Coupon code with discount is available.
» Request via PM here«
Niwalker C11 XP-L V6 1300LM Brightness USB Rechargeable Dual Switch Tactical LED Flashlight
It’s now in flash sale for $33.89 (-$9.96)
Convoy C8 Xp-l Hi 7135*6 Integrated Head Long Range LED Flashlight
It’s now in flash sale for $17.99 / $20.99 (-$12.00)
Offer expires in 5 days and 14 hours.
Xiaomi Mi Note 3 5.5 Inch Facial-Recognition 6GB RAM 64GB ROM Snapdragon 660 Octa Core 4G Smartphone
Use coupon code 5BGNOTE3 for massive $63.00 discount - price drops to only $286.99
- 6GB LPDDR4 1866MHz RAM
- 64GB UFS ROM
- Snapdragon 660 Octa Core
- 5,5” Full HD IPS screen
- 3500mAh battery
- under-glass fingerprint sensor
- 3D curved glass body
- metal frame
- USB-C with QuickCharge 3.0
- dual 12 Mpix rear camera with optical zoom and 4 axis optical image stabilisation
- 16 Mpix front camera
- NFC
New ThorFire PF04 XP-G2 R5 210LM 3Modes LED Pen Light Flashlight AAA
Coupon code with nice discount is available.
ThorFire PF01S Upgraded XP-G2 120LM Tactical Mini Pocket LED Flashlight
ThorFire PF02S Upgraded Version XP-G2 240LM 5Modes Pocket Pen Light LED Flashlight 2xAAA
Coupon code with additional discount is available.
- Unique 180 degree rotary head
- Cree XP-G2 S3
- 3 colors: black, red, golden/yellow
- 3 mode groups:
- high/medium/low
- strobe/SOS/beacon
- red-green alternative flashing (additional LEDs on both sides of button )
- looks moddable (easy to open: side screws + head screws)
Sunwayman C41CT XM-L2 U3 1000LM 6Modes USB Rechargeable Memory Mode Brightness LED Flashlight
Sunwayman C45CT XM-L2 U3 1000LM Dimming USB Rechargeable Memory Funtion Brightness LED Flashlight
Hi petemer! Can you ask some coupon code for Eagle Eye X2R 3C led version?
Thank you!
I like these new Sunwayman lights,
looks like a good UI:
Activation of the light:
A quick depress of the switch at the top to turn the light on; hold the switch the light will cycle through Low-Mid-High-Turbo. Last mode memorized.
Hidden Modes:
A quick double-click will activate Strobe and another quick double-click under Strobe will enter SOS.
(I assume it’s single click to turn it off)
Interesting they are using XM-L2 when most new lights are using XP-L / XP-L2.
The smaller one’s about the same size an a Nitecore MH20GT
Pretty cool “wave” knurling.
CRELANT V5CS XM-L2 18650 960LM Camping LED Flashlight
Use coupon code d5e70b for additional discount to get final price of $23.99
- 3C and 5C tints in stock (7C is under restocking)
- dual switch design: side e-click + tactical tail switch
- High, Low, Strobe, SOS, Stepless dimming (5–100) with memory function
Please use this link:
Eagle Eye X2R XM-L2 U3 670Lumens USB Rechargeable Tactical LED Flashlight 18650
with coupon code HEX2R
” 2PCS GETEED 3.7v 4800mAh 35A High Power 21700 20700 Rechargeable Li-ion Battery “:2 STÜCKE GETEED 3,7 v 4800 mAh 35A High Power 21700 20700 Wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland-arrival notice-arrival notice
Use coupon code 94bf0d to lower the price to $15.99 (–20%)
JoinRun S4 4Slots EU Plug LCD Display Automatic Rapid Intelligent Li-ion/NI-MH/NI-CD Battery Charger
Use coupon code 1b30d2 to get additional discount and $22.99 final price($39.90 -> $28.79)
It’s shipped with US cord and adequate adapter for your country but it’s powered by standard figure-8 cable so you can use any matching cable lying around. Can also be powered by 12V DC power source with barrel plug(car adapter is not included).
- compatible with all popular chemistries (Li-ion 4.2V and 4.35V, LiFePO4, Ni-Mh/Ni-Cd)
- big backlit LCD even shows charging phase (CC, dV, CV)
- internal resistance an capacity measuring (apparently one slot only)
- 800mA/350mA (Li-ion) and 600mA/300mA(Ni-Mh) current per slot
Thank you!
Hey ZozzV6 What you planning to do with Eagle Eye X2R ?
Im just curious
There is always some people who asking for a flashlight around the house and that is good for beginners and easy to use. So I always keep 2-3 new pieces for them.
Totally. This is great flashlight for non-flashoholics with decent output, good tint and at ~670lm you don’t have issues with heat.
Built in micro USB charging is great because user doesn’t have to handle the cell at all - just use it like common cellphone. So with good quality cell it’s imho as safe for a newbie as possible for li-ion based light.
There’s only one thing to be aware of - to charge the cell inside the flashlight you have to turn the switch on as it’ mechanical switch which breaks the circuit otherwise. If you put 3500mAh cell inside, it lasts so long with sporadic use that some users tend to forget the fact and then call to sulk their’s great flashlight doesn’t turn on anymore - just flickers and doesn’t charge
But this design also have the advantage of zero standby current draw when not used so no issues with drained cells after few weeks or even months.
