… Three Noctigon 3XP parallel only 6A configured with two 219B 4500 and one 219B 4000 each MCPCB. …
All correct
Do these SW40s and SW45s share the same Vf bin/voltage performance group? Hope they're at least quite close for an about even load distribution; if not, in series is the way to go.
All correct
Do these SW40s and SW45s share the same Vf bin/voltage performance group? Hope they’re at least quite close for an about even load distribution; if not, in series is the way to go.
Cheers
No, they don’t. There’s always slight difference between LEDs, even those came from the same reel.
This is a makeshift solution practice which is not ideal but works OK. In real world practice many flashlight makers do the same. Some uneven brightnesses can be seen in ultra low firefly modes.
Low LED thermal resistance, high thermally conductive MCPCB, and careful soldering (thin solder joints) lessen the problem.
Clemence; Just covering my bases. Hopefully can find a good driver for this.
Pls add one more noctigon 3X in series ($3.30) plus two 219B 4500 and one 219B 4000 ($2.8 x three = $8.40) and reflow service for same (.70). I’m sending $51.75 + $12.40 = 64.15 USD
… one more noctigon 3X in series ($3.30) plus two 219B 4500 and one 219B 4000…
9A for this one. would work? …
9A and you're asking if that would work. That depends in what you believe “to work” is. For emitters who start tapering at ≈4A when properly cooled, if “to work” is to witness Mr Magical Smoke that will work.
My guess is you probably meant to say “3A” or “Noctigon 3X parallel”. That fixes it.
3× 219B in series will take no more than 3,5A. 3A is the max. for highest output. If you want to use 9A then parallel is the way to go. I suggest no more than 2,5A / LED.
1x Reflow service – $1 (2S2P, Standard reccomended SnPb solder)
2x E21A sm203-D160-R9050 – $5.46
1x E21A sm653-D240-R9080 – $2.73
3x VR16S1 – $12
3x Reflow service – $3 (Standard reccomended SnPb solder)
Shipping – $5
Total: $49.71
EDIT: paypal sent!
Soldering service for 3x E21A on 3x VR16S1 = 3x USD 1,2 = USD 3,6.
This is the most difficult one. Scraping off the masking layer, sanding them smoothly, then positioning the LED through the entire reflow process with just enough solder to make flat and thin solder joints. Since you paid already there’s no need to send me more payment to avoid unnecessary fees from Paypal. It’s just to let you know
3x VR16S1 – $12
Shipping – $5
Total: $49.71
EDIT: paypal sent!
- Clemence
You are a busy man the coming period, may the Agung not distract your hard work !
3x VR16S1 – $12
Shipping – $5
Total: $49.71
EDIT: paypal sent!
- Clemence
Mt. Agung eruption has been a norm these days. We’re all getting used to it. And yes, I never thought the additional side orders would be this much. I probably would have to close the store for a week just for soldering.
All correct
www.virence.com
Nichia Esttool [Nichia LED calculator] - Shooting Beamshots With HDR - Nichia E21A Tint Shots
Its Okay To Be Smart - SmarterEveryDay - Deep Look - Veritasium
Cheers
The Light
I am
FIXED: How to properly insert images into your posts without breaking the forum page layout
- Clemence
www.virence.com
Send payment for 1x sw40 and 1x sw45 more, total 6+6 (was 5+5).
Really hard to calculate how much I need for all my flashlights…
The GB will ends tomorrow, please kindly re-check the gsheet. I will stop receiving orders in 180604, 00:00, GMT +8 (~26 hours from now)
Thanks,
Clemence
www.virence.com
Clemence,
Not sure if you saw my change above, it is not on the sheet yet:
I’d like to update my 15 emitters from all 4500k to: 9 × 4500k and 6 × 4000k.
Thanks again for doing this!
fixed
www.virence.com
sending now to
virence.cle@gmail.com
steve42
Cheers
The Light
I am
Big order:
Total: $49.71
EDIT: paypal sent!
