[REVIEW] MiBoxer C4-12 (NiMH/NiCd/Li-ion Smart Battery Charger)
44 posts / 0 new
SoCalTiger
SoCalTiger's picture
Last seen: 2 months 2 days ago
The MiBoxer C4-12 is MiBoxers's newest lithium-ion battery charger. The MiBoxer C4-12 is a 4 bay high-current smart charger which can charge up to 4 Li-Ion batteries at 3A per slot (12A total). The C4-12 is great for anyone who needs to charge multiple cells at high current simultaneously.
I was provided a copy for review by MiBoxer (Amazon US stock).
Official Product Specifications
Parameters:
Weight: 485g
Material: Fireproofing PC+ABS
Color: Black
Input Voltage /Current: DC12V 5A
Output Voltage: 4.2V±0.1%/1.48V±0.1%
Output Current: Li-ion maximum 4*3A /Ni-MH/Ni-Cd maximum4*1A
Apply to:
Li-ion(4.2V) (IMR/INR/ICR) 10340 / 10350 / 10440 / 10500 / 12340 / 12500 / 12650 / 13450 / 13500 / 13650 / 14350 / 14430 / 14500 / 14650 / 16500 / 16340(RCR123) / 16650 / 17350 / 17500 / 17650 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 20700 / 21700 / 22500 / 22650 / 25500 / 26500 / 26650 Ni-MH / Ni-Cd(1.48V):AAAA / AAA / AA / A / SC / C / D
Package information:
Package include:
1*C4-12 Battery Charger
1*Adapter( 12V 5A)
1*User Manual
Adapter information:
Input Voltage: 100-240V
Output Voltage: 12V
Output Current: 5A
Material: PC
Advantage:
Super Fast Charger 3A for each slot, total 12A; four slots charging independently with a power bank function.
Attention:
Only 4th slot have the usb output function, and only for li-ion battery. It can’t charge for LifePO4 and 4.35V li-ion battery.
Packaging and Contents
1 x Battery Charger
1 x Power Adapter
1 x Manual
Included wall adapter outputs 12V 5A.
Fit and Finish
The MiBoxer C4-12 is made out of ABS plastic and has a mild "texture" which gives the appearance of a subtle sheen as well as helping to reduce the visibility of finger prints.
Size-wise, this charger is significantly bigger than the Opus, Littokala Lii-500, Xtar VC4 and Nitecore D4 among others. It is even wider and more spacious than the Zanflare C4.
All 4 slots are evenly spaced, which helps make it easier to insert/remove batteries from the center slots. When charging 4x18650 batteries, the spacing is perfect and it is relatively easy to insert all 4 cells. However, care must always be taken to make sure that you don't accidentally knock out an adjacent cell when inserting or removing multiple batteries.
Size is approximately 4.5"x6" (12cm x 16cm)
OCD ALERT: The plug from the wall to the adapter does not seat all the way in. No impact on functionality.
User Interface and Modes
Operation:
* When multiple batteries are inserted, press button to cycle display between slots.
* When batteries are inserted, long-press button to enter current selection mode. Once in current selection mode, press button to cycle through the charge current options. The range is from 0.1A (100mA) to 3A. After you cycle past 3A, there is also an "Auto" which will determine the appropriate charge current automatically. When using 18650GAs, it determined that the best charge rate was between 1.3A - 1.7A.
0.10A
3A
Display - Always Displayed:
The display automatically cycles through stats for the selected slot.
* Temperature
* % Capacity
* Time - Cumulative charge/analysis time
* mAh - Cumulative charge
Display - Rotating Display (Top Right):
* V - Voltage
* mA - Charge Current
* mR - Internal Resistance
Voltage
Charge Current
Internal Resistance
Battery Chemistries Supported:
* NiMH and NiCd
* Lithium-ion (4.2V ICR, INR, IMR, etc.)
x Lithium Iron Phosphate (LiFePo) Not Supported
Battery Sizes:
* 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650, 16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22500, 22650, 25500, 26500, 26650, AAAAA, AAAA, C, SC, D
* Protected 18650s Fit. The Protected Panasonic NCR18650GAs fit at about 69-70mm.
* You can charge 4x26650 simultaneously.
Power Bank:
With 1x18650 battery, and main power disconnected, the unit can output 5V 1A via the USB port. The battery has to be inserted in the 4th bay and only the 4th bay will provide power.
Wish List / Recommendations
1) Quick Test - I wish that this charger also had a drain and test function to determine capacity for all 4 bays.
