✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650
Use coupon code 3a103e to get $18.87 price (-$11.08).
This is tried design based on prevalent C8 host with XP-L HI LED (1A, 3A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
» Jump to First post quick links/deals list «
Astrolux MF-01 18x XP-G3/Nichia 219C 12000LM Super Bright LED Flashlight 18650
Use coupon code e04bc8 to lower price from $109.95 to $85.95.
Astrolux MF02 XHP35 HI 3000LM NW Long-range Searching LED Flashlight 1587M
Coupon code 85dd97 is active again for massive $45.96 discount.
Note: code only works for neutral white version.
Astrolux MF02 XHP35 HI 3000LM CW Long-range Searching LED Flashlight 1587M
Use coupon code YMF02 for -$44.08 / –35% discount. Coupon also works for NW version but previous coupon gives better discount.
[COOL WHITE] Astrolux MF04 XHP35-HI CW 2700LM 7Modes Dimming High Bright Long-rang Searching LED Flashlight “:Astrolux MF04 XHP35-HI Suche LED Taschenlampe Sale - Banggood Deutschland-arrival notice-arrival notice
[NEUTRAL WHITE] Astrolux MF04 XHP35-HI NW 2700LM 7Modes Dimming High Bright Long-rang Searching LED Flashlight “:Astrolux MF04 XHP35-HI NW 2700LM 7 Modi Dimmen High Bright Long-rang Suche Sale - Banggood Deutschland-arrival notice-arrival notice
Use coupon code 720f70 to get $179 price ($219).
This light is basically BLF GT ultra thrower powered by 4x18650 cells with unbeatable throw capabilities.
Lumintop ODL20C XHP35 2000Lumens 8Modes USB Rechargeable Brightness Tactical LED Flashlight
Use coupon code BRANDLMT to get -$19.99 discount and final price of $59.92
Nitecore EA42 XHP35 HD 1800Lumens 7Modes Dimming Tail Stand LED Flashlight for Outdoor Camping
Coupon code with discount is available.
» :email:Request via PM here«
Nitecore EC22 XP-L HD V6 0.5LM To 1000LM Stepless Dimming EDC Mini LED Flashlight 18650
For the Astronlux MF04 (the BLF GT) is there a longer tube for 8 18650's? Or does the original BLF GT also use 4x18650?
The BLF GT Uses 8 18650 batteries, but can run off only 4. I would pretty safely say the MF04 only has room for 4.
That’s exactly the case. Right now there’s no 8x18650 extension tube for MF04, but I would expect this might be available in the future (all other Astrolux lights were 1:1 BLF design). I’ll try to find out.
Right now there are these new 4x18650 tubes for Astrolux MF01 / MF02 / MF04 available:
Two designs to pick the one you like better (the only difference being the appearance of the knurling) - note this is not an extension tube - just different design to change flashlight style.
Red Copper ReyLight Pineapple Mini Nichia 219C  360LM Simple Operation EDC Tactical Flashlight
Upgraded ReyLight New Pineapple Nichia 219C  470LM 4Modes Memory Function EDC Tactical Flashlight
UNI-T UT210E Multifunction AC/DC Current Mini Digital Clamp Ammeter
Use coupon code 263e8e for additional -$10 discount to get final price of $29.99
Xiaomi Mijia Wowstick Wowpad 2 Magnetic Screw Pads Position Plate Remembrance Mat Repair Tool
It’s now in flash sale discounted from $9.59 to only $2.99 (lowest yet).
Offer expires in 5 days and 5 hours.
BlitzWolf® 20W 3A BW-L1 Foldable Portable Sun Power Solar Charger USB Solar Panel Charger with Power3S for iPhone 6s / 6 / Plus, iPad Air / mini, Galaxy S6 and More
It’s now in flash sale discounted from $85.99 to only $41.99 (–51%)
It the most cost effective option on the market right now – parameters are not overstated: 2 USB output ports able to deliver up to 3A of current (combined) so its able to charge any smartphone out there. It doesn’t even require full sun to charge(performance is reduced of course). The same product is sold on amazon and elsewhere under Anker 20W and Anker 21W panel if you want to search for more reviews. It’s now even cheaper than in preorder one year ago…
Folds into small book:
I got one of these. Easy to dismiss as an expensive magnet until you go to change out a part in a smartphone. There IS a difference between some of the screws in an iphone, but the difference is nearly imperceptible to my old eyes. On closer examination there are some that are 2 or 3 treads longer than the others and I suspect that the holes they go in to are not forgiving of having a longer screw being forced into them. This is a great way to keep track of original hole locations.
Also got a fancy blue project pad. After decades of working on tiny stuff that could’ve really benefited from such a surface I got one just in time to be an old man.
Some suspect those screws are different length on purpose - you destroy PCB/mainboard traces when you put one of those imperceptibly longer screws in wrong socket…
On the other hand - this is not that expansive given the size. Any magnet even quarter the size will cost much more.
Jetbeam DDR-30GT XHP70 3680LM Outdooors Long Range LED Flashlight 18650
Use coupon code 49909b to get -$90 discount.
XANES STL07 Smart Bike Tail Light Brake Sensing USB Rechargeable IPX6 Waterproof Rear Light
Newest tailight from Xanes is now in preorder for $16.99 (first 120 pcs), the price will gradually go up to a target price of $27.28.
  • USB rechargeable
  • seat rail mount
  • auto on/off
  • auto stop light (braking detection)
  • light sensor
  • CNC Alu
  • manual mode switch
