I’m also curious about these. Why this specific size? Does it fit in existing things or is this just a common size they had? Can a normal human use these or do I have to build this around precise measurements for it to be worth it?
Any lens flashlight that has an area around the LED that can fit 32mm.
Of course you can make your own host if you want too.
They mentioned that one of the issues with the previous collars was that to make the opening hole they sliced the top off the dome, which wasn’t ideal for concentricity.
Marinebeam isn’t the factory mass producing them so they don’t know how they changed the manufacturing process to fix that.
I assume other improvements like coating quality and stuff like that also apply, since they mentioned it is “a lot better”
I would suggest looking up some of the flashlight mods that use wavien collars on google.
This size is the same size as the old wavien collar ‘small’ version.
As long as you can fit it in the flashlight head you can simply use layers of tape to adjust the height, glue it in place, and then your aspheric thrower will have 2x the intensity.
You would get sued for one piece?It reminds me Shakespeare’s “Merchant of Venice”…
But who would learn that it was a replica?You could have bought it somehow.
Tell them that Notta’s offering 3 for $60 including shipping. (These are uber lightweight.)
This small size IMO warrants a better deal than 1 for $50. I’m messing around with head housings that are starting at 2 1/2 times this size.
What I don’t want to do is to get one set up right and then have to take it apart to the next experimentation.
Do they know how much hassle it can take to get focusing just right?
Who wants to mess with all that time wasted to set up the next one?
Point being this’ll cost me a lot more than $50 in my time to buy only one.
And I ain’t buying 3 @$50/each.
So if they’re looking at potential future business to accommodate those bigger head housings someday (and I bet others are thinking the same way) then they need to grease this first sled a bit better for me to want to ride the next one. If there is a next one. If there isn’t then I’m luke warmly interested in these dinky ones.
If I could somehow make them myself and just use them that would be fine.
If I sold them or sold flashlights that sued them that would be very illegal.
They already agreed with the patent holder that they could produce some but wanted to first know how many people would be interested in buying.
It takes me about 5 minutes to focus my wavien collar, done it plenty of times.
The marginal improvement from a larger size doesn’t matter that much, it’s only a few percent.
The main point of a larger size is if you have stuff around the LED that need clearance, like soldered wires, huge die size, etc.
btw $56 is about the same price the old wavien small collars used to be.
Google “DIY wavien collar” and there’s a thread on BLF about exactly that kind of stuff
There’s nothing that even comes close to a cold-mirror coated glass reflector though.
I would buy one, and probably also a quality 50mm lens, but I would have to know the focal length and if the lens has a small rim to clamp it behind a bezel (and if the 50mm is measured with or without the rim). And the price must be reasonable of course.
Possibly. I have not followed it well but has anyone measured the increase of throw of a dedomed SST-40 as opposed to one with dome on, and compared that to the throw increase of a XM-L2 ? Is it just as good? In other words: how good is the photon recycling effect in the SST-40? (the wavien collar uses the same effect).
Great Enderman, thanks for doing this! I want one, maybe two if the price goes down.
I have a few questions regarding lenses and the collar:
What f-number should a Lens have for optimal performance (meaning it collects all of the light and there is no wasted lens diameter)?
I want to put the smallest possible lens on top of a small sized collar. It should be possible to glue it directly on top if the diameter is just slightly larger or if the lens has a rim?
