Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
New Arrival :
TANK007 TK737 Rechargeable Focusing Strong Flashlight
https://www.gearbest.com/led-flashlights/pp_1219885.html?wid=1433363
Ultra high performance Cree LED provides Shock-Proof dependable light
80,000 hour LED life
High power flashlight with zoom function
Could focus the light with twisting
Twist precisely
Five output levels available
Automatic memory function, remember last used setting will come on at same level as when turn off
Waterproof to IPX6 standard
The price for Tank flashlight is expensive.
I remember years ago their quality is same as Ultrafire, uranusFire and many other XXXXfire brands.
Their design still look like low end Ultrafire lights and they’re charging big dollars :zipper_mouth_face:
Thank you for your feedback, we have submitted these information to our related colleague. :wink:
May 11th 2018 update:
MHVAST TS50 XHP 50.2 LED High Power Flashlight
https://www.gearbest.com/led-flashlights/pp_1830727.html?wid=1433363
Features:
● High efficiency constant current circuit and constant current output
● Premium type III hard-anodized anti-abrasive finish
● Humanized side switch function, one button to open or close the flashlight
● Stainless steel frame, ergonomic handle with anti-roll design
● High performance aluminum peel orange reflector
● Ultra-clear glass lens tempered with a violet anti-reflective coating
Specifications:
● Emitter Type: XHP 50.2
● Material: aluminum alloy
● Battery: 3 x 18650 Li-ion battery ( not included )
● Lumen: 2920 Lumens
● Operating voltage: 8.4 - 12.6V DC
1.1800LM 7xT6 USB Rechargeable 18650 LED Headlight
https://www.gearbest.com/headlights/pp_1836402.html?wid=1433363
Main Emitters: XM-L T6
Emitters Quantity: 7
Luminous Flux: 1800lm
Color Temperature: 6000-6500k
Battery Included or Not: No
Beam Distance: 400-500m
Body Material: Aluminium Alloy
2.MHVAST H10 Cree XM - L2 U2 LED Head Lamp - BLACK 3000-3500K 26
https://www.gearbest.com/headlights/pp_1830735.html?wid=1433363
Features:
● CREE new XM - L2 U2 LED with a lifespan of up to 50,000 hours
● Maximum output 560 lumens
● Working Voltage: 2.7V - 6V DC
● High efficient constand current circuit and output-luminance
● Durable, custom-designed micro controller drive circuit
● Side switch and mode changing infinitely variable brightness side switch
● High performance aluminum OP reflector for far throw
● Compatible Battery: 1 x 18650 battery
● Waterproof: IPX-8 standard
Convoy C8+ XPL HI LED 1100LM Portable Flashlight - DESERT SAND
https://www.gearbest.com/led-flashlights/pp_1845626.html?wid=1433363
Main Features:
● Unique design
Deep diamond knurling, u-shape tail, it is non-slip, waterproof, and abrasion resistance.
● Eight lighting modes
0.1 percent brightness, 1 percent brightness, 10 percent brightness, 35 percent brightness, 100 percent brightness, strobe, biking and battery-check, so many brightness options are convenient for us.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable
● Widely application
It is suitable for camping, fishing, hunting, hiking, searching, working
● Powered by 1 x 18650 rechargeable battery ( battery is not included )
● Light source: XPL HI beads
● Input: 4.2V
1.HKV Flashlight Distress Signal Emergency SOS Red Flash Warning Lamp
https://www.gearbest.com/led-flashlights/pp_1844217.html?wid=1433363
Lumens Range: 200-500Lumens
Color Temperature: 6000 - 6500K (Cool White), 640 - 780nm( Red )
Feature: Waterproof,Rechargeable
Light Modes: Strobe,Red beacon
Mode: 3(Low - High - Strobe)
Battery Included or Not: Yes
Zooming Function: Yes
Rechargeable: Yes
LED Lifespan: >10000
2.MHVAST TG20 USB LED Dual Mode Flashlight
https://www.gearbest.com/led-flashlights/pp_1830730.html?wid=1433363
Specifications:
● Emitter Type: XPL V6
● Mode: high, medium, low, ECO; strobe, SOS, beacon
● Battery Configurations: 1 x 18650 or 2 x CR123 Li-ion Battery ( not included )
● Lumens Range: 235M
● Waterproof: IPX 8
● Charge: micro USB charging
Features:
● Equipped with high efficiency smart constantly current driver.
