lol…it sure seems to be in this madness of a hobby.
Another use even if it sounds out there: at only 100 watts a pop and used in conjunction with a battery plus repeating/fast acting timer and motion sensor plus trail camera or hard wired security system… why couldn’t these provide what you needed in a very small/portable package to ‘stun’ for that initial all important photo?
You wouldn’t have anybody’s eyes open initially yet this much light will certainly stop someone in their tracks where they shouldn’t be for whatever purpose you are trying to serve. If they destroy it in anger? You’re out an old garage sale motion light fixture and $26 (camera and even possibly power source mounted discreetly elsewhere).
I wish that I could offer more ‘long term’ info beyond an observation that the original Morris light seems to be still working fine. With my finger finally free from a splint I expect my wife to cancel the cable TV soon motivating me to hoist up that 28’x4”x6” laminated pole with a TV antenna and the previously outlined Westgate product attached.
Some of the accessories that i have purchased for that light have been continually backordered so I would keep my experience in mind if this much more configurable Westgate model is your cup of tea.
Advice for these flat/finned lights: Attach whatever is needed to discourage birds from using those nice nest holding cooling fins as the foundation for their new homes. If anybody has an idea that will look halfway decent (it would be nice to top the light with copper or something that didn’t look jury rigged) I’m all ears.
My 2nd package containing the light above arrived today. For some reason, I was hoping that 11,000 lumens of lower CRI/warmer tint for $26 delivered would be a bit more attractive to a few more light junkies out there than just myself. I’ll epoxy them both to one of my old RAB motion lights (great long range sensors) pointed in opposing directions and see what happens….
Can you check how much power it’s using. I found my “300 watt” flood light actually only used half that much. The emitters were rated for 300 watts, but the power supplies couldn’t drive them fully.
The $26 light ended up approx. 14’ up and attached to the middle of a 26’x40’ room. Not much spill in to the corners yet a nice tint and overall compliment to the pretty much useless 4’ fluorescent tubes that will burn around it until they die. I’m happy with the purchase so far as it’s nice to have your main work area spotlighted (well) in a comfortable glow.
Just ordered (4) more when the last of my garage fluorescents died after accidentally leaving the lights on. The 100 watt versions seem to be the best value so I didn’t go with any of the higher lumen versions. Ceilings are only 10 feet high so it will be interesting to see how they cover; especially the light covering my work bench. Hoping to cover a 24’x32’ area w/two lights plus the bench light while saving the last light for a portable (area) work light utilizing the trunion mount paired with some other attachment device.
Just chiming in to say I’m still following along to see how those $26 Amazon lights fair. Do they seem to handle the heat okay? Are they properly grounded inside? The “100 watt” version - how much is this? Equivalent to an old 500 watt halogen floodlight (the thin long tube ones)?
I have only run them for short periods of time in not very hot climates and have not taken them apart/probably won’t. The 500 watt halogen is probably a good approximation yet probably with less side spill and looking far less intense up close (I chose the 3000K versus whatever a halogen is). The 18,000 lumen that I have from Morris puts that category of halogens to shame yet it’s hard (imo) to beat a 500 watt halogen (period) up close or in a pretty wide pattern.
I remember picking those lights up for $6 in their hayday so $26 for this on a lark with no research to rely on is a lot of money. I’m just hoping that they pay off versus the $100+ that we’re (seemingly) paying for 100 watt (non-corncob) 3000K lights now. Keep in mind that I’m still willing (at this time) to pay approx. $200 for a properly heats sinked 150 watt light sporting a dimmer with nobody else jumping in here concerning either version in any Kelvin rating.
What about a version with a dusk to dawn sensor? I don’t see one (i.e. this same thin 100w model). Also - how cold is the cool white and how warm is the warm white? I’m wondering which one to go with - guessing the cool white.
I would message them on Amazon and report back with their answer. I have no idea what the cool version looks like and have only reported (not very descriptively) on the warmer ones. Very hard for me to describe light when it’s flooded over a large area yet I have always preferred anything but cool to actually work around for any extended amount of time. Security ‘in your face’ lighting? Cool is best imo.
I hope that these answers from the seller (use the order of the links above for reference) are of help to someone else taking the gamble here:
Question 1: The first light (ASIN:B078HGRBH6) is cold white.
The motion sensor is similar, they are up to 50ft / 15meter. But the second light have stronger waterproof than the first light, the second light (ASIN:B078H6WPPK) is IP67 waterproof.
Question 2: Yes, it is the same version with the four lights you ordered, just with no motion sensor.
The difference between these two lights is mainly the difference in appearance.The second lamp has better heat dissipation than the first one, and uses lamp beads
with better heat dissipation.The second lamp is lighter and thinner than the first lamp.
In terms of motion sensors, the difference between the two is small.
I am waiting for them to respond to my request for a swap of the (4) lights just purchased for (5) of the same lights with motion sensors for less money. I will send them a link to this post and let’s see what they say…(the last package came out of Jersey).
