3XP mosX, it should be good for testing.
led4power
led4power's picture
BLF Q8 boards in stock:
BLF Q8 4040/5050 DTP PCB
With soldered Luxeon V LEDs:
4x LUXEON V on BLF Q8 DTP PCB
I don't have washers+screws in stock yet, I hope I will have some in a few days.
DIY washer example by djozz:
http://budgetlightforum.com/comment/1289469#comment-1289469
From now on, shipping calculation is based on weight, over 50€ order registered shipping is available with 2€ discount included. Also, for heavy packages there is Premium packet option available for most EU countries, with good prices.