● Free Change modes from tactical to memory.
● Hardened ultra-clear glass lens with an anti-reflective violet coating.
3.XM-L T6 LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1836395.html?wid=1433363
Flashlight size: Mid size
Lumens Range: >3000 Lumens
Feature: Waterproof,Cool,Strong
Power Source: Battery,Battery
Battery Quantity: 4
1.Yeelight Pro Smart LED Eye-care Desk Lamp
https://www.gearbest.com/table-lamps/pp_1842996.html?wid=1433363
Specifications:
● Power: 15W
● Input Voltage: 100 - 240V
● Working Voltage: 12V, 1.5A
● Color Temperature: 4000K
● LED Quantity: 88pcs
● Luminous Flux: 650lm
● Adjust Angle: 60 degree up to 90 degree down
Main Features:
● A uniquely-crafted look with durable build that fits simply everywhere.
● Choose favorite color temperature and brightness level for studying, relaxing or sleeping.
●Energy-efficient LED lamp emits non-ghosting and non-flickering lighting for eye protection.
● The stand can be adjusted for better visibility.
2.Xiaomi FZ101 Portable Zoom Flashlight
https://www.gearbest.com/led-flashlights/pp_1846889.html?wid=1433363
Specifications:
● Model: FZ101
● Interface: USB Type-C
● Battery Capacity: 2600mAh
Main Features:
● Lightweight Mini Design:
With its mini size, it is portable for you to bring it outside. The body is made of premium aluminum alloy with strong and sturdy design.
● 672 Lumens Brightness:
The max brightness is 672 lumens, meeting your needs of night camping, running, observation or exploration perfectly.
● 2600mAh Large Capacity Battery:
Comes with a 2600mAh large capacity battery, bringing you a brightness endurance for 2375mins.
3.PHILIPS LED Desk Light Stand Table Lamp
https://www.gearbest.com/table-lamps/pp_1847296.html?wid=1433363
Main Features:
● Energy saving; built-in LED, as part of the system
● Energy efficient; energy saving, compared to traditional light sources
● Advanced LED light; adjustable light intensity with dimmer switch
● Bright cool white light; Philips LED desk light stand with suitable color temperature
● Philips LED desk light stand with minimize the light that is reflected from the surface
● Excellent heat dissipation; there is no risk of burns
Xiaomi included a pre-collimator? Nice!
Dear Agro,
There is not including a pre-collimator.
1.JETBeam BR10GT LED Rechargeable Bike Light
https://www.gearbest.com/led-flashlights/pp_1848493.html?wid=1433363
Main Features:
● Unique design, compatible with multiple platforms: bicycle, handheld, rail mount and many more
● Rechargeable by USB port with water-resistant rubber cover
● Maximum output of 1100 lumen reach out to 230 meters
● Digital stitch constant circuit control. Up to 14 hours of runtime
●Battery Included or Not: Yes
2.ZHISHUNJIA 3-Mode XM-L2 White Light Flashlight / IPX8 100m Diving Depth
https://www.gearbest.com/led-flashlights/pp_1847019.html?wid=1433363
Feature: Waterproof,Diving,Charging indicator,Adjustable brightness,Power Indicator,Side Switch
Photographing,EDC,Rescue,Search
Battery Quantity: built-in 5400 mAh lithium-ion battery
Rechargeable: Yes
3.Folomov CAMP D4 Flashlight Campact and Portable Outdoor Torch 1080 Lumens
https://www.gearbest.com/led-flashlights/pp_1847023.html?wid=1433363
Flashlight size: EDC
Emitters: Cree XP-L V6
Emitters Quantity: 1
Luminous Intensity: 1080 Lumens
Feature: Waterproof,Lightweight,Portable,Popular,Adjustable brightness,Water Resistant,Pocket Clip,Anti-Roll Rugged Design,Lanyard,Integrated Heat Dissipation Design,Strong
Mode: 4(High - Mid - Low - SOS)
Rechargeable: No
Waterproof Standard: IPX-8 Standard Waterproof
On the picture we can see that the light uses 2 lenses. In this rare setup we call the one closer to the LED a pre-collimator.
