I received my light Friday from Banggood. It came in a typical hard cardboard box that Lumintop uses for other lights. Included were spare o-rings, a lanyard, charging cable and instructions.
I commented back in the early listings of this post that this looks just like a Manker 21 or Utorch Ut02. It is confirmed roughly when putting them side by side until you turn them on. Externally, the Lumintop has wider cooling fins as well as another set of cooling fins forward around the reflector swedged area when compared to Manker/Utorch. The handle barrel area has a nice knurling pattern very different from its siblings. Lastly the Lumintop is almost 1cm longer comparatively.
The real differences are the UI and output.
UI: The lumintop is single side click ON and single click through the modes. A double click takes you to turbo. Strobe and special modes are hidden. Long click to turn off. No lock-out that i can find.
Output: The Lumintop is more focused and has a tighter hot-spot than the Utorch or the Manker and is noticeably brighter than both as well. The newer less powerful version Utorch UT02 is simply blown away but I compared to all three anyway.
I pre-ordered the cool white version and it’s around 6500k. The throw is quite remarkable! I will have to take pictures and post them.
