Fried my flashlight? Lumintop ODF30
51 posts / 0 new
Zane
Hi everyone,
I just purchased a Lumintop ODF30 Flashlight from Amazon, and 2 Keep Power IMR26650 5200mAh batteries. I charged fully then put the battery in and closed it, and when I pressed the power button nothing happened.
I unscrewed the tail cap and smoke came out and it smelt very bad, and the battery felt warm. Does this flashlight not have reverse polarity protection, or was it shorted when I got it? I’m assuming it got fried and ‘let the magic smoke out’
Thanks for your help,
Zane
Edited by: Zane on 04/28/2018 - 00:32
moderator007
moderator007's picture
Last seen: 2 hours 14 min ago
Did you put the battery in backwards?
yasenf
Last seen: 4 hours 34 min ago
Looks like you describe battery venting. Put it away on a safe place outside, as if this is the case, the smoke is bad for inhaling. The info you gave is not enough for locating the problem, but people will start asking you questions to identify the cause. As beginning – is the battery fully wrapped – i.e. is the foil undamaged?
moderator007
I didn’t find anywhere that say’s it’s reverse polarity protected, but In this day and time it should be standard.
Zane
I’m not sure, I wasn’t really paying attention. So probably… I think that’s why it smoked and got warm. Putting the battery in either way now it doesn’t do anything or get warm.
Zane
Yes, the foil is undamaged and the battery is in good condition as far as I can tell. I put it on the charger and it seemed to be fine. I tried with the other battery in the flashlight and it didn’t work either. I think I damaged the circuitry on the flashlight.
Zane
In my defense though I didn’t see anywhere on the manual that stated which way the battery should be put in…
moderator007
Could have been reversed cell, but know way to know if you don’t recall which way you put it in.
Either way, Amazon should take care of it.
Zane
moderator007 wrote:
Could have been reversed cell, but know way to know if you don’t recall which way you put it in. Either way, Amazon should take care of it.
Thank you very much for your help!!
Slightly off topic, but can you recommend any similar flashlights with Type C charging built in?
moderator007
Interesting picture, battery seems to be in backwards of the norm. Took from the Lumintop site.
moderator007
http://budgetlightforum.com/node/57341 and this one http://budgetlightforum.com/node/57918
Just seen this a few days ago. There are others I’am sure, I know nothing about them though as I don’t own a USB C type yet.
Manker seems to make quality lights though.
Newlumen
Newlumen's picture
Last seen: 4 months 1 week ago
Sound like a capacitor went bad, and possible you might have a defective xhp 70.2.. i think amazon should take care of it…
By the way, i ordered my odf30 from banggood this afternoon. I hope i dont run into problem like your..
toddcshoe
toddcshoe's picture
Last seen: 14 min 25 sec ago
moderator007 wrote:
Interesting picture, battery seems to be in backwards of the norm. Took from the Lumintop site. !{width:110%}[img]https://i.imgur.com/hM42inG.png?1[/img]!
That battery in the pic is not backwards. There is a “-” right next to the High Capacity text. The negative end is in the tail cap. I don’t own a light where the positive battery tip goes in the tail cap. I have a few Lumintop batteries and a bunch of other name branded cells and on all the ones I have, reading the text on the battery from left to right, as is the norm. The left is the positive tab and the right is the negative. Am I missing something?
"Everywhere I go, there I am"
g_sintornillos
g_sintornillos's picture
Last seen: 2 weeks 1 day ago
If it does not have polarity protection, it will not be the first Lumintop model that does not have it.
A friend of mine fried an SD10 for that reason.
Sorry for my bad English (gogole transtorla)
g_sintornillos
There are
The first one that came to mind: Olight S1 mini
https://www.forolinternas.com/viewtopic.php?f=9&t=14397
Zane
g_sintornillos wrote:
If it does not have polarity protection, it will not be the first Lumintop model that does not have it. A friend of mine fried an SD10 for that reason.
I contacted Lumintop last night, they confirmed it does not have polarity protection.
They also confirmed the positive side goes towards the LED, negative towards the tail.
Kinda bummed about frying the flashlight, but thankfully Amazon has great customer support!
It doesn’t have reverse polarity protection, so make sure you put the negative in towards the tail and you will be fine.
MascaratumB
MascaratumB's picture
Last seen: 24 min 12 sec ago
RPP should be mandatory in these flashlights Facepalm
I almost damaged a Manker E11 due to that as well! Sorry to hear this and I hope :
a) that Amazon helps you on this
b) manufacturers start to make lights with RPP AND warn users/buyers if the lights sell don’t have it!
The User Manuals got to serve for something… Facepalm
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Zane
Yes, Amazon has already paid for the shipping back to them and will give me a full refund.
Not sure why RPP isn’t included in the lights, it would save the companies money because their lights wouldn’t get fried and returned to them! That, or put in the manual a warning like you said.
WalkIntoTheLight
Last seen: 3 days 8 hours ago
Zane wrote:
Yes, Amazon has already paid for the shipping back to them and will give me a full refund. Not sure why RPP isn’t included in the lights, it would save the companies money because their lights wouldn’t get fried and returned to them! That, or put in the manual a warning like you said.
What you say is true. However, I would not recommend a light that takes lithium-ion cells to anyone who is not familiar with their safety issues. You mentioned you weren’t paying attention when you put the battery in the light, and might have put it in backwards. That is dangerous! On some lights (with multiple cells) it might cause a short and do a lot worse than just smoke a bit.
Not paying attention to the proper orientation of cells is fine for alkalines or NiMH rechargeables. I’ve done it myself. But you have to be a little paranoid when using lithium-ion cells. They’re safe, but only if you follow all safety rules.
The manual should definitely have warnings about that.
Oh, one other thing: I wouldn’t personally buy lithium-ion cells from Amazon. Depending on how they are put in the warehouse bins, you might be getting fakes even if the seller is good.
Pete7874
Pete7874's picture
Last seen: 6 min 55 sec ago
What makes you think it’s backwards?
Zane
Where do you suggest buying Li-ion batteries?
Newlumen
Newlumen's picture
Illumn.com
Mtnelectronics.com
I do a lot of business with them.
Newlumen
Newlumen's picture
Yea. I will be careful.. this light is similar to the jetbeam t6. You have to insert the battery correct position.
Speed4goal
Last seen: 1 year 8 months ago
Unless otherwise stated the positive goes towards the head of the flashlight. Just like the old maglights and every other flashlight from a kid onward.
But in this day and age especially lumintop should have reverse battery protection. Either physical like nitecore or electrical.
Is this your first flashlight?
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Speed4goal
I would be highly surprised if the manual doesn’t say don’t insert battery backwards
If the batteries are icr then yes a direct short will most likely cause a vent with flame or this case a pipe bomb literally. But if it’s a imr inr chemistry. It may just vent some when it gets overheated. If you look at battery spec sheets. They have to be direct shorted for hours with no flame or explosion. They have to be overcharged at 12volts and 3x the mah for hours. They have be cooked in a oven. And crushed vertically horizontally. And violently shaken.
But no I wouldn’t recommend lithiums to someobe who doesn’t have a little common sense.
I have had shorts in lights I built and thought I had enough reflector clearance and smoked the drivers literally. Comes up under the lens. And melted springs before also.
moderator007
Only thing I can guess is maybe staying up to late. Sick
Funny part is when I saw the pic I thought the battery is in backwards when I saw the negative on the tail cap end.
I will never live this one down. Facepalm
Speed4goal
Nope never
toddcshoe
toddcshoe's picture
Speed4goal wrote:
Nope never
Oh come on, yes, we got to give him a pass based on sleep deprivation. Smile
moderator007
I apologize to the OP, poor Zane probably spent half the night trying to figure what the *ell I was talking about. Facepalm
Lumintop
Lumintop's picture
Hello Zane,
Regret to hear that and the unhappy purchasing experience happens to you.
Due to the high current output, ODF30 is designed without reverse polarity protection indeed.
So, when inserting the battery, please make sure and make sure that the positive side goes towards the LED, and the negative towards the tail.
Next, we will make a notice about this issue.
Thanks for the supporting. Smile
LUMINTOP – Reliable! Playable!
liteupmynite
Last seen: 9 hours 11 min ago
I'm new here and this is my first post. Smile
I recently purchased a Lumintop ODF30 Flashlight and same battery from Amazon as well. And, made the mistake of installing the battery backwards. After removing the battery, I smelled the smoke too. Light didn't function after re-installing battery with the proper polarity.
Looking at the manual and flashlight, there doesn't appear to be any reference to the correct polarity for the battery. It's been my experience that most flashlight use a spring on the negative poll with few exceptions. I will never make that assumption again. Silly
I ended up watching a youtube video about this light to gain insight into how the battery should be installed: https://www.youtube.com/watch?v=RAII-erOb6I&t=261s
I'm under the opinion that this battery does not have reverse polarity protection. Perhaps, if I had I used a protected battery, the flashlight wouldn't have gotten fried.