1.ROFIS R2 700LM Tail Magnetic USB Rechargeable Flashlight
https://www.gearbest.com/led-flashlights/pp_1853796.html?wid=1433363
Main Features:
● Adjustable angle head
Flashlight head and body can be adjusted from 0 - 90 degrees. It is very convenient and practical.
● Indicator reminder
It has charging indicator, power detection, low battery reminder, active temperature control circuit, etc.
● Five lighting modes
700lm in extreme light, lighting time ( 330lm after 3 minutes ), 300lm in highlight, 98 minutes in lighting, 90lm in mid light, and 253 minutes in lighting; low profile 5lm, lighting time 43 hours; moonlight 0.5lm, lighting time 125 hours.
● Uses a 14500 800mAh lithium-ion battery
● Compatible with alkaline AA batteries and Ni-MH AA batteries
● IPX 8 ( 2 meters underwater ) waterproof, 1.5 meters drop-proof
ROFIS R3 Multifunction Bright Flashlight
https://www.gearbest.com/led-flashlights/pp_1849552.html?wid=1433363
Main Features:
● Magnetic tail cap
The powerful magnetic tail cap can be attached to the metal object, combining with head rotation, which enriches its usage scenarios.
It can be used as a headlamp, flashlight and so on.
● Uses a 18650 3400mAh lithium-ion battery
Features:
Introductions:
● Press the side switch to turn the flashlight on / off ( High mode comes on first ).
● With the flashlight on, press and hold the side switch to ramp through the infinite variable brightness system. When the desired mode is reached, release the switch to memorize the mode.
● With the flashlight on, double click the side switch to access the hidden strobe mode. Double click again to access SOS mode.
ON THE ROAD MX3-HL USB Charging LED Head Lamp (Exclude Battery Pack)
https://www.gearbest.com/headlights/pp_1687029.html?wid=1433363
Main Features:
1.Mini type
2.Light weight
3.Smart Temperature Control in Real-time
Using Methods:
1.Wire Control Switch, double click and direct access to Turbo.
2.Triple - click, and direct access to Strobe.
3.Wire Control Switch is optional, some products have no wire control.
No wire control need to press the switch to activate Turbo and Strobe.
SKILHUNT M200 USB Compact EDC Flashlight - NATURAL WHITE 4500 - 5000K
https://www.gearbest.com/led-flashlights/pp_009560930996.html?wid=1433363
Main Features:
● Unique design
Unique compact design, it is non-slip, waterproof, and abrasion resistance.
● Brightness level
Press side switch to low, mid, high, turbo, cycle.
● Super bright and latest CREE XP - L LED, max 1200lm, high-performance, high-efficiency, and energy conservation
● Built-in magnetic charging system, fast charge and convenient
● Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
● Low-voltage prompts function
The light will flash when the battery is low, remind the user to replace the battery on time.
● Powered by 1 x 18650, 2 x CR123A, 2 x RCR123A ( battery is not included )
● Voltage: 2.7 - 8.4V
Waterproof rate: IPX - 8
Main Features:
● Springs at both ends mitigate shock for increased reliability
Emitters: Cree XML-T6
Emitters Quantity: 12
Battery Quantity: 4
Specifications:
● Lumens: 1250 Lumens
● Waterproof: IPX 8
● Input Voltage: 2.7 - 6V DC
1. Jetbeam TH15 Tactical Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009530129764.html?wid=1433363
Main Features:
● Unique triple tail switches ( JETBeam’s patent ) and a side switch design
Using triple tail switches and a side switch design, it is convenient for us.
● Seven lighting modes
Very bright, bright, medium light, low and medium light, low light, energy saving, flashing, so many brightness options are convenient for us.
