Once I insert a cell I watch the display cycle. The first charge rate is usually too low, on the 2nd cycle it’s gets higher, then the 3rd cycle it typically sets. So maybe check it 30 secs after inserting to see what it settles on.
It also needs to see that low internal resistance to set at 3A automatically.
It also needs to be below 4v initially to use the “constant current” charging mode.
That’s the same problem Mikeadoo had. It turns out the button tops were not welded securely enough. Removing the button tops an adding solder blobs fixed it. I suspect that soldering the button tops might also work, but I have not tried this yet.
It does seem to be related to button tops, though.
The circuitry and software in the C4-12 that determines the internal resistance is very finicky. Maybe more sensitive than other brands of chargers, hence why Miboxer might be doing these small software changes to improve this.
Also, I wouldn’t really say your other charger gets the resistance right, but that it gives a more stable and reliable reading then the C4-12. Accurate internal resistance is a very difficult thing to measure due to the tiny units we use, milliohms.
I have Liitokala chargers that I can set to 0.5A, 1A and 2A.
At least the indicator light stays permanently on those values. Obviously that’s no proof the charger actually uses those currents. I never use such cells but 2A would cook 900mAh cells.
Anyway my question was a bit unclear I think.
Which Liitokala charger has 3A output? I haven’t found one above 2A. And that’s for all cells combined. So only if there is one cell in the charger it gets 2A.
The only Liitokala charger I know that charges 2A is the Lii-402 only when used with single battery on the slot #4 and using a USB charger that can provide 2A.
I’m not sure of any others Liitokala charger that can charge at 2A… maybe someone can comment?
This C4-12 is the first charger I’ve seen with this much power, 12A. Maybe it will start a trend where other charger manufacturers will release high powered versions of their current models. Then we will have choices. :+1:
