The price is 0.5$ per 351B + shipping.
Thank you, now I want to order some…
Are the 351B available yet ?
@X3, they are available now. Just send a PM to AEDe with your info and payment.
Here’s an output measurement for the LH351B. This is on a Kaidomain 16mm DTP MCPCB mounted on an aluminum heatsink with fan cooling.
Ah, as expected from a small 3000k 90CRI emitter. Not nearly as efficient as the LH351D 4000K 90CRI.
Three times cheaper though…
Yes.
Also, you know what is strange in relation to it?
In terms of lumens per watt, it is about as equivalent to a 219B R9080 in terms of brightness. Doesn’t have as good R9 though.
@AEDe, do you have any 351Bs 4000k you could sell to us?
I would really like to have some 4000k 351Bs for special builds of mine.
It is possible to order 351B 4000K 70cri only.
Oh okay then. Thought you had 90CRI LH351B.
Would’ve been great though. Thanks anyway.
I would be in for 4000K 90CRI LH351D (20 pieces)
Could you please notify me, when it will be available again?
Yes, of course.
Anyone know if 351D fits under carclo triple optics?
Yes, no problem.
The type doesn’t matter either. The beam is very nice with the clear/smooth spot version also
So… I see I managed to miss the 351D in 4000k… Looks like they may come back into stock? I am interested since the Vf is higher and I have a couple of triples that I would like to rebuild.
Great thanks! Now I need to figure out what host to use. I have way too many S2+
I prefer E2L. Lighter weight and you can access bezel easier to switch optics but overall not much different from S2+
@AEDe again, do you have 3000k 90CRI 351D emitters?
Thanks again for the response.
There are only 3 Hicri led in the shop I used.
1)351D 4000K 90cri
2)351B 3000k 90cri
3)XPG3 5700 90cri
All other variants available on order whith minimum 800-1000pcs with lead time obout 6 weeks.
If you need at least 500pcs. 351D 3000K 90cri(300pcs I can take for myself) we can arange order, but with a prepayment condition. I not have vacant >1000$