2) Storage Mode - I wish that this charger had the ability to automatically drain or charge to 50% for storage.
3) LEDs - I wish that each bay had an illuminated color LED (Green=Done, Red=Charging, Flashing Red=Error) This would make it easier to tell if charging/analysis is complete from a distance.
Summary and Conclusion
Overall, the MiBoxer C4-12 is a good smart charger. It works well, especially for people looking to charge their cells quickly and it also looks very nice. My favorite aspect of this charger is all of the information available on the display. For example, I like that it shows both capacity in percentage as well as the voltage. I also like that this charger displays cell temperature which is something most chargers do not do. You can charge cells at up to 3A but make sure that your cells are able to support that much current first.
Since this charger can also support charging NiMH and NiCd and it is straight-forward to use, it is a good universal/family charger. It can also fit protected cells and the bays and nice and spacious. This is one of the few chargers which can fit 4x26650. When charging 18650s, there is a nice amount of space in-between each cell. You can even charge C and D cells, which is also rare. It does not support LiFePo cells.
I like the wide range of charging options. You can charge as slow as 0.1A (100mA) all the way up to 3A. This provides tremendous flexibility. For 18650s, I normally charge them at 1A. For smaller cells like 14500s, you'll want to use a smaller current, more like 300mA. Charging multiple cells at 3A would get pretty warm, though.
I like that the unit is powered with a proper wall plug and not USB-powered.
The sliders move well (not too stiff or too sloppy).
The power bank functionality works well and outputs 1A although it only uses the 4th slot. So, if you need a ton of energy you will need to swap batteries to the 4th slot. Using cells as a power bank is also a good way to discharge cells (either for storage or testing) without "wasting" energy.
The only thing that I wish this charger did was automatically drain and charge batteries in all 4 slots to analyze the battery capacity. This charger will show you the cumulative charge but you would need to drain the battery first in order to get a good approximation of capacity.
Pete7874
Pete7874's picture
Last seen: 3 hours 25 min ago
Thanks for the review. Great job.
I’m working on my own review of this charger. Hoping to post it up in a few days.
ssschen
ssschen's picture
Last seen: 1 week 14 hours ago
Many thanks for the full photo of the AC Adaptor. Good to know that it accepts 100-240V inputs Big Smile
Would you guys say that this is a good 2nd charger to the Liitokala 500? I came very close to ordering the Zanflare C4 last week when it was a flashdeal special on GB for only US$22.xx shipped.
SoCalTiger
If you already have an analyzing charger like the Lii-500, this makes a good 2nd. I have both the Zanflare C4 and this. If you are stuck between them, my main points of comparison are this:
Function:
  • Zanflare has full capacity test function
  • Both have resistance function
  • MiBoxer can charge faster and will automatically select charge current (may be a negative if you prefer charging slower by default)
  • Both have dedicated power adapters included
  • Zanflare can use all 4 cells for the powerbank function (MiBoxer only C4)
Ergonomics:
  • MiBoxer is wider and deeper. It’s much easier to get cells in and out, also less likely to knock cells out accidentally
  • Neither have inset notches on the positive terminals that help hold cells down (Xtar does this and it’s very helpful to prevent knocking a cell out)
Appearance:
  • MiBoxer is “right-side-up” (Zanflare is “upside down”)
  • Overall construction quality and appearance is similar
Display:
  • MiBoxer has better display overall IMO and I like that I can view a lot of information for a single cell at once
  • Zanflare allows you to view info on all 4 slots at once but you have to click on the display for each slot to rotate
  • MiBoxer shows temperature
  • MiBoxer automatically rotates through stats
ssschen
ssschen's picture
Function:
Ergonomics:
Appearance:
Display:
Thanks very much for the detailed breakdowns of the differences between the two chargers. Big Smile Thumbs Up
I see from your signature you have done reviews of both chargers too, so will check out your reviews later. At this stage, I am leaning towards the MiBoxer C4-12 mainly because of its ability to fast charge at 3A over all 4 slots. Will have to keep an eye out over the next week or so. Hopefully GB will do a good deal on it during the 11.11 shopping festival. Not sure why BG is not carrying it?
Pete7874
Pete7874's picture
You may want to read my review regarding this part specifically.
ssschen
ssschen's picture
Thanks for that. Just read it. A bit concern about the sporadic reboots. And that it won’t revert back to the last saved charging current (3A), so you could end up with 3A of charging for a small time only. You didn’t mention this on the 2A charging, so sounds like 2A charging is more reliable? I haven’t read the Zanflare review yet but my guess is its max charging current is probably the same as the Liitokala 500, ie. 1A?
