If I get time I may do some beamshots with all 10507 optics. I do have a single 10508 and 10511 but i’m not sure I want to go swapping all the optics. I just so happen to have these in triples:
Jaxman E2L:
Nichia 219C D240 4000K 90CRI
LH351D 4000K 90CRI
Convoy S2+:
XP-L HI V2 5D 4000K 70CRI
Just from my own description though I feel like it needs to be emphasized that the LH351D has NO hotspot AT ALL. It could pass for a mule. I have reflector based lights with this LED in them that do show a hotspot but all of these TIRs totally smooth it out across the entire beam.
From the stuff I’ve seen about it, while it’s not got a defined spot, it’s also nowhere near the almost 180deg of a mule; it’s just got the even circle aspect. Would be neat to see, even if the drive current’s not the same.
You are right, the beam width is not the same but I more so meant the fact that it looks like a very “even” circle all the way to the edge. If it’s more intense in the middle you will not be able to notice.
It’s worth repeating that the poll is what we ask for, not necessarily what we’ll actually get.
For example, the current results show LH351D and 4500K in the lead, but the LH351D does not exist in 4500K. Neither does the 219c. Cree has a wide range of tint bins from 4000K to 5000K, but the Samsung and Nichia options are only 4000K or 5000K with nothing between.
So, to get 4500K, only Cree emitters work. Or to get LH351D, only 4000K or 5000K works (and it doesn’t appear that BLF has tested the 5000K 90CRI version yet).
In a few days I’ll probably make something to scatter-plot the data to check for emitter+tint correlations in case there are any useful patterns.
Hmm. I had forgotten about the limited tints available in the 219C (and I had no idea what tints are available for the LH351D). So I just answered them independently. Maybe there should only be one poll with the actual available options, because I care a bout getting a Nichia or a Samsung much more than I care about the difference between 4000K and 4500K (and I don’t really want any of the Crees).
Neither the 219C nor the LH351D come in 4500K. Both come in 4000K and 5000K.
I’d be pretty happy with 4000K, 5000K, Samsung or Nichia as long as it’s 90 CRI. If Cree made a 90 CRI, neutral white XP-L HI, I’d be happy with that too (I have a shaved 4500K 90 CRI XHP70 and it’s pretty nice).
Indeed, it is bizarre to have two polls simultaneously, one for CCT, the other for emitter choice/CRI.
Unless it is a student project to garner some theoretical data to be written up for finals.
Make it real, i.e. the actual possible choices. One poll.
Otherwise I will have to get my head around how to vote tactically for what I want (4000K Samsung, or Nichia, though I don’t really want a Nichia but it seems to have a cult following based on past history when that’s all that there was)
I think it’s more a known quantity thing. I can buy a Jaxman or Emisar with a 219C (and I have), so I know I like those. I’ve read reviews of the Samsung, and I would like to try one, but until and if the FW3A is available with a Samsung, I have to learn how and get the equipment to reflow emitters just to try one. That’s a big commitment for some of us. Well, I couldn’t find any MCPCBs with Samsungs already soldered last time I looked. That could have changed.
To be fair, that tree is only like 10 meters away. I find the floodier option not to be very useful outdoors, because the foreground is always so much brighter than the target. So I plan on having XP-L HI in mine, even if I have to swap the emitters. Maybe I’ll pay an extra $20 to get a MCPCB pre-made from Mtn, but I’d rather just pay an extra $6 and not have to solder anything.
Unfortunately, there aren’t many Condorcet voting services which can do more than one question in the same poll, and I haven’t found a survey site which has good voting systems. So it’s really awkward to gather two preferences at once.
It could be done by multiplying the options, but that would make an awfully long ballot with 30+ candidates for each person to rank.
