Coupon for the xiaomi screwdriver set isn’t working
Many thanks for the info, beam0, very helpfull :+1:
Too late probably, it did work for me. Few bucks cheaper than at ali.
gavrook:Coupon for the xiaomi screwdriver set isn’t working
Exactly. Coupons in general do not work when the item is in flash sale like these screwdrivers right now. When flash sale is over coupon should work again - but price might be different.
Civictor T5 PLUS CA3-3K 900 Lumens 5Modes Switchable Tactical LED Flashlight 18650
Use coupon code 835c6f to get $35.99 price.
Civictor T5 XM-L2 U2 1000 Lumens 5Modes Switchable Tactical LED Flashlight 18650
Use coupon code f4b929 to get $27.99 price.
Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650
Use coupon code 3a103e to get $18.87 price (-$11.08).
This is tried design based on prevalent C8 host with XP-L HI LED (1A, 3A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
Astrolux MF-01 18x XP-G3/Nichia 219C 12000LM Super Bright LED Flashlight 18650
Use coupon code e04bc8 to lower price from $109.95 to $85.95.
Astrolux MF02 XHP35 HI 3000LM NW Long-range Searching LED Flashlight 1587M
Coupon code 85dd97 is active again for massive $45.96 discount.
Note: code only works for neutral white version.
Astrolux MF02 XHP35 HI 3000LM CW Long-range Searching LED Flashlight 1587M
Use coupon code YMF02 for -$44.08 / –35% discount. Coupon also works for NW version but previous coupon gives better discount.
” [COOL WHITE] Astrolux MF04 XHP35-HI CW 2700LM 7Modes Dimming High Bright Long-rang Searching LED Flashlight “:Astrolux MF04 XHP35-HI Suche LED Taschenlampe Sale - Banggood Deutschland-arrival notice-arrival notice
” [NEUTRAL WHITE] Astrolux MF04 XHP35-HI NW 2700LM 7Modes Dimming High Bright Long-rang Searching LED Flashlight “:Astrolux MF04 XHP35-HI NW 2700LM 7 Modi Dimmen High Bright Long-rang Suche Sale - Banggood Deutschland-arrival notice-arrival notice
Use coupon code 720f70 to get $179 price ($219).
This light is basically BLF GT ultra thrower powered by 4x18650 cells with unbeatable throw capabilities.
Lumintop ODL20C XHP35 2000Lumens 8Modes USB Rechargeable Brightness Tactical LED Flashlight
Use coupon code BRANDLMT to get -$19.99 discount and final price of $59.92
Nitecore EA42 XHP35 HD 1800Lumens 7Modes Dimming Tail Stand LED Flashlight for Outdoor Camping
Coupon code with discount is available.
» Request via PM here«
Nitecore EC22 XP-L HD V6 0.5LM To 1000LM Stepless Dimming EDC Mini LED Flashlight 18650
For the Astronlux MF04 (the BLF GT) is there a longer tube for 8 18650's? Or does the original BLF GT also use 4x18650?
For the Astronlux MF04 (the BLF GT) is there a longer tube for 8 18650’s? Or does the original BLF GT also use 4x18650?
The BLF GT Uses 8 18650 batteries, but can run off only 4. I would pretty safely say the MF04 only has room for 4.
BEARS ARE PEOPLE TOO:For the Astronlux MF04 (the BLF GT) is there a longer tube for 8 18650’s? Or does the original BLF GT also use 4x18650?
That’s exactly the case. Right now there’s no 8x18650 extension tube for MF04, but I would expect this might be available in the future (all other Astrolux lights were 1:1 BLF design). I’ll try to find out.
Right now there are these new 4x18650 tubes for Astrolux MF01 / MF02 / MF04 available:
Two designs to pick the one you like better (the only difference being the appearance of the knurling) - note this is not an extension tube - just different design to change flashlight style.
Red Copper ReyLight Pineapple Mini Nichia 219C 360LM Simple Operation EDC Tactical Flashlight
Upgraded ReyLight New Pineapple Nichia 219C 470LM 4Modes Memory Function EDC Tactical Flashlight
UNI-T UT210E Multifunction AC/DC Current Mini Digital Clamp Ammeter
Use coupon code 263e8e for additional -$10 discount to get final price of $29.99
