Versus using only thermal paste, what does reflowing the mcpcb to the pill result in? Better heat dissipation?
I had thought about the SST40 but wasn’t sure I’d be okay with the tint since I’m pretty firm on neutral tints only, and everyone seems to comment on how cold/bluish it is, interestingly just today I received my first SST40 light! (Jetbeam E20R). I wasn’t able to get outside with it tonight but inside it’s not too horrible, I don’t see any bluish tint at all, even on white walls, it looks very yellowish to me, with a hint of green.
I also plan to get the C8+ tan host version and run a MTN-17DDm so maybe the SST40 for it as well. I see Richard offers the Slice LED option, how’s the tint on it after slicing?
The SST-40 doesn’t exhibit the tint shift we’re used to seeing from Cree, it does drop some but not like the XM-L2’s. I’ve found the 40 to have a nice creamy color once the dome is taken off. Richard seals them though, so it’s a bit different than a naked die.
Gnude Gnu’s haven’t been legalized for power use to date, not in the US anyway. Testing is underway to put them to work under AR confinement but the results are not in… Gnarly Gnude Gnu’s will be next. Mark my words.
Still though, it’s true, the XM-L2 U4 with a clean de-dome on it throws further and burns less current than a pushed XP-L HI, MaxToch found that out in the Shooter 2X.
The Convoy store also claims “about 1100 lumens”, so it might be true. The output current is listed at 3000mA, which is higher than the previous Convoys that use 8x7135. So, it looks like they’re using a better driver.
If I had to guess, I’d say probably closer to 1000 lumens, but I wouldn’t rule out 1100.
Pretty sure the driver is made up consisting of 8x380mA 7135 chips, making it effectively a QLite (3.04A) So actual output depends greatly on the emitter choice you make when you order the light. A 1A tint will be higher than a 4C, for example. Just how it is. Relatively simple to stack a few chips for more power.
Where are you referring to that it says this? I haven’t seen that info anywhere. As far as I know this is still the 2.8A driver and would not be putting out 1100 lumens. Am I missing something? I can see BG listing 1100 lumens but I don’t see anything like this in the Convoy store.
