Great to know!
I’d just find some teardown pictures from another site:
http://chargerlab.com/2018/03/16/dismantling-the-xiaomi-mi-6-usb-port-fast-charger/
http://wemedia.ifeng.com/59342258/wemedia.shtml
HKJ, can you give us a bottom line thumbs up/thumbs down on that Xiaomi charger?
From the sidebar on that review Angerdan suggested, some topical info:
http://chargerlab.com/2018/03/15/amazon-recalls-260k-power-banks-due-to-fire-hazard/
That is a thumbs up, but it has more ports than power.
I have just published the Xiaomi review: Test/review of Xiaomi Mi 60W Fast+QC+PD usb charger CDQ06ZM
Can you confirm the report from Chargerlab about having to plug, unplug, and plug in again to get the Apple charging protocols recognized?
How would a user be able to tell this recognition had happened correctly, without the “Power-Z” test device they used?
No, I did not notice any problem when testing, but i did not try with a IPad.
Was just browsing around in AliExpress and came across this:
https://www.aliexpress.com/item/info/32863092690.html
(not sure if something like this has been reviewed before)
it's labeled "smart USB charger" appears to convert DC12-36v into 4-ports USB voltage (supports QC2/3) and also displays the current being supplied (like a USB meter).
Product parameters:
Input voltage: DC 12-36V
Input interface: DC5.5*2.1 (notebook adapter can be directly inserted)
Output voltage and current:channel 1-3: QC2.0, fixed output 5V/1A-2.4A;
channel 4: QC3.0, automatic output 5V/3.4A, 9V2.3A, 12V/1.5A
Maximum current: 8.5A
Maximum power: 45W
Product Size: 77.5*54*28MM
Product weight: 92.5g
Package include: 1pcs QC 2.0 3.0 Smart Charger (Not include the power supply)
I will take a look at it, but the specifications looks phony: QC2: 5V only, QC3: 5V, 9V, 12V that standard usb and QC2
I like to put this USB meter in:
https://aliexpress.com/item/T50N-Dual-USB-Spannung-strom-Power-Kapazit-t-Meter-unterst-tzung-QC2-0-QC3-0-PD/32835723725.html
It has a silver case, unusual futuristic display font and a lot of connectivity.
Tomo E4 with more detailed LCD (temperature, voltage and current):
http://www.tomopowerbank.com/shop/epilot-e4/
Hi HKJ,
I’d like a slim, small capacity powerbank, around 3-4000 mAh or so. I’m considering building recycling a smartphone lipo, but I’m also having a look to ready options… these two for example could be interesting, in case you are interested in reviewing them:
Hmm, just my opinion, regarding the low-cost small-capacity powerbanks,
I think there are too many such kinds it may not be possible to do that much “stringent” testing on them — low-cost unbranded items tend to not have that much quality control and while one batch may perform better, the next batch may easily change… at least based on my experience of them. Just my 2 cents worth…
Actually, I have something that looks practically the same as your second link (the one here: https://www.gearbest.com/power-banks/pp_436972.html), someone passed it on to me (my relative got it as a “giveaway” souvenir from some club event).
Soshine E4 with more detailed LCD (temperature, voltage and current):
SHOP - TOMO
The seller do not ship to Denmark (Shipping would probably be way to expensive anyway) and I could not find it on Aliexpress or Abay
Hi HKJ,
They are marked as “discontinued” and “out of stock”
[quote=HKJ]
On eBay and from canadian seller it’s available:
https://www.ebay.com/itm/EPILOT-E4-Smart-Replaceable-Power-Bank-18650-Battery-Charger-with-LCD-Display/183290298848
https://www.esmokercanada.com/epilot-e4-diy-powerbank-18650-charger
I searched for “Tomo E4” and did not get any matches.
I have ordered it.
I like to suggest following devices for review:
T50N Dual USB Voltage, Current, Power Capacity Meter, Support QC2.0, QC3.0, PD Test
The Kotomi Premium USB Voltage Meter USB Table QC/PD Triggers PD Testing Meter Kotomi Pre
WEB-U3se USB Voltage Current Meter Capacity Apple Lightning Data Line Tester MFI Silver Box
WEB-UL001 Adjustable Constant Current Electronic Load Mobile Power Supply USB Aging Discharge Test Instrument Wire Tester
WEB-UCC001 Car Charger Charging More than Seven in One Head QC PD SCP Desktop Fast Charge IP6518
WEB-UPD003 Fast Charge IPhoneX 13 to 1 Charge QC DC to PD VOOC SCP FCP AFC Head
QC2.0 QC3.0 test board, Qualcomm fast charge head, mobile power detection, hand automatic switching
USB QC2.0 QC3.0 test board burn-in board trap tester protocol board polling device
PD Type-c USB Test Board Burn-in Board Trap Tester Protocol Board Polling Device
USB PD voltage trigger and tester, mutation device
USB PD decoy type-C PD test board adapter voltage polling protocol fixture
DC-DC Power Supply Buck Module 8V-35VTo 5V 8A 4-port USB Car Power Charging Converter Support Android/iPhone Phone Fast Charging
POWER-Z Bit Dog CNC aluminum alloy OLED, QC3.0, FCP, MTK double USB charger, car charger
Good list, I will definitely get some of the stuff on it. I have not decided how much yet.
angerdan:Soshine E4 with more detailed LCD (temperature, voltage and current):
http://www.tomopowerbank.com/shop/epilot-e4/The seller do not ship to Denmark (Shipping would probably be way to expensive anyway) and I could not find it on Aliexpress or Abay
The Tomo Epilot E4 is available from Gearbest (black is a few cents cheaper than white); maybe there’s a generic coupon code somewhere to bring down the price…
https://www.gearbest.com/chargers/pp_1319856.html
I saw a cheaper price for the Epilot E4, but I’m not familiar with the following online store, and whether they ship or not…
While searching for the Tomo powerbanks, I came across other models too:
Tomo D2 (2x 26650) powerbank/charger:
https://www.gearbest.com/chargers/pp_1524290.html
(specs list the input current @ 1A ; it will take a long time to fully charge 2x 5000+ mAh 26650 with this powerbank…)
Tomo K2 powerbank/charger/flashlight (2x18650):
https://www.gearbest.com/chargers/pp_009791773690.html
I like to suggest these USB power supplies:
https://www.navilock.de/produkte/1407_AC/62516/merkmale.html
https://www.google.com/shopping/product/5248245363798167092?prds=scoring:tps
https://www.reichelt.de/Ladegeraete-fuer-USB-Geraete/USB-AC-NL-USB2/3/index.html?ACTION=3&GROUPID=4924&ARTICLE=143238&START=0&OFFSET=100&