_Charging Li-Ion at 4×3A
Here is a graph of charging current when charging a Samsung INR18650-30Q button top using a manually selected 3A rate. All four channels were being charged at 3A while data was being logged on Channel 1. As can be seen, my unit is not capable of sustaining 4×3A charge throughout the whole cycle. It will reboot after some time and will restart using lower charging rates. Once finished, when removed from the charger, cell voltage was 4.18V._
Pete7874
Pete7874's picture
Yes, 4×2A charging posed no issues for me. Possibly even 4×2.5A may have been OK – I have not tested that yet.
In all honesty though, I don’t see myself needing to use 4×3A much if at all. I don’t own any cells larger than 18650. A typical high drain 18650 has about 3000 mAh capacity. It’s not going to be that much quicker to charge it using 3A vs 2A or 2.5A. Now, if you own large 26650 cells with 5000+ mAh capacity, that difference in charging speed will become more noticeable.
Correct.
myst999
Last seen: 3 days 3 hours ago
I recently purchased this charger and haven’t had any re-booting problems when charging at 3A. It looks like they may have fixed the re-booting issue as you mentioned in your review:
However, what I have is a first version of this charger and Miboxer told me they tweaked it since and that in the newest version, the charger will better control temperature and will not reboot.
Pete7874
Pete7874's picture
Yup, but if yours is an updated version, then you should see current rate dropping below 3A in order to prevent temperatures from climbing.
Also, just to be clear, in my case the re-booting did not happen when charging only 1 or 2 cells at 3A. It happened when charging all 4 cells at 3A.
Also, the rebooting is fairly quick, so unless you are watching the charger throughout the entire cycle, you might miss it.
myst999
Also, based upon battery level and resistance , the current rate will drop even if you set it at 3A – so those are additional things that will lower the charge rate. The next time I have 4 batteries pretty well depleted I will keep an eye on the current rate to see how it behaves.
Pete7874
Pete7874's picture
Yes, try with 4 depleted high current drain unprotected cells, such as Samsung 30Q.
You don’t want to be pushing 3A of current into low current / high IR cells to begin with.
Lexel
Lexel's picture
Last seen: 1 day 23 hours ago
My review Charger did not reboot with 4×3A charge
Pete7874
Pete7874's picture
Good to hear. What was the highest temp you observed during 4×3A charging? Starting with fully depleted cells, how long were all the cells at 3A before current started ramping down?
Lexel
Lexel's picture
I switched to 3A after 15 minutes
the other charger is 1A all the way
Pete7874
Pete7874's picture
Because of the rapidly cycling current/voltage/IR display in your video, I can’t tell when it started ramping down. I also can’t see what the other 3 channels are doing… what level of charge they’re at.
But your temps are much lower than mine. Mine reached 53C, and that’s when the reboot happens.
Lexel
Lexel's picture
I looked at the pictures
to 4208 is last with 3A
start picture 4101 with 30 seconds pause
so at 4116 12,5min I switched to 3A manual
54minutes till current ramp down
charge for a 3000mAh high drain cells took 86 minutes
mikelights
mikelights's picture
Last seen: 1 week 1 day ago
Very helpful review thanks!
Current collection
Olight -S1R -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite  -TN42 -TN40 ThorFire -S70S -TG06S -TK05 Manker -Mk34 Noctigon Emisar -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S -Emisar D18 -Emisar D4S Rofis -TR31 Lumintop -BLF GT -GT Mini -IYP365 -Tool AA 2.0 -FW3C Acebeam -X80GTvn -W30 Imalent -R90C -MS18 FireFlies -E07 Brass Reylight -Pineapple
Product Reviews
Chargers:
Opus BT-C3100MiBoxer C4-12MiBoxer C8Folomov A1
Flashlights:
BLF GTTN42TG06SEmisar D4GT MiniS70STM36EDC-C4BLF Q8W30
Custom Builds
XPL-HI C8, Aspheric XHP-70OSLON D1S
ZoomieFan
ZoomieFan's picture
Last seen: 1 day 5 hours ago
Quote:
I like the wide range of charging options. You can charge as slow as 0.1A (100mA) all the way up to 3A. This provides tremendous flexibility. For 18650s, I normally charge them at 1A. For smaller cells like 14500s, you’ll want to use a smaller current, more like 300mA. Charging multiple cells at 3A would get pretty warm, though.
