Yes, with Carclo you can choose smooth or frosted finish. And cups that shape the beam to different beams.
Though really the only options that make sense is the narrowest cups with clear or frosted.
I’m aware of 1 other 3-up 20 mm lens, it’s from Kaidomain. I think it’s clear only and has slightly different hole spacing.
If the throw of the Samsung LEDs were an issue could we not just as for the narrow clear optic instead of the narrow frosted? I’m putting the floodiest optic I can find it it regardless.
XP-L HI 5D or the Samsung is my choice. If they were to do multiple, I think XP-L HI 5D and 219C 5000K would cover a lot of peoples preferences. I’m interested in seeing the poll results (once the poll is created).
I used doubled 20ga wires to get more current through my 219C triple. This didn’t hurt the emitters. It does have more of a heatsink than the FW3A will, but the FW3A will thermal throttle sooner.
Right there with you. I actually have a Samsung 4000k and it is absolutely even tinted, large hot spotted and a wall of light. I love this Convoy S2 with Samsung triple mod. I also have a 5000k samsung triple.
Being willing to buy a light that’s not high CRI is different from preferring it. Given the option, I’d much rather this light be one I can use for everything I might need to do that day which includes pulling it out to help gauge the color of something (clothing/fabric or other colored products, for instance), like I sometimes do with the d4 219c. If you’ve ever bought clothes under poor quality florescent lighting, and then when you look at them outside they are a different color, you know this can be frustrating. If not, look up the old “The Dress” controversy; the type of light source the viewer thought was being used determined what colors they thought the actual dress contained. My use case does not include trying to look for things further from me than a high brightness can reveal, but rather using a floody beam to see the entirety of a nearby object, instead of only a small spot on it. Indeed, I could see down a path with trees on either side for some considerable distance using the d4 219c turbo, although of course that’s not usable for a long time in warm weather. I only used it for ~30s or so. Still, the standardized throw of that would have been around 160m at the time (ga cells and a lee minus green filter). In the fw3a, the throw of a samsung comes up as about 155m assuming 2cd/lm and the xpl is 243m or so.
Personally I like the d4 219c and don’t particularly want something throwy, so if the fw3a was as similar to my d4 as it seems, I’d be very happy. The choice seems to come down to this: do you want your small, elegant light to produce a beam which is rather wide but is definitely soft and as aesthetically pleasing as befits the design, or do you want to tack on another few dollars to fit a CREE in order to chase cd, despite small multi emitter lights being entirely wrong for that?
No, multi-emitter lights are not wrong for throw.
Being right for throw, for me, is maximizing cd/volume and cd/weight.
Beam intensity is roughtly intensity of LED multipled by reflector area / active TIR area.
Multi-emitter lights add some dead area on the front of the light, so they need to have wider heads for the same effect.
OTOH they are shorter.
So of we compare 2 lights, one with 4 mm² emitter and another with four 1 mm² emitters and same reflector area, they’ll have similar intensity and similar output. The former will be longer, the latter thicker.
The latter will be lighter and have smaller volume.
Due to smaller size, it will cool worse for smaller sustained performance. It will have a weirder beam.
Overall….I think that both approaches make sense.
But I digress….
XP-G3: Strongest “Cree Rainbow” effect: angle-based tint shift, green around hotspot.
XP-G2: Lowest output. Old.
219c: Most heat, lowest sustainable output, highest chance of damaging itself on turbo.
LH351D: Super floody. May be a bit green at low levels.
As shown above, the only downside to the XPL HI is that it costs a tiny bit more.
It is equal to or better than the others in every other category… especially heat management. In a light this small, heat management is a big deal & should not be ignored.
As TK mentioned a few posts back…. there is much more to consider than CRI. Consistent beam is another consideration. The XPL HI is the best in that category also.
The XPL HI is by far the best ’all around’ choice for this light.
It is not just a matter of throw vs. flood. It is a matter of the best choice for ’all around’ use.
Nope. LH351D is more efficient and more powerful. Much more efficient. As long as you compare units with the same CRI which TK didn’t do.
As to heat management - this is a matter of opinion. Some want flashier with more output for shorter time, some want cooler that shine for longer.
There won’t be much difference though. Vf is pretty similar. 2 seconds?
Totally agree with you here. But the XP-G2 deserves some elderly respect :face_with_monocle:. Still love that emiter for the lower heat, consistent tint and great balanced beam.
Huh? Since when is the XP-L Hi considered to have a consistent beam in a Carclo optic? The beam is so ugly that Hank had to design a special rotated pads ledboard for it to make its pointy hotspot half acceptable.
The small Carclo triple and quad board give the smoothest beam with small die leds, the XP-E(2) looks wonderful through them, and XP-G size leds look very ok too. The XP-L(hi) has a too big die for this optic, it gets less efficient and the beam is ugly. Strange enough, the LH351D has an even bigger die but still looks good, but I doubt that the optic is very efficient with them.
The ONLY downside? A TINY bit? It's a solid 120% of the starting price; in fact it's more than the d4 now costs. It may be only $6, but it's still a big percentage. And what about color rendering? Not only does the XPL have a mere 70+ cri, the lh351d's test (https://budgetlightforum.com/t/-/49771/13) as having an even higher r9 value (79) than the regular 219c (rated at 50), to say nothing of the xpl which would be something like -28 (that's negative!). Maukka also says the lh351d would get about 2.25cd/lm in a triple clear tir, which means my previous comment was actually underestimating it. I should expect then more like 165m, or more than my personal copy of the d4 219c (would still be mildly less than other people's, but not unimpressive for 3 emitters vs 4).
The other thing is that these samsung ones would be very efficient indeed, and make little heat, because the Vf is higher and the flux is pretty comparable. That's with about 9% less lumens than xpl, but equal lumens to the xp-g3 we all know and despise. I believe they may even make less heat than the xpl's given the Vf and flux difference, but I haven't tested that. They have a VERY consistent beam according to the beamshots I've seen; please refer to maukka's tests for this as well. Inconsistent beams are mostly a cree thing :P.
These reasons are why once I took a closer look at the samsung's, I changed my preference from 219c. I don't know about you, but to me they seem like a much better all around choice. Sure, the xpl's will flood less, but then take a look at the same tests done with an xpl hi. https://budgetlightforum.com/t/-/47683
Tom E wrote this about his DQG TinyIII 26650:
“I’ve done some further run testing. Also modded mine with replacing the CW XP-G2’s with XP-G3 S5 5000K’s. I got a slight bump in output, possible slight drop in amps drawn (not sure of this). Actually the CW stock LED’s had a pretty decent tint - nice white, no blue at all. The XP-G3’s look really good in this light - no yellow, or any rings, etc. Tint is as good as the good XP-G2 CW stock LED’s. I’m happy with the upgrade, though no big impact.
• With the XP-G3 S5 5000k on a BASEN at 4.23V, got 6.1A tail (clamp meter):
turbo: 2,820 start, 2,680 30 secs, lo: 5.8 lumens, mid: 327 lumens, hi: 962 lumens
• CW Stock, on a BASEN at 4.20V, got 6.4A tail (clamp meter):
turbo: 2,650 start, 2,520 30 secs”
That sounds good to me. I personally want my EDC FW3A to have Throw & Flood.
