*BLF LT1 Lantern Project* (first code for all 3000 GB list sent)
9915 posts / 0 new
sbslider
sbslider's picture
Last seen: 1 hour 38 min ago
DatBobaLife is #764
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
d0190535
Last seen: 1 year 6 months ago
Thanks.
DBSAR
DBSAR's picture
Last seen: 1 day 15 hours ago
UPDATES, May,18,2018:
- Did some Beam-pattern comparison shots tonight of the new V2 prototype against the original SRK-based V1 prototype, the BLF Q8 with the best diffuser i found (and have tested that fits perfectly) and compared it to the best & most used other modded LED lanterns i have, a modded survival multi-lantern, a modded Noma dual-LED lantern, and a modded Coleman LED.
Photo below shows them from left to right:
First up, is a collage of the lanterns placed against a white flat, smooth back-drop to show the beam patterns of the lanterns, with a flat-plane below them to simulate a table or counter surface. The Nikon D5100 DSLR settings were the same for all 6 photos, (F5.6, S-1/180,) and all lanterns were on low or medium modes set so they were all roughly the same output, ( averaging 250 ~ 300 lumens)
Now here is where the details of my findings are shown..
- photo #1 is the V2 BLF Lantern prototype, with two down-firing XP-L 3000K LEDs. As of right now this new head design has the smoothest, most even beam pattern of all my lanterns with the least artifacts and least tint shift. This is due to the moderately frosted main lens/globe, (with not second inner globe) and the use fo 2 or 4 LEDS & senter post instead of one LED and side post design. Also, the trick here to get this smoothness and higher beam angle from down-firing LEDs, is both the top surface & bottom surface painted with a clean-white “Flat” coating, (not gloss white, or chrome coating like 90 % of commercially available lanterns we see on the market today. Chrome plating or shiny surfaces just adds glare, hard-lighting, and artifacts. ( as seen on the #2 , #4, #5, and #6 photos. Flat-white surface form my past tests reflect the most light in a smoother flood-pattern than polished or shiny surfaces, and with the top & bottom surfaces of the head flat white, the reflecting back & forth also “amplifies” the light out the sides, increasing efficiency and flood angles. Notice in photo #1, where the V2 has the smoothest pattern, least tint shift, and most down firing light for table illumination, and also the least hard-light glare.
Image #2 is the V1 prototype, with a single down-firing XP-L 4000K LED, it only has a bottom flat-white surface, but the top surface around the LED is shiny. for some reason this increases the tint shift and hard lighting, (though better than the other lanterns, its not as good as the V2.
- Image #3 is a stock Q8 with the diffuser. As most flashlights with diffusers, there is almost no illumination downward on the table that it rests on, and most of the light
is directed upwards. While ok indoors, but outdoors its impractical and has the most glare on the eyes of all these lanterns when resting on a table below the eye line.
- Image #4 is a much larger Coleman modified LED lantern, with single down-firing XP-L 4000K. while it has good table illumination because of its much bigger size, its diffuser and single LED produces some hard-light artifacts in the beam.
- Image #5 is a Survival Lantern i modified with a single down-firing XM-L 3000K LED, While its tall lens/reflector adds to the beam angle, it has some artifacts due to the shiny bottom surface.
- Image #6 is a modified Noma dual-LED lantern. with two XP-G2 3000K LEDs, This lantern has both down-firing AND up-firing LEDs, and in between them is a diffuser “tube”. While this design does increase the overall beam output angle, the up-firing LED does produce more eye-glare, and the framed lens adds shadows & artifacts.
Next up below, i added the bottom tripod mount to the lantern as talked about earlier in the topic, ( in this case i added a 1/8” aluminum plate inside the bottom cap, then threaded it with the 1/4-20” standard tripod hole. then sealed in the inside to make it waterproof.
then here below showing the V2 BLF lantern prototype on a camera tripod. This would be a great option outdoors at a camping area, where it will illuminate a larger area.
DBSAR
DBSAR's picture
So as the above tests for the beam pattern smoothness and angle were done with two XP-L 3000K 7A emitters, the next test and modification will be swapping the XP-Ls for the new Samsung 351D 4000K emitters, ( using two at first then four of them to measure amp-draw versus output) to compare the new High-CRI 351D LEDs for lantern use. I also hope to add the USB charger function too over the next couple weeks, ( in this case it will be TP4056 1-Amp module-based, same as the V1 prototype has, to do a longer-term test of sustainability for run times per night versus charging-times per day using four 3200mah or 3400mah cells.
_ I als owill begin working on a cross-section drawing of the new V2, but we do need to get a CAD-design drawing after that to provide to Thorfire for a base to work on.
Satan@103TFS
Last seen: 1 hour 59 min ago
Very nice.. so far , so good.
GreenLights
Last seen: 18 hours 28 min ago
Would you please share what this diffuser is and/or where to get one? Thanks.
Just discovered this wonderful addiction.
sbslider
sbslider's picture
Awesome work!
goshdogit
goshdogit's picture
Last seen: 1 hour 29 min ago
The new prototype is looking great! Thumbs Up
What method are you using for the lanyard on top? I have found these ‘crimp’ style ends to be unreliable.
My friend lost a ferrocerium rod when one failed. In the rare instances that I use a lanyard, I eliminate the plastic end and tie a knot instead.
