They do look different from the ones I got from another AliExpress store, about half a year ago (“Liitokala official store”, the one that has ‘hongkong’ in the store URL)
For your 4-pronged 30Qs, are there markings or codes underneath the pink wrapper (they should still be vaguely visible)
(I have to use photo editing software to adjust the contrast since my budget camera had hard time to pick them up)
(this reads: L0H5 65V21)
(this reads: NMA6 W16)
I believe those markings underneath the pink wrapper are manufacture lot/date codes that should be on genuine Samsung cells.
(anyone knows how to decipher the date for those ‘underneath’ codes?)
Received mine today. 99% certain they are fakes due to the following:
Connected to 10 amp electronic load and could not even pull 850mA of current from the one cell I tried to test. I need to verify my setup tomorrow night. It's late and I have to crash.
There are clear signs that there were previous wrappers that had been stripped off the cans. Remnants of the old wrappers show through the existing shrink wrap.
The shrink wrap is slightly darker and thicker than my real 30Q's. I can not locate any signs of date stamp on the cans through the wrappers, but it's late. I'll check again tomorrow..
I can't see vents (or what appears to be vents) under the button like I can on my real 30Q's.
I have 4 of the cells discharge testing on a Lii-500 at 1 amp rate. I should have results in the morning.
EDIT: I retract the struck out parts above. More testing is required. Please see my post about 4 posts down.
Custom holder with short 18 gauge wires pressed firmly against the cell terminals, but I do need to make sure all my connections are in order. I think I see signs of corrosion on the wires. I'll report back tomorrow.
If anybody else can chime in and test the cells, then we can see what the cells really are:
- Real Samsung 30Qs(hopefully)
- 18650s with characteristics similar to 30Qs, but cheaper(LG HG2 is a bit cheaper usually then the 30Q for some reason on wholesale sites like Alibaba)
- Rebadged high drain lower capacity cell, like an HE4, or a Samsung 25R.
- Real 3000mAh cell, but with very high internal resistance, like a laptop cell
- Recycled cell and not tested for capacity
Ultrafire
BTW, I just received my 6 Samsung 30Qs from Sunway store.
I have to retract my earlier opinion. There is something wrong with my electronic load. It has served me faithfully until now. I'm getting the same odd results with my real 30Q's too. I played with connections and switched carriers and I still can only pull low amperage with even my trusted cells that once performed well in the load.
The raised areas that I thought were remnants of other wrappers turned out to be imperfections in the wrapper itself.
I stripped one wrapper and found no date stamp or any other markings on the can:
In your picture it looks like the top part of the can is different then the top part of the fake cell. I’m willing to bet they saw this thread and changed their picture.
I’ve gone through about 50 Samsung 30qs and I’ve never seen one that hasn’t had date codes on the can there should be 3 or 4 of them. Not a bare Can. They maybe trying to pass off mh1 Cells off. Would give the right capacity and be a 10 amp cell. Just a wild guess on that.
Doesn’t make sense why liito Kala would shoot themselves in the foot and ruin their reputation.
Unless your Lii-500 is not accurate at all (my Lii-500 measures about 2% low, for example), that's a fake cell.
Buying cells whose top is for whatever reason covered (protected cells or with charging ports) makes counterfeiting easier. Cell top shape is the single most differentiating/identificating factor, as when you buy known 3-lobe top cells and you receive cells with 4 or 5 lobes you can smell the presumed rip-off.
Gosh, it stinks for me to see people posting pictures of their received cells but not clearly showing cell tops.
I believe we should do something in this respect here (in the Commercial Seller's Spot), to check if at least some known AliExpress cell sellers have something to say. There's some sort of gang behind the Great Wall which is making money rewrapping cheaper and readily available cells as what they are not.
Note, these cells were discharged using the Lii-202 and then charged with an Xtar VC4. Did this with 4 of the cells, the first number is the voltage at the time of inserting them into the charger and the second number the mAh that the VC4 indicated when the cells finished charging.
Just read your posts. It appears you and I received the same type of cell. I have sent a message to the vendor telling him/her that my cells are not real 30Q's based on wrapper and lack of can stamps. I should have included the differences on the positive terminal. I'll report back if I receive a reply.
Sorry for my ignorance. What is this mh1 cell you mention?
I’ve messaged the seller yesterday. First asking “are these cells authentic?” And I got a reply of “I gave you a box.” Then I explained some of the discrepancies I noticed and their reply was “Dear buyers, our batteries are all very good, you will know if you use them.” :person_facepalming:
Probably time to open a dispute with AliExpress. Maybe/hopefully you’ll get a better answer.
I bet I get similar replies. I'll try to work it out with the seller for a bit anyway. Thanks for that info.
Thank you BSM. Interesting the mention of the impressive matching. I have to say the same. These cells have provided incredibly similar test results. Even their arriving voltages were the same. Seems like you all may be onto something. I wonder if the MH1 has can stamps. A quick google isn't answering that for me.
I don’t know how friendly aliexoress is to customers I think barkuti had hell getting his money back and not sure if he ever did.
But just maybe people will get a refund and get to keep the cells. If that’s the case then it’s free decent cells.
Liito Kala is probably betting most users won’t notice a difference they’ll just run a capacity test and that’s as far as it will go. If they got a handful of claims they could settle. But the hundreds of other orders would all be money in the bank. I use to respect them. From now on for my 26550s shockli and Evva from richard have my business
This was my first time ordering cells from AliExpress. I’m going back to LiIonWholesale and my trusted, local eBay seller. Never had any problems there.
I usually use imr and I have one eBay seller. I go to him first help support the small business. Imr really pissed me off when the new CEO took away our discount code. Plus I get real grade a cells from my other guy. IDK how he does it. But he gets brand new toolpacks and takes them apart. Grade a cells go to oem. What the public has access to is grade b cells. There’s nothing wrong with them buy any means. But when you have to give a 3 year warranty on your batteries and you purchase millions you get the best. Good rewraopers like Basen will show you the latest pallet of cells they got and what b grade it is whether it’s b1, b2 or b3.
I just got a couple months ago 8 brand new BLUE 25r still at their factory voltage. Still test above capacity. I’m sure they’ve sat around for a few years but I couldnt resist since they are gone forever now. Resistance is right and capacity is right. Goes to show me lithium cells at there factory state of charge. Can sit for years without damaging the cell. KY latest purchase was 30 vtc 5 cells from a oem skateboard battery some German company. Perfect cells in the 3s10p I took those apart myself
