Totally. This is great flashlight for non-flashoholics with decent output, good tint and at ~670lm you don’t have issues with heat.
Built in micro USB charging is great because user doesn’t have to handle the cell at all - just use it like common cellphone. So with good quality cell it’s imho as safe for a newbie as possible for li-ion based light.
There’s only one thing to be aware of - to charge the cell inside the flashlight you have to turn the switch on as it’ mechanical switch which breaks the circuit otherwise. If you put 3500mAh cell inside, it lasts so long with sporadic use that some users tend to forget the fact and then call to sulk their’s great flashlight doesn’t turn on anymore - just flickers and doesn’t charge
But this design also have the advantage of zero standby current draw when not used so no issues with drained cells after few weeks or even months.
Use coupon code 282233 to drop $25.99 price to only $17.99 (–8$ / –30%) Best price to date!
This is high quality precision screwdriver set with well designed(they even win reddot award) and compact case. See reviews @Banggood product page - there are also user provided real photos that better show the high end craftmanship.
I already got mine (ordered some time ago in flash sale for few bucks more ) and I’m positively impressed with the quality and good design. I can recommend this set. It’s very useful and stylish at the same time. I think you’ll like it as well
I don’t own it (I’m using a Bondhus set for my knives) but the Xiaomi/Whia set was a subject of discussion a few months ago in the All Things Budget Knife thread.
Some use it for knives and commented on it:
Exactly. Coupons in general do not work when the item is in flash sale like these screwdrivers right now. When flash sale is over coupon should work again - but price might be different.
Use coupon code 3a103e to get $18.87 price (-$11.08).
This is tried design based on prevalent C8 host with XP-L HI LED (1A, 3A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