Is there an “advised amps” list for cells? Is it a percentage of the peak discharge or just a fixed number for a certain cell size?
I even saw a charger that does 4A.
So before I start cooking my cells I would like some advise on 18650, 20700, 21700, 26650, 32650
Not on the list, do you think 32650 fits?
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
tatasal
Last seen: 21 min 35 sec ago
Recommend charge rates are from .5C to 1C. They say for longer cell life, .8C or below is recommended.
1C mean 1 times the capacity (of the cell). The Samsung INR18650-30Q for example, is a 3000mah cell, so 1C = 3amps.. while .8C is 2.4amps (or below)
ZoomieFan
ZoomieFan's picture
That’s very clear. Thanks!
tatasal
Yes, but only two 32650s at a time, and not side-by-side.
Sales-Miboxer
Sales-Miboxer's picture
Last seen: 1 year 6 months ago
working perfect
Please sent email any question:sales@miboxer.com
JasonWW
JasonWW's picture
Last seen: 5 hours 49 min ago
Every battery model has a data sheet from the manufacturer. Each model will specify a charge rate for rated life (typically 500 cycles at a certain capacity loss) and a maximum safe charge rate (which could reduce capacity quicker). Typically 1A is good for all 18650 and your not in a rush.
There was a list of 18650 cells with recommended charge rates, but I cant find it.
JasonWW
JasonWW's picture
Boro
Last seen: 1 hour 49 min ago
Function:
Ergonomics:
Appearance:
Display:
What very helpful post thank you.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 3 hours 55 min ago
I just bought this charger for $15.99 on Amazon? $9 promo with $5 coupon!
I have an Opus arriving too but I couldn't resist this deal after reading this and other great reviews! I actually need to replace an Xtar VC2 that is 50% malfunctioning.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
JasonWW
JasonWW's picture
I have an Opus arriving too but I couldn’t resist this deal after reading this and other great reviews! I actually need to replace an Xtar VC2 that is 50% malfunctioning.
I’m pretty sure you didn’t. Maybe you bought the C4?
Wait, are you saying you used two coupons to save $14? So the Amazon price was $30? I have never seen it that low on Amazon. Only on Aliexpress when they had their big 11/11 sale.
Do you have a link?
The cheapest I see is $38 which is a pretty decent price for Amazon. Usually it’s $45.
Nachtfeuerzeug
MiBOXER C4 Universal Battery Charger, LCD Display Speedy Smart Charger with US Adapter for Rechargeable Batteries Ni-MH/Ni-Cd AA AAA Li-ion/LiFePO4/IMR 10440 14500 13450 18650 RCR123 26650 https://www.amazon.com/dp/B073RZBQ85/ref=cm_sw_r_cp_apa_vvTtBb04F1QQN
I'm pretty sure you didn't. Maybe you bought the C4? Wait, are you saying you used two coupons to save $14? So the Amazon price was $30? I have never seen it that low on Amazon. Only on Aliexpress when they had their big 11/11 sale. Do you have a link?
Yes! A C4.
EDC
Reviews:
JasonWW
JasonWW's picture
BROODMASTER wrote:
I’m pretty sure you didn’t. Maybe you bought the C4? Wait, are you saying you used two coupons to save $14? So the Amazon price was $30? I have never seen it that low on Amazon. Only on Aliexpress when they had their big 11/11 sale. Do you have a link?
Yes! A C4.
Oh, that is a different model.
Did you mean to buy the high powered 12 amp version C4-12?
Or the lowerer powered 3.2 amp version C4?
The older C4 can be pretty cheap, but it’s not the model we are talking about in this thread.
Still, $16 for the C4 is a really good deal.
Nachtfeuerzeug
JasonWW wrote:
Yes! A C4.
Oh, that is a different model. Did you mean to buy the high powered 12 amp version C4-12? Or the lowerer powered 3.2 amp version C4? The older C4 can be pretty cheap, but it's not the model we are talking about in this thread. Still, $16 for the C4 is a really good deal.
Yup, I think I got the lower powered version. It was a little deceiving buying it through the IPad app.  I usually charge at 0.5A anyway.  Here are the details:
Order Summary
Items: $29.99
Shipping & handling: $0.00
Promotion Applied: -$9.00
Your Coupon Savings: -$5.00
Total before tax: $15.99
Estimated tax to be collected: $0.00
Order total: $15.99
Thanks for the heads-up and the compliment for the price!
EDC
Reviews:
