I wonder if there is a alternative 16mm mcpcb that would host more than 3 Optisolii, clustered around the center point? Either 4x like those quadrix one for e21a, or 5x, cross type, or 6x = 2x3? The more the better, ideally I am dreaming of the LEDs populating the entire board and creating kind of light emitting honeycomb.
- Clemence
Thanks Clemence, I am aware of these. But they are 20mm sized so would not fit an aleph head which I prefer now. And the location of the pads is not ideal for a mule.
You can make your own using thin copper and JBweld.
I was thinking about something like this, but was unsure about the bond, so thanks much for suggesting JBweld. Do you know of any tutorial on this subject?
and btw, when do you expect the new arrival of optisolii?
At best, I can only complete the payment to Nichia in 180622 or 180625. It’s a long holiday here. The last time I was about to complete it, Nichia couldn’t process my order because the Optisolises were out of stock. Now when they’re back, there’s this holiday.
- Clemence
What specific type of JBweld woudl you suggest? They have loads of different bonding solutions.
The original JB Weld is the strongest and most heat resistant up to 315C
- Clemence
- Clemence
Thank you!
UPDATE 180706:
New variants, VR21SP4 (quadtrix E21A) and VR21P4 (quad Optisolis/757). Same board material and technology as previous one.
- Clemence
New Products:
VR21P4 (parallel only, 757/Optisolis only)
- The closest performance to DTP copper MCPCB.
- 1 Oz copper
- Diameter = 21mm
- Thickness = 1,5mm
- Compatible with Carclo 106xx
- Almost invisible (from afar and when lit) yellow marking for enhanced aesthetic
- Special solder footprint dimensions for precise LED positioning. Very easy to solder with DIY techniques. No more overflow solder - bumps which can impede optic placement.
NOTE:
Ignore those erroneous guide boxes, they won’t affect the board/soldering performance. The LEDs self align perfectly.
This board is sure overkill for 757 LED family, the board thermal resistance is much lower than the LED thermal resistance itself. But with some scrapings here and there this board can be used for other high power (2 pads) LEDs as well.
NF2L757GT-F1 sm273 P9 Rfh00
VR21SP4 (larger version of VR16SP4)
New features:
- 1 Oz. copper
- Tighter LEDs spacings at 0,3mm
- Smooth backside
- 2,5mm holes can be tapped for M3x0,5 screws for alternate mounting options with thin heat sink plate.
- Diameter = 21mm
- Thickness = 2mm
Still waiting for the optics for further tests….
- Clemence
A quick test with VR21SP4: good news, with proper optics it can be used as a thrower. Not as throwy but decent at 8 - 10 degree hot spot (estimated).
Tested with Armytek Viking OP reflector, 37mm, and 45mm colour mixing TIR optics. Will post the beamshots if I have the time between soldering the 219B GB orders.
- Clemence
I will put mine in the Convoy L6 (medium to large size OP reflector) and will report back how that works. Iight convert the light to use the new Gaggaione 67mm silicone TIR optics.
The optics used were 45mm Gaggione LLC49R and Yajiamei 37mm. The reflector was from newest Armytek Viking. All resulted in good beams, little to no artefacts.
E21A on VR21SP4 can’t be driven as hard as the VR16SP4 because of the smaller gaps. 2A/LED seems near the limit for R9080 and 2,5A/LED for R70.
- Clemence
Why did you make the gap smaller again?
Popular demand to make it easier with optics.
- Clemence
Finally had a little time for quick testing the VR21SP4 with some optics I laying around.
4x E21A sm403 D220 R9080
The contestant:
So, quadtrix E21A boards (VR16SP4 & VR21SP4) are not that hopeless for medium range thrower. To get rid off the center cross there are several options:
- Add diffuser or diffuse the optics used (including texturized the reflector when possible)
- Use colour mixing optics (OP reflector, special TIR with multi facet/pebbled surface)
- Alter the focal point to below the MCPCB surface.
Hope this helps
- Clemence
I am a bit surprized that you gave this higher priority than a regular quad, for quad carclo
Quad config is not as good as quadtrix config for colour mixing. I prepared all these boards for the CCT switching lights and for the upcoming colour E17A (I hope E21A as well).
- Clemence
Thanks Clemence!
That first pic looks so perfectly soldered and just clean! :+1:
