Thorfire TG06S Review
8 posts / 0 new
cellguy
cellguy's picture
Last seen: 11 months 3 weeks ago
A while back Thorfire contacted me via this forum and asked if I was willing to review both the TG06S and the TK18 if they provided them. Since the Q8 has been my favorite light since it arrived I immediately agreed.  I know there are a number of reviews out there on both lights so I won’t focus my effort on an enthusiast’s deep dive into the specs, showcasing beam shots or nitpicking tint. Instead I will look at the performance of the TG06S as an overall value proposition in a very crowded market place.  Thorfire made no request regarding the style or tone of my review in any way. First up is the TG06S.
TG06S Kit, MRSP: $24.80
  • Cree XPG2 –R5 LED; 500 Max Lumens on High
  • 1 Lumen Moonlight Mode and 500 Lumen Hidden Strobe Modes
  • Requires Single 14500 Battery (included) or 1.5/1.2v AA (not included)
  • .75A Micro USB charger (5v power supply is required but not included)
INITIAL THOUGHTS:
Operation:
The UI is simple and intuitive.  A half press of the switch moves you through H-M-L-MOON. Light will always start on high.  A double press activates the strobe.
Build:
The build quality is above average. The switch is crisp with a satisfying travel and click. The knurling could be more pronounced. The finish on my review unit was flawless.
Performance:
Overall I rate the performance as acceptable. On high, the light will noticeably step down after approximately 3 minutes. I do not have a way to measure it but I am guessing it goes from 500 lumens to around 300 lumens. This is based on it still being brighter than the 200 lumen setting. I also feel like the moonlight mode is somewhat crippled. Since the TG06 has no memory you have cycle down to that mode each time making it less useful in certain situations.
Charger:
Thorfire states:  “Battery charger has over charging protection, short circuit protection and reverse connect protection.”  These are great safety features, but I am quite finicky about my battery chargers and do not plan to put this unit into service.
Battery:
I have read good anecdotal reviews of Thorfire brand batteries and in my limited use of the included 14500 cell, I would tend to agree this is a adequate choice to power the light. I do recommend the use of a Li-Ion cell with the TG06S as its performance is severally throttled with an alkaline battery. In a quick test, leaving the light on high, it was still running strong after 1 hour. This is another indication to me that the light runs around 300 lumens after step down. The rated run of 35 minutes on high (500 lumens) was completely inaccurate with my unit but the 1h15m runtime on medium (200 lumens) appears to be perfectly plausible.
WOULD I BUY IT?
I have spent my own money to purchase the TG06S (the review unit is my second unit). It is fantastic budget flashlight and I would be surprised if there is a better value available right now. Personally, I would pass on the kit due to the unknown quality of the charger and purchase just the flashlight. After coupon, it is available for $13.50 on Amazon with two day Prime shipping. The TG06S has been a pleasure to use and carry and I do not believe you will regret adding it to your collection.
Current Favorites:
BLF Q8, Thrunite TC20, Convoy L6
Edited by: cellguy on 05/08/2018 - 12:57
TShoot
Last seen: 1 year 8 months ago
I received mine today and compared it to my Utorch UT01. Used the same model battery (both new and freshly charged EBL INR 14500 800mAh 3.7 V Li-ion batteries) in each flashlight.
The Thor TG06S is taller by about 1/4" and approximately the same width
Pocket clip on the Utorch UT01 allows for a flush fit pocket carry while the Thor TG06S pocket clip leaves about 1" sticking above the pocket.
I did beam shot comparisons for both. Both were close enough that I didn't see that much of a difference for the distance I use them.
They one thing that REALLY bothered me about the TG06S was how hot it kept getting in the "high" mode and how little time it took to get there. The UT01 was still cool to my hand way after the TG06S was a very good hand warmer. That concerned me about overall longevity.
So, how fast it got hot, the inferior pocket clip, the extra length and the lower build quality has me returning the Thor TG06S to Amazon the same day I received it.
I really wanted to like it because it was $13 dollars cheaper then the Manker E11 (Utorch UT01 equivalent) on Amazon but I didn't think it would be reliable long term.
I did like the fact that it has a tailswitch, albeit a bit mushy vs. the Utorch UT01 side switch that has no lockout. But, between the two, I would pick the Utorch UT01/Maker E11 over the Thor TG06S any day.
But, it is still probably a great flashlight for the price, support for 14500 battery and decent lumens - just not for me.
Friends help you move. REAL friends help you move the bodies.
BlueSwordM
BlueSwordM's picture
Last seen: 14 min 21 sec ago
Uhh why do so many good budget AA lights have to have high as a starting brightness in their UI? Makes the light much less attractive.
TShoot
Forgot that one. Not fun if you are trying to walk around in a room that everyone is sleeping and the first setting is high and it doesn't remember the last setting.
cellguy
cellguy's picture
I agree, it’s a miss for an otherwise attractive light. Starting on high plus no memory really cripples moonlight mode. Perhaps the TG06S+ can remedy it! Wink
Current Favorites:
cellguy
cellguy's picture
@TShoot I wonder if you have a driver issue. I did not mention it in my review but mine ran cool throughout. It really never heated up even after multiple turbo cycles. The Utorch UT01 looks like a nice light but at 75% more expensive, it certainly loses the value proposition.
Current Favorites:
Lightbringer
Lightbringer's picture
Last seen: 27 min 12 sec ago
TShoot wrote:
They one thing that REALLY bothered me about the TG06S was how hot it kept getting in the “high” mode and how little time it took to get there. The UT01 was still cool to my hand way after the TG06S was a very good hand warmer. That concerned me about overall longevity.
Ummm, that’s actually a good thing. You want heat to escape from the LED to the case and to the outside world.
Those lights that “stay cool to the touch” are bottling up all the heat to the poor little screaming LED.
That will kill longevity for sure.
Lightbringer
TK05? Really nice little critter, I got a few of them.
L→H, with memory. 600 lemons with a 14500, half with with AA.