I really like bottom tripod mount, and I think I’ll add one to my Q8. Did you modify the tail PCB in order to make room for the 1/8” plate?
Can you test the beam pattern when the lantern is hung a few feet above a table?
Persechini
Persechini's picture
Last seen: 3 weeks 3 days ago
@DBSAR
The V2 prototype was already cool looking, now with the beam comparison I’m liking it even more, put a high CRI emitter and I might have to order a few more to donate to my scout group XD
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
cu42
Last seen: 10 hours 31 min ago
Persechini wrote:
@DBSAR
I am all for high CRI as well. At this point though, I’m in even if this thing has a knock off CW cree LOL.
Has a price range been discussed for this thing? Trying to narrow down quantity I want vs can afford.
Madtoffel
Last seen: 16 hours 2 min ago
Looks great so far. Maybe you could also add some sort of rubber pads/coating to the bottom to give it a more stable stand on sloping surfaces like camping tables. And high cri would be great.
DBSAR
DBSAR's picture
EDIT: i thank David below for noting my error in what you were referring to. Big Smile
the one i found for the Q8. Its the diffuser head from this flame light: https://www.amazon.ca/gp/product/B078STGQK9/ref=oh_aui_detailpage_o06_s0…
It has a shoulder and clips on the Q8 bezel perfectly & locks in place. I am using the flame unit its self for another electric simulated campfire.
DBSAR
DBSAR's picture
I agree, i don’t like those crimp ones either for that reason. I only use the “sleeve” type, which is much stronger and locks permanently on the paracord end. I also melt & fuse the paracord ends together to they are joined permanently too. The ones i like best are these with the built-in locking hook on the lantern lanyard, which is handy for clipping to a overhead guy rope, inside a tent with the roof loop hanger, etc. This type: https://www.aliexpress.com/item/100pcs-pack-Zip-Clip-Buckle-Zipper-Pulls...
If i remember i will try to get an outdoor photo of the lantern hung a few feet over a table. A trick i do for these situations with lanterns is place a white paper plate over the top as a “hat” hood reflector which really increases the down reflection of light. Smile
DBSAR
DBSAR's picture
cu42 wrote:
Persechini wrote:
@DBSAR
Prices are not worked out yet, ( for the group buy and the retail after) which will be worked out by Thorfire.
yasenf
Last seen: 1 hour 7 min ago
Please, add me for one more, total of 2. I am #255 in the list.
DavidEF
DavidEF's picture
Last seen: 6 days 13 hours ago
DBSAR wrote:
I sort of tried different things to get the right diffusion level that seems to work the best with out decreasing lumens form the LEDs. ( i am using a plastic frosted cup, with an additional frosted sleve atm to get the best beam pattern. I can take photos of it later to show.
I’m pretty sure he was talking about that diffuser “cone” you used to test against the prototypes, not the piece you used on the actual prototype.
- The YKK Philosophy
sbslider
sbslider's picture
yasenf is #765
DBSAR
DBSAR's picture
ah yes, the one i found for the Q8. Its the diffuser head from this flame light: https://www.amazon.ca/gp/product/B078STGQK9/ref=oh_aui_detailpage_o06_s0...
It has a shoulder and fits on the Q8 bezel perfectly & locks in place. I am using the flame unit its self for another electric simulated campfire.
dbare
Last seen: 6 days 15 hours ago
Yes, interested
sbslider
sbslider's picture
GreenLights
This is great, thanks!
beam0
beam0's picture
Last seen: 1 year 4 months ago
I really need to get in on this, please add me to the list for 1 pc.
Great work DBSAR, thanks for all the time and effort you’re putting in on this!
Don’t know why I’ve ignored this for so long but I really like the way it’s evolving.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
sbslider
sbslider's picture
beam0
beam0's picture
Nice! I had been thinking about looking into doing something like this on my Q8, can this mod be done to a regular stock Q8?
CJ Avlis
Last seen: 3 hours 15 min ago
Jumping in for a 2nd one please.
DavidEF
DavidEF's picture
Yeah, it was a stock Q8 before he modded it. Wink
DBSAR
DBSAR's picture
The standard Q8 tail cap metal is to thin, i had to add a 1/8” thick aluminum plate inside the tail cap using JB-weld to make it thick enough to thread it so it can hold onto the tripod mounts.
sbslider
sbslider's picture
Hi CJ, you currently are on the list 3 times,
174 CJ Avlis
263 CJ Avlis
447 CJ Avlis
Should I add you for a fourth?
sbslider
sbslider's picture
What I am planning on doing in the interest list going forward is providing it to DBSAR sorted alphabetically by user name, so you can easily look in the first post and see where you stand. This would be updated every so often, maybe twice a month, or more often if folks want. It is pretty easy to do for me, the magic of a spreadsheet. I’ll add a link to it below, but it seemed like for some reason several folks are having problems seeing the numerically ordered interest list, so don’t be surprised if you have problems with this one as well. Just ask for permission to see it if you need to.
I’ll continue to keep up the order of interest document which I have been linking to for the past week or so as soon as people request to be added, but will update the listing in the spreadsheet sorted by peoples name just periodically, like every other week or so (as mentioned above). Hopefully this helps folks know where they stand in terms of how many lanterns they have showed interest in to date.
Interest list sorted by user name
DBSAR
DBSAR's picture
That would be awesome idea Smile
