*BLF LT1 Lantern Project* (Codes for batch #1 underway from Sofirn)
9352 posts / 0 new
sbslider
sbslider's picture
Last seen: 3 hours 52 min ago
The list I created above is functional, but I am reworking it a bit to be easier to read. Hope to be done in a couple days or so.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
djozz
djozz's picture
Last seen: 1 hour 20 min ago
So is the cooperation with Thorfire working out sofar?
Newlumen
Newlumen's picture
Last seen: 1 hour 21 min ago
Anyone know if this lantern use unprotected or protected ? I want to start shopping for some protected 18650 if it does..
BlueSwordM
BlueSwordM's picture
Last seen: 6 hours 39 min ago
It will be using unprotected of course.
Just use any 18650 you have around, and it will work, as it uses the BLF Q8 battery tube, meaning both unprotected and protected cells will fit. And it has low voltage protection, meaning I would just use unprotected 18650s in this case.
Newlumen
Newlumen's picture
Do you think it will be ok to use unprotected 18650 for the normal people ( newbie) ?? I am fine with the unprotected..
BlueSwordM
Yep. Low voltage protection is there, like with the Q8.
And since all modes of the lantern are going to be regulated low power modes, protected cells are not really necessary.
DBSAR
DBSAR's picture
Last seen: 4 hours 42 min ago
I spoke to Barry a couple times so far via PM, once i can get a cross-section drawing done, and find somone who can to CAD design for the lantern to provide to them, then hopefully we can get it rolling more with them.
DBSAR
DBSAR's picture
It can use both. (but will need button-tops though)
beam0
beam0's picture
Last seen: 1 year 3 months ago
Some of the better protected cells now offer considerably higher currents of 10A continuous:
https://liionwholesale.com/collections/batteries/products/protected-pana...
https://liionwholesale.com/collections/batteries/products/protected-lg-m...
For lights with built-in low voltage shutdown I’m typically okay with using unprotected cells, even in a light that could end up being left on by mistake. Although with protected cells you will have a double layer of protection if one or the other fails.
These 10A continuous protected cells may be a good compromise for those that prefer to have that double layer of protection.
However I don’t know everything going on with the driver for this lantern yet, so I’m not sure if +10A capable cells would be required to achieve maximum output on the highest mode.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
djozz
djozz's picture
I have no idea if you tried that yet, but maybe you can ask thijsco to do some drawing? He was on the Q8 and GT projects too so he may add some experience with these projects too.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 40 min ago
If it uses a Q8-style driver, the LVP should be pretty solid and standby current is lower than the cell’s self-discharge rate.
DBSAR
DBSAR's picture
I don’t know him, but i can send a PM and ask if he is willing to help out on it.
barretttx
Last seen: 1 month 1 week ago
100% interested
sbslider
sbslider's picture
barretttx wrote:
100% interested
added to the interest list at #768
Raptor2018
Last seen: 1 month 2 days ago
Interested as well.
thijsco19
Last seen: 1 hour 36 min ago
I would really love to help on this project, unfortunately I don’t have the time. I joined our fire department and the training has just started so that takes all my time atm.
That being said,maybe fritz15 is interested?
DBSAR
DBSAR's picture
That being said,maybe fritz15 is interested?[/quote]
Thanks for chiming in Smile I don’t know Fritz15 sadly either or if he would like handle the CAD needed for this project.
djozz
djozz's picture
Thanks for chiming in Smile I don’t know Fritz15 sadly either or if he would like handle the CAD needed for this project.[/quote][/quote]
If in the end there is no one who will do CAD drawings, I can assure you that Thorfire is perfectly able to do the drawing themselves as long as they get the information. In the Q8 project all the important details were communicated via crude drawings in Paint, and even hand drawings, they converted them into technical drawings that were sent to us for evaluation. It was not perfect but it worked.
thijsco19
Especially since they obviously have the q8 drawings it might be easier if you go through thorfire directly.
As djozz said with the q8 they did all of the work off some easy to make crude sketches and drawings.
schlafsack01
Last seen: 1 day 16 hours ago
I am also interested.
sbslider
sbslider's picture
Raptor2018 and schlafsack01 added as 769 and 770.
sbslider
sbslider's picture
Next person interested will get number 579, somehow it got skipped.
List sorted by user name is now formated to be easy to read, just scroll down the list and see how many lights you signed up for, and the number of each entry.
Interest list sorted by user name
DBSAR, Just let me know when you want me to send you a .rtf version to post on the first post.
flashycali
Last seen: 10 hours 42 min ago
In for one.
Please add me to the list, thanks!
bmengineer
bmengineer's picture
Last seen: 49 min 28 sec ago
If you need some CAD help I might be able to find a few hours – all you need is a cross section and they’ll work off of that?
Find all my reviews of flashlights and more gear at www.bmengineer.com
DBSAR
DBSAR's picture
[/quote]
If in the end there is no one who will do CAD drawings, I can assure you that Thorfire is perfectly able to do the drawing themselves as long as they get the information. In the Q8 project all the important details were communicated via crude drawings in Paint, and even hand drawings, they converted them into technical drawings that were sent to us for evaluation. It was not perfect but it worked.[/quote]
good points. Smile
DBSAR
DBSAR's picture
I will be doing a cross section like i did for the V1, ( its in the OP) but its a bit crude with no actual measurements.
DBSAR
DBSAR's picture
RTF file works easier for copying to the OP i’m guessing.
rockymtflyfisher
Last seen: 1 month 4 days ago
Interested in Group Buy.
ToyKeeper
ToyKeeper's picture
I’ve done 3D modelling and animation, but not in the sorts of programs people use for physical production purposes. Less SolidWorks, more Blender. So it’d probably be better to ask ThorFire.
If it helps at all, I could share what I’m using to handle the FW3A interest list. The data goes in a plain text file, one line per request, with tab-separated values. Post URL, request type, username… sorted by post URL. Then a script goes through to assign request numbers and generate a report of requests — one sorted by request number and one sorted by username.
It’s still pretty crude, and I haven’t yet added the bits to automate everything, but it works for manual purposes.
DBSAR
DBSAR's picture
All help is aappreciated Smile I will work on an updated Cross section drawing in Photoshop like the original in the OP ASAP this week, so we have a base design to work on.
