petemer
(petemer)
May 10, 2018, 10:13pm
1056
Nitecore LR30 High CRI LED White/Red 205LM Portable Camping Light Flashlight
Use coupon code 30NTLR for 20% discount ($27.96 / -$6.99 at the moment).
6x White High CRI LEDS + RED LED
1x18650 or 2xCr123/16340 li-ion
3 constant white modes + hidden RED modes: constant, SOS and blinking
magnetic base
20m(~22yd) illumination range in high mode
blue LED voltage indicator accurate to 0.1V
impact resistant polycarbonate construction
waterproof according to IPX6
» Jump to First post quick links/deals list «
petemer
(petemer)
May 14, 2018, 2:23pm
1057
ThorFire TK05 XP-G3 600Lumens 4Modes Dimming EDC LED Flashlight
Coupon code with nice discount is available.
» Request via PM here«
Cree Xp-G3 LED
powered by 14500 battery
max 600lm
4 modes (3 constant + hidden Strobe)
petemer
(petemer)
May 14, 2018, 8:23pm
1058
petemer
(petemer)
May 14, 2018, 8:10pm
1059
ThorFire TK18 XP-L2 1200LM Stepless & Mode-Dimming Memory Function Tactical LED UI Flashlight
Coupon code with sizeable discount is available.
Cree XP-L2 LED NW (5350-5500K)
dual switch (rubber taillick + side e-switch)
LED charge indicator in side switch
18650 or or 2x CR123A battery powered
max 1200 lm
3lm low
2 UI modes: 5 predefined modes (4 constant + hidden bike strobe) or continuous ramping 3-1200lm
momentary on function
petemer
(petemer)
May 14, 2018, 8:22pm
1060
SET | ThorFire TK18 XP-L2 1200LM Stepless Dimming Tactical UI Flashlight with 18650/USB Cable/Charger
max 1200 lm
3lm low
3000mAh battery, charger and cable included
petemer
(petemer)
May 18, 2018, 1:38pm
1061
petemer
(petemer)
May 16, 2018, 5:20pm
1062
petemer
(petemer)
May 16, 2018, 5:39pm
1063
petemer
(petemer)
May 17, 2018, 6:58pm
1064
Xiaomi Mi Note 3 5.5 Inch Facial-Recognition 6GB RAM 64GB ROM Snapdragon 660 Octa Core 4G Smartphone
Use coupon code 5BGNOTE3 for massive $63.00 discount - price drops to only $286.99
6GB LPDDR4 1866MHz RAM
64GB UFS ROM
5,5” Full HD IPS screen
3500mAh battery
under-glass fingerprint sensor
3D curved glass body
metal frame
USB-C with QuickCharge 3.0
dual 12 Mpix rear camera with optical zoom and 4 axis optical image stabilisation
16 Mpix front camera
NFC
petemer
(petemer)
May 18, 2018, 12:29pm
1065
petemer
(petemer)
May 18, 2018, 12:38pm
1066
petemer
(petemer)
May 18, 2018, 12:47pm
1067
petemer
(petemer)
May 18, 2018, 1:34pm
1068
LightFe MK62 XP-G2 S3 280LM 3Modes 180° Adjustable Head USB Rechargeable Mini Keychain Light EDC Flashlight
Coupon code with additional discount is available.
Unique 180 degree rotary head
Cree XP-G2 S3
3 colors: black, red, golden/yellow
3 mode groups:
high/medium/low
strobe/SOS/beacon
red -green alternative flashing (additional LEDs on both sides of button )
looks moddable (easy to open: side screws + head screws)
petemer
(petemer)
May 18, 2018, 1:43pm
1069
petemer
(petemer)
May 18, 2018, 1:55pm
1070
ZozzV6
(ZozzV6)
May 18, 2018, 5:04pm
1071
Hi petemer! Can you ask some coupon code for Eagle Eye X2R 3C led version?
Thank you!
beam0
(beam0)
May 20, 2018, 10:18pm
1072
I like these new Sunwayman lights,
looks like a good UI:
Activation of the light:
A quick depress of the switch at the top to turn the light on; hold the switch the light will cycle through Low-Mid-High-Turbo. Last mode memorized.
Hidden Modes:
A quick double-click will activate Strobe and another quick double-click under Strobe will enter SOS.
(I assume it’s single click to turn it off)
Interesting they are using XM-L2 when most new lights are using XP-L / XP-L2.
The smaller one’s about the same size an a Nitecore MH20GT
Pretty cool “wave” knurling.
petemer
(petemer)
May 21, 2018, 11:10am
1073
CRELANT V5CS XM-L2 18650 960LM Camping LED Flashlight
Use coupon code d5e70b for additional discount to get final price of $23.99
3C and 5C tints in stock (7C is under restocking)
dual switch design: side e-click + tactical tail switch
High, Low, Strobe, SOS, Stepless dimming (5–100) with memory function
petemer
(petemer)
May 21, 2018, 11:15am
1074
petemer
(petemer)
May 21, 2018, 12:20pm
1075
