It also has to do with the size, larger packages tend to take longer. So an envelope is a bit easier to transport then a big hunk of PVC lol.
Also, I noticed in some pictures you posted that your sphere is still at a funny angle.
Were you not able to twist it any more? The PVC likes to get stuck, when this happens I wiggle it back and forth while pulling it out. The top piece has no glue so it should pop out.
Then line it up properly and press it back together firmly.
Got my correction disks today and installed the two disks per directions. Using my modified Convoy from PFlexPRO (sphere tested at 607 lumens), I get a reading much lower than I was expecting.
But here's where things get interesting. I reversed the correction disks in the direction they're not supposed to go (smooth side towards the sensor).
Now when I test the PFlexPro light, I'm only off by ONE LUMEN.
Again, with correction disks in wrong direction, here's the Nitecore TIP (rated at 150 lumens). And we get . . . 149 lumens. So, seems for my tube, reversed correction disks is what works.
Thanks for looking that up. Very strange, it seems to be giving a lower correction factor then it should but it seems to be inline with the numbers I got with the old sheets in that orientation (around .64)
It is unlikely but possible that he managed to get 2 of the first batch of discs that read a little lower. In which case he is correct, flipping them around is what is needed to get the correct readings.
Yep, that is the correct way to install them physically, although I can’t tell which orientation they are. Both of the smooth sides should face towards the inside of the sphere with the new discs (which I made 100 of). With the old discs they were the other direction but there were only about a dozen of them mixed in, so it is unlikely that most of you have those.
Yep, I sent 3 to everyone (and 4 to the international people) just in case 1 broke in shipment. Easier and cheaper to send a spare then ship another package. I had the buy the whole sheet of diffuser anyways.
this is what i’m experiencing with my kit.
With both smooth side facing the tube i’m getting a .64 correction. it seems a little low.
what seems to work for me is the smooth side touching, with that i’m getting a .675 correction.
Do you have the rough side of both disc facing the tube?
I did try it that way. I think the correction factor was around .74
The way I have mine setup is the rough side facing the tube and the sensor.
