Seems to throw very well.
Having an XHP35 HI with that size of reflector, as the reflector is about as deep as the Acebeam K70. Even at only 2500 lumens, 1200m throw is a reasonable claim.
Edit: I was perhaps wrong.
MT07S HI:
1600~1800 lumen and 220 kcd
~60 more participants needed
Interested
did you sign up? ;)
bump
30 places left ;)
30 places left.
I am excited.
How noticeable in real world use would the ~350m FL1 difference between the Astrolux MF02 and the Haikelite MT07S HI be?
That is a non negligible difference.
The MT07S HI does have a slightly better UI, and more thermal mass, so it’ll stay a bit cooler than the MF02.
But at 1050m tested throw vs 1400m tested throw, if you only want throw, get the MF02.
Are you referring to manufacturer published number of 1587m and 1200m for MF02 and MT07S HI?
Thanks, I think I will pass this up and get the MF02 instead.
interested!
DENGOH: Yohan110:How noticeable in real world use would the ~350m FL1 difference between the Astrolux MF02 and the Haikelite MT07S HI be?
I was refering to the tests in this link posted above by hIKARInoob.
I see no MT07S HI result, maybe it is hidden somewhere in that thread.
Anyway, if they are indeed having difference of 350m measured by forumer, I think it is quite funny to know Astrolux and Haikelite were using offset numbers quite close to each other to boast their flashlight throw distance.
1587-1200 = 387m. I wonder is it possible they engage the same test house to perform the test and cause this offset from reality.
Interested.
10 more needed
This seems like a better deal than the sc26 group buy that I am in. I am about ready to back out if that group buy. It’s going terribly.
I can highly recommend the MT07S (70.2). Great machining and finish; the light feels really good in the hand. And the output is just amazing. It’s just a joy to use, and the price doesn’t get better than this.
JakeDjanitor:This seems like a better deal than the sc26 group buy that I am in. I am about ready to back out if that group buy. It’s going terribly.
How does it compare to the xhp 35 model? I have a q8 and an l6 for the medium distance stuff.