Project Excalibur - Next Generation LED Thrower (UPDATE 2018-01-15: 1.7Mcd)
Portable Thrower Comparison
Paypal sent for:
8x 219B-V1 sw45k R9080 = 22,40 $
3x 219B-V1 sw40 R9080 = 8,40 $
2x 219C sm303 D200 R9050 = 7 $
Shipping = 5 $
total = 42,80 $
Hello, may I please make an order?
I would like 10x of 219B sw45k:
3x reflowed onto Noctigon XP32 in parallel configuration
3x reflowed onto Noctigon 3XP [parallel only]
4x reflowed onto Noctigon 4XP v.2 [parallel only]
Costs:
10× 219B sw45k = $28
XP32 = $5
3XP = $3
4XP v.2 = $3
3x reflow service = $2.10 (is this the correct price for reflow?)
USA shipping = $5
Total = $46.10 (please advise if this is correct before I send paypal)
Thank you!
5 sw45k + 5 sw40 + shipping = 33 USD
PP sent
Sorry for my bad English (gogole transtorla)
Sorry, supposed to be 24:00 NOT 00:00. So there’s still ~10 hours
- Clemence
www.virence.com
OK, will update your list
- Clemence
www.virence.com
Paypal sent for 10x sw40 r9080
Can you put my stuff on the list Clemence if you find the time? I don’t have much time now. Maybe tonight.
- Clemence
www.virence.com
link to djozz tests
10x of 219B sw45k: 10x USD 2,8 = USD 28
1x Noctigon XP32: USD 5
3x reflowed onto Noctigon XP32 in parallel configuration: USD 0,7
1x Noctigon 3XP [PO]: USD 3
3x reflowed onto Noctigon 3XP [PO]: USD 0,7
1x Noctigon 4XP: USD 3
4x reflowed onto Noctigon 4XP v.2 [PO]: USD 0,7
1x Economy shipping: USD 5
TOTAL: USD 46,1
www.virence.com
www.virence.com
Ooh. Good point. Can I get 4x of my sw40 reflowed onto a 4x noctigon? Is that $3.7 extra?
Yes that’s correct.
- Clemence
www.virence.com
Thanks. Paypal sent to reflow onto a quad.
7 * 219B sw45k
price is 7 * 2.8 usd + 5$ shipping = 19.6$ + 5$ = 24.6$ total
I send them to your paypal now ?
- George
My Reviews : KDlight C8 / ThruNite Archer 1A V3 / Thorfire C8s / ThruNite TN12 (2016) / Utorch UT01 / Utorch UT02 / Jetbeam WL-S2 (xp-l) / ThruNite TC12 V2 / Massdrop Brass AAA / Manker LAD / Lumintop SD26 / ThruNite Mini TN30 (3x xm-l2) / Qualilite D81 / Nitecore MH20GT / Odepro TM30 / Klarus XT30R / Nitecore NU20 CRI / Ultrafire XM-L2 / Foursevens Mini MK II / Manker E02 / Manker E14 II / Teekland Flashlights / Lumintop Elfin / Thorfire S70S / ThruNite Neutron 2C / Jaxman M8 / KDLITKER C8.2 / Zanflare F1 / Nitecore Concept 1 / Emisar D4 / Astrolux MF-01 / ThruNite TC10 V3 / Amutorch JM70 (xpl hi)
Sure
www.virence.com
Paid
- George
Paid for $70
15 × 219B sw45k R9080
10 x sw40 R9080
deferred shipment with my next qualifying order
payed from s…1@gmail.com
Reflow service led onto mcpcb.
1pcs sw45k reflow onto Noctigon XP16 – led sw45k $2.8 + mcpcb noctigon xp16 $1.85 + reflow service $0.50 = $5.15
1pcs sw40 reflow onto Noctigon XP16 – led sw40 $2.8 + mcpcb noctigon xp16 $1.85 + reflow service $0.50 = $5.15
Bare led
sw45k 1pcs $2.8
sw40 1pcs $2.8
Shipping $5
Total = $20.9
Paid.
Just got home from the grocery store. Will update the list soon.
- Clemence
www.virence.com
