Itsme
(Itsme)
May 15, 2018, 6:21am
120
Specifications
Product name: Astrolux MF04 XHP35-HI Searching LED Flashlight
Brand: Astrolux
Model: MF04
Emitter Type: XHP35-HI
Peak Beam Intensity: 1460000 CD
Max Output: 2700 Lumens
Range: 2416 Meters
Mode: Moon, Medium, High, Turbo, Strobe, SOS, Beacon
Lumens: 15LM, 350LM,1700LM, 2700LM, 2700LM, 2700LM, / .
Runtime: 300H, 25H, 3.5H, 2.5H, / , / , / .
Battery Configurations: 2x 18650 or 4x 18650 Li-ion Battery (Not included)
( Sumsung 30Q 20A 18650 Power Battery Recommended)
Switch Type: Clicky
Switch Location: Side of the flashlight
Material: Aerospace grade aluminium alloy
Impact Resistant: 1 Meter
Waterproof: IPX-7 Waterproof
Lens: 3MM toughened ultra-clear glass lens with anti-reflective coating
Reflector: Large-diameter high reflectivity aluminum reflector
Carrying Strap: Strap
Color: Black
Weight: 1290g without battery
Size: 234mmx 136mmx 54mm (Heightx Head diameterx Body diameter)
2.4 KM? Thats pretty darn far!
Banggood
(Banggood)
May 15, 2018, 7:13am
121
Yes, ASTROLUX MF04 is a CREE XHP35 HI 2700lm 2.45km Searchlight, excellent light!
Itsme:
Specifications Product name: Astrolux MF04 XHP35-HI Searching LED Flashlight Brand: Astrolux Model: MF04 Emitter Type: XHP35-HI Peak Beam Intensity: 1460000 CD Max Output: 2700 Lumens Range: 2416 Meters Mode: Moon, Medium, High, Turbo, Strobe, SOS, Beacon Lumens: 15LM, 350LM,1700LM, 2700LM, 2700LM, 2700LM, / . Runtime: 300H, 25H, 3.5H, 2.5H, / , / , / . Battery Configurations: 2x 18650 or 4x 18650 Li-ion Battery (Not included) ( Sumsung 30Q 20A 18650 Power Battery Recommended) Switch Type: Clicky Switch Location: Side of the flashlight Material: Aerospace grade aluminium alloy Impact Resistant: 1 Meter Waterproof: IPX-7 Waterproof Lens: 3MM toughened ultra-clear glass lens with anti-reflective coating Reflector: Large-diameter high reflectivity aluminum reflector Carrying Strap: Strap Color: Black Weight: 1290g without battery Size: 234mmx 136mmx 54mm (Heightx Head diameterx Body diameter) 2.4 KM? Thats pretty darn far!
Banggood
(Banggood)
May 22, 2018, 9:00am
122
RaVeN
(RaVeN)
June 6, 2018, 11:07am
124
Hi Banggood,
That’s weird, you are advertising the new acebeam EC65 but it’s been saying “Coming soon” for a long time now.
Banggood
(Banggood)
July 5, 2018, 1:53am
127
Hello Everybody,
Astrolux MF04S XHP70.2 Floodlight Flooding Flashlight is coming soon
1. Compare with Astrolux MF04 about illumination:
1). MF04 utilize XHP35-HI LED without jelly to be a long-range concentrator
2). MF04S works with XHP70.2 LED but not a "HI" lamp bead, reach stronger flooding effect
3). MF04 mains long range with 2416 Meters 2700 Lumens
4). MF04S mains professional floodling effect with 1549 Meters high lumens up to 6000 Lumens!!
Is this Astrolux S43 a new model?
Sillen
(Sillen)
August 29, 2018, 4:25am
134
This is killing me. Buy S41 on flash sale and within days the S42 is same price and now S43 is out. What is the difference 42 to 43?
varbos
(varbos)
August 29, 2018, 8:07am
135
Most obvious difference is ramping UI.
I don’t know if it is “ramping” UI. Steppless dimming is not necessarily the same as “ramping”! The description seems to mix both things, so I don’t know exactly how it’s going to be!
But, besides what looks an improved UI, something on the look is also different
Banggood
(Banggood)
September 5, 2018, 1:44am
137
1. Special deals for 12th Anniversary Sale,
Astrolux S43,
only $29,
code:9f1297,
link:https://goo.gl/5FgssP
BlueSwordM
(BlueSwordM)
September 5, 2018, 1:56am
138
@Mascaratum , Texas Ace confirmed the S43 is using a NarsilM FET+1 driver with 0.5A micro-USB charger.
That means it’s now a lower power usb rechargeable worse looking Emisar D4.
Nicolicous
(Nicolicous)
September 5, 2018, 2:39am
139
.5A charging is slow for 18650 and less water proof.
Also it’s similar price to emisar D4 so D4 is a clear winner
My thoughts please don’t hate me
