^THIS^ +1,000,000……infinitum…. Aging hands are definitely a factor. Burning, Stinging, pangs that can shoot from hand/wrist/finger joints to the bowels of hell in a split second. I have both configurations of switches…side switches eliminate the pain though…. Getting older can suck …. :disappointed:
Just because a switch is on the side does not mean it needs to be an e-switch.
This topic is not about e switches vs physical switches, it is about tail vs side.
Also if the light is designed well then it takes the same amount of time to find a side switch as it does a tail switch, assuming you have working nerves in your fingers.
I actually really like both types, depending on how they are implemented. There is no guarantee you won’t have problems with either kind of switch…but electronic switches should be less likely to fail, if they are made properly. Clickies wear out, no matter what.
I’m a fan of the side switch. They mean small lights. which I am a fan of. Plus, they can be used in many positions with various fingers and I find that useful. Generally, a tailcap switch is a thumb only operation.
Depends on application, key ring for me has to be twisty, side switch for general uses. I find side switch more comfortable , the switch is just there when using it. Not always easy to find though when dark and quickly grabbing. Rear clicky for me is more suited when holding the flashlight at head height(side clicky for waste height). I like all types of UI, all have pro/cons depending on use. I would say most of my uses are more toward side clicky overall……
More secure and comfortable grip than a tailcap switch.
A well designed sideswitch won’t turn on accidentally in the pocket even when lockout is not used. Example: Zebralights, Eagtac DX3b mini.
A well designed sideswtich can be easier and faster to find in the pocket than a tailcap switch - example: Zebralight SC64w… switch is deeply recessed inside a cavity that funnels the finger onto the button.
Most sideswitches are e-switches which allow a more natural and intuitive UI than mechanical clicky switches. They’re also much quieter.
More compact … always a good thing for a pocket EDC.
