FW3A, a TLF/BLF EDC flashlight - interest list closed, check your inbox for coupon code
11217 posts / 0 new
raccoon city
raccoon city's picture
Last seen: 51 min 54 sec ago
FW3A Team wrote:
Interest list updated.
- TK
I should be on the list for two, but am only on there for one.
http://budgetlightforum.com/comment/1245554#comment-1245554
http://budgetlightforum.com/comment/1308299#comment-1308299
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 33 min ago
Thanks. It’ll be in the next update.
At some point, I plan to have a script go through every post to train it to recognize requests, and in the process it’ll also add missing post numbers to the list and look for any requests which got missed. Then with the complete data set filled in, I can further tweak the engine to recognize things better.
Request numbers will change, since corrections will go in the order posted instead of the order noticed. It may also be useful to merge the TLF requests into the same list, in chronological order, in case there are any supply limitations (distinct batches) like there have been on some other projects. That will also change the request numbers.
DavidEF
DavidEF's picture
Last seen: 9 hours 32 min ago
…and you say all that as if it’s “just a thing”. LOL! Do you even know how lucky we are to have you here? Thanks for all you do around here, sincerely. Party
- The YKK Philosophy
pepinfaxera
Last seen: 1 day 16 hours ago
Review Post # 2129 Page 71 I see error. Missing numbers #870, #871 and #872.
I see in Post # 2128 Page 71 , that belong to:
pepinfaxera wrote:
Interest list : Post # 2128 Page 71
870 – # Post . raccoon city … Oh, what the heck… … Add me to the list as well.
871 – # Post . t3rminal … Please add me to the list for two lights
872 – # Post . t3rminal … .. “ …… “ …… “ …… “ …….. “
Edit Post # 2129 Page 71
I am sorry
EDIT:
Post # 2128 was eliminated by blocked.
Post # 2129 is now new #Post # 2128
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
candor
Last seen: 54 sec ago
Hear, hear!
Please put me on the list for a third. And many thanks to all involved.
JordanZHP
Last seen: 5 hours 25 min ago
Please put me down for 2, thanks!
Kingjohn
Kingjohn's picture
Last seen: 9 min 24 sec ago
Please put me in for a third one!
Hojobones
Last seen: 5 days 21 hours ago
Please sign me up for one! Thanks!
Athlon2350
Last seen: 5 hours 17 min ago
Please put me down for 3, thanks!.
ToyKeeper
ToyKeeper's picture
I took some time today to add the “votive candle” mode (candle mode timer). It’s off by default, meaning candle mode will go until it’s manually shut off or LVP activates… but the user can click 3 times to turn on the timer and add ~30 minutes. Click 3 times again to add another 30 minutes, and so on. The maximum time it can handle is about 4.5 hours.
For most of that time, it’ll run normally. However, for the final minute or so, it’ll gradually dim, sputter, and then shut off.
The UI diagram has been updated too.
cabfrank
Last seen: 1 hour 42 min ago
So cool!
MascaratumB
MascaratumB's picture
Last seen: 9 hours 56 min ago
I can’t wait to have this flashlight on my hands Blushing
(specially ‘cause I can’t flash Anduril on other lights)!
Thanks for all the work ToyKeeper Beer
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
GIVEAWAY - 1
DB Custom
DB Custom's picture
Last seen: 12 hours 52 min ago
I’m SO old fashioned, still have to blow out my candles the manual way…. Wink
whatthewillus
Last seen: 1 hour 43 min ago
I’m also interested. Please add me to the list. Thanks!
CrashOne
Last seen: 2 days 3 hours ago
What are the tolerances on the inner tube? If it touches the outer tube, the switch will not work I think? I was wondering how durable this solution is.
djozz
djozz's picture
Last seen: 28 min 37 sec ago
If both the inside of the outer tube and the outside of the inner tube are anodised it will be pretty hard to wear it out to the extend that it shorts, and if it does a bit of tape (i.e. Kapton tape is durable and pretty thin) around the inner tube should fix it.
Jesjes
Jesjes's picture
Last seen: 3 weeks 6 days ago
Servus,
please put me down for one
Jesjes 1
Thanks
DavidEF
DavidEF's picture
Yeah, if both the tubes are anodized, I don’t think it will ever wear through in normal use enough to short.
eas
eas's picture
Last seen: 1 month 4 days ago
Unless some grit accidentally finds its way in.
DavidEF
DavidEF's picture
Yeah. But I did say ‘normal use’. Wink
I don’t expect the tubes to ever move much in relation to each other in normal use. So, even with a piece of grit finding its way in, I don’t see how it could be a problem within the normal life expectancy of a flashlight. Or am I remembering something wrong about the design?
Yohan110
Last seen: 4 weeks 9 hours ago
Interested in one.
Firelight2
Firelight2's picture
Last seen: 3 hours 13 min ago
TK reported that she was getting odd behavior from her prototype sample until she inserted a piece of paper between the inner and outer tube.
Sounds to me like just anodizing between the two layers might not be enough. Maybe it would be better to redesign the tube to be 1mm thicker and then add a thin plastic tube between the 2 metal tubes. That’s how Liteflux did it in their LF2XT years ago, and it worked perfectly.
Tom Tom
Last seen: 1 month 4 weeks ago
I’m not worried about the inner and outer tube connecting, in general, a bit of Kapton tape would fix that if the anodising was weak, and maybe keep the inner tube aligned so it didn’t drift off towards the head and perhaps hit the wrong contact area.
It’s the little bit at the tail end, where the inner tube has a ridge to keep it in place, which in the cross-section, suggests rather fine tolerances, possibly less amenable to a simple fix, if the anodising fails there.
Edit: http://i.imgur.com/AVSmLGN.jpg
Edit2: The inner tube needs to float, so my speculative comments about wrapping with Kapton etc. are unlikely to work for everyone. Strong anodising and designed spacers are the way to go, if this is to be reliable for everyone.
ToyKeeper
ToyKeeper's picture
Thicker anodizing should be enough, but I wouldn’t be opposed to adding an actual spacer to keep the tubes apart. I think half the issues I’ve seen were caused by the inner tube getting knocked sideways during use. Or perhaps just caused by the weak spring. In any case, I want it to respond better to acceleration.
Hopefully there will be new prototypes soon… I’m getting impatient.
Tom Tom
Wouldn’t that be deceleration Wink
JasonWW
JasonWW's picture
Last seen: 35 min 21 sec ago
I was thinking impact g’s.
ToyKeeper
ToyKeeper's picture
The only difference between acceleration and deceleration is the observer’s inertial reference frame.
I’d say I want it to respond better to shock, but … that seemed a bit too vague. Shock can include surprising news, or even surprising nudes.
ToyKeeper
ToyKeeper's picture
One might even be shocked by surprising gnus… bewildered by a wildebeest.
Hey, it could happen. Especially if they were trained as ninjas.
JasonWW
JasonWW's picture
Perfectly clear to me.
zak.wilson
Last seen: 6 hours 1 min ago
Good thing it can’t sense light while also illuminating. That should substantially reduce the chances of it being shocked if you use it to surprise a nude.
Ceilingbounce – flashlight testing and runtime graphs for Android
