I’m still thinking this light could benefit from spring bypasses.
I’m not an experienced tester and I’ve only ever tested one light that had a boost driver. I did however notice that as I was using a heavy wire across the tail cap and a clamp meter to measure the amp draw on turbo that it extended the turbo run time.
I further could watch the amp draw decrease as I compressed the driver spring.
Also, what battery do you think is best for this light.
The Acebeam doesn’t give much full power turbo runtime, but does give extra run time at lower levels.
The 30T gives a lot of full power turbo run time, but it’s 3,000mah capacity runs out pretty quick.
Maybe the Lishen/Liitokala 4000mah is a good compromise?
Also, that 20A protection circuit is the biggest I’ve heard of. To answer Noirs question, that’s probably why they set that 3.5v turbo stepdown limit. If they tried to set it to a lower voltage it would probably try to draw well over 20 amps from the battery and maybe burn up the driver in the process.
I think it should. When the driver pulls a heavy load from the battery, the voltage sags down. The more resistance, the lower the voltage. All of this extra resistance causes the driver to work harder.
As you can see with the 30T battery, when placed under a heavy load (15A) this battery can maintain a higher voltage level.
A lot of lesser load (10A) boost driver lights use double springs to reduce electrical resistance and keep the voltage high.
Since a boost driver is trying to put out a constant wattage, Ohms law states V x C = W. This is voltage times current (amperage) = wattage. So as a batteries voltage runs down, the current draw will go up (but only so far).
I suspect if the springs were bypassed, reducing resistance, then voltage going to the driver would be higher and it would run turbo for longer times.
Look at what the extra resistance of the 18650 adapter did to the performance. It hurt it a lot. Therefore, my theory is bypassing the springs would definitely help improve performance.
I’m surprised Acebeam did not improve the springs. This seems like an error on their part.
I think we’re on the same page here Jason, but I have the tendency to express a bit differently. I’d say with both spring stock and bypassed, the driver works equally hard. But with a spring bypass you have a tad more voltage available for the driver, resulting in more turbo (max output with intermittent cooling) sequences with depleting cell voltage before reducing in output.
Maybe I should change “harder” to “less efficiently”.
This is actually something I’d like to explore in more detail. If a boost driver produces the same output at 3.5v and at 4v, is it working more efficiently or harder?
When I tested the Lumintop ODF30 I tested Turbo at three different battery voltage levels (Liitokala 5000mah 26650 black).
4.2v = 8.35A
4.0v = 9A
3.6v = 10A for one second then drop down to next level.
When testing a protected KeepPower 5200mah at 4.2v it drew 10.6A for a second then dropped down to next level.
I found all this pretty interesting, but I’d still like to learn a bit more in depth as to what’s going on especially in relation to heat build up.
I think it’s important to understand what is going on. With a lower input voltage you need more current for the same output. More current means more heat for the same output, therefore lower efficiency. But the intrinsic efficiency of the driver could be just a tad higher or lower at that current level, so you need to superimpose the efficiencies to get the total efficiency.
To state that the driver is working harder or less efficiently is merely a definition issue I think. And since there probably is not a well defined definition, miscommunication can occur easily.
For those curious about how the different batteries can have different amounts of voltage sag, here is a comparison of the Samsung 30T to the Samsung 48G (I’m not sure what 5100mah cell Acebeam is using, but it seems similar to the 48G)
You can immediately see why the “high drain” 30T allows for more turbo run time due to its minimal voltage sag compared to a “high capacity” type battery.
It is sadly very difficult to make beamshots during the summer here. There’s only a couple hours of darkness during the night. The need for flashlights severely decreases for a while
I'm a little late to the the party, but this review is so good, I had to give you a shout out. Thanks, maukka. Love all the technical data, especially runtime charts and color rendition info.
I am impressed by the flat output levels once this flashlight steps down to about 800 lumens. Predictable, flat output is the main reason I prefer boost (and boost/buck) drivers over linear and buck.