● Powered by 1 x 18650 2600mAh rechargeable lithium-ion battery
● Waterproof rating: IPX - 8 ( 2 meters underwater )
● Voltage: 5V
Irradiation distance: 228m
2.Nitecore LR12 1000lm Flashlight Camping Light
https://www.gearbest.com/led-flashlights/pp_009307968687.html?wid=1433363
Main Features:
● Unique design
Tail cover rotary switch design, it is non-slip, waterproof, and abrasion resistance.
Signal light, low light, medium light, high light, extremely bright, so many brightness options are convenient for us.
● Light source: CREE XP - L HD V6 beads
● Voltage: 3.7V
Irradiation distance: 200m
3.Nitecore MT21C Tail Magnetic Flashlight
https://www.gearbest.com/led-flashlights/pp_009877396626.html?wid=1433363
Main Features:
● Aluminum material
Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● lighting modes
Extremely high light, high light, medium light, low light, energy-saving gear, flash, SOS, beacon light, so many brightness options are convenient for us.
● Voltage: 3.7V
4.Nitecore GEM10UV Stepless Dimmable Flashlight
https://www.gearbest.com/led-flashlights/pp_009998598739.html?wid=1433363
Main Features:
● Aluminum material
● 3000mW UV light
It is suitable for identification jewelry and so on.
● Powered by 1 x 18650 rechargeable battery ( not included )
● Voltage: 3.7V
Jetbeam WL - S4 - GT Searchlight LED Flashlight
https://www.gearbest.com/led-flashlights/pp_009241569169.html?wid=1433363
Main Features:
● Aluminum alloy material
Using aluminum alloy material, it is non-slip, waterproof, and abrasion resistance.
● Button switch
● Six lighting modes
Extremely low light, high light, medium light, low light, flash, SOS, so many brightness options are convenient for us.
● Powered by 4 x CR123A or 2 x 18650 battery ( not included )
● Light source: CREE XHP70 beads
● Voltage: 5V
Irradiation distance: 400m
Charging time: 4h
Head diameter: 63mm
Body diameter: 26mm
Length: 243mm
New Arrival June 27th
1.Convoy S9 XML2 Direct Charge Side Switch Flashlight - BLACK 6000 - 6500K
https://www.gearbest.com/led-flashlights/pp_009210413813.html?wid=1433363
Main Features:
● Side switch
● lighting modes
When the flashlight is off, press and hold the button to start the moonlight file 0.1 percent.
When the flashlight is off, click the button, you can turn on the gear after the last flashlight was turned off ( the gear is 0.1 percent moon - 3 percent low - 30percent mid - 100 percent high, double-click strobe flash )
When the flashlight is turned on, long press the button, you can turn off the flashlight.
● Powered by 1 x 18650 battery ( battery is not included )
● Light source: CREE XML2 beads
● Voltage: 4.2V
Waterproof rate: IPX - 6
2.Convoy C8+ XPL HI Portable LED Flashlight - BLACK 4000-5000K
https://www.gearbest.com/led-flashlights/pp_009317032402.html?wid=1433363
Main Features:
● Tail switch
● 12 groups of 55 modes
● Light source: CREE XPL HI beads
● Voltage: 4.2V
3.TANK007 TK360 - 1 R5 Outdoor Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009441545082.html?wid=1433363
Main Features:
● Aluminum material
● Tail button switch
● One mode
● Powered by 1 x CR123 or 1 x 16340 battery ( battery is not included )
● Light source: CREE XP - G2 beads
● Voltage: 0.8 - 4.2V
4.Outdoor Lighting Multifunctional Aluminum Alloy Charging LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009309728890.html?wid=1433363
Main Features:
● Aluminum material
● One mode
5.Convoy M2 Portable LED Flashlight - BLACK 6000 - 6500K
https://www.gearbest.com/led-flashlights/pp_009917547179.html?wid=1433363
Main Features:
● Unique design
Simple design, it is non-slip, waterproof, and abrasion resistance.
● Light source: XML2 beads
● Voltage: 4.2V
Yippie! I was waiting verry long for the next XR-E Flashlight! :smiley:
