My kind of reasoning. :sunglasses:
So I ordered two of those with your link. Thanks for the info petemer! :+1:
XTAR VC4 LCD Screen USB Battery Charger For 18650 26650 14500 Battery
It’s now in flash sale for $17.99 (53% OFF).
Charges both Li-Ion and Ni-Mh chemistry.
Offer is valid for 3 days and 16 hours.
That Blitzwolf coupon used on your link only drops the price to $20.39 ($13.60 discount from $33.99)
The price I posted ($17.99) applies to CN warehouse.
Coupon code with very nice discount is available.
» Request via PM here«
- Cree XP-G3 Neutral White
- dual lightning zones (multi faceted reflector)
- USB rechargeable
- built in 1400mAh battery
- 3 constant modes + 3 hidden blinkies (press for 4sec to access)
- max 400lm
- LED power indicator (under button)
- German standards compliant (ensures no dazzling of incoming traffic)
Use coupon code BWL3X to get 30% discount (-$22.80 and final price $53.19 at the moment).
This is the most powerful solar charger in Blitzwolf range. It’s capable of delivering up to 3.8A of current (it full sun) which is enough to charge at full speed high power devices (high-end smartphones or tablets). Even smaller Blitzwolf panels can charge smartphones in cloudy day so this should easily power more demanding tablets. Solar cells from SunPower provide unsurpassed conversion efficiency over 23.5%
Blitzwolf chargers offer best value/cost ratio on the market and quality is very good.
At the moment the most cost effective version is 2A BW-L2 15W for $17.99 - see here: 15W version deal
28W version is the most recent so more reviews can be seen on BlitzWolf® 15W 2A BW-L2 and BlitzWolf® 20W 3A BW-L1 versions.
Use coupon code 9a8078 to get $12.00 discount (price drops from $59.99 to $47.99)
Original R-JUST 10W Portable Wireless Charger Fast Charging Pad For iphone X 8/8Plus Samsung S9 S8
It’s now in preorder for $13.99 (30% OFF) for first 100pcs, then the price will gradually go up to $19.99.
Four color options available. Ultrathin - only 4.66 mm (0.18 in)
Stock is due to arrive within a week (30th of June).
BlitzWolf® BW-FWC3 5W Wireless Charger Charging Pad for iPhone X 8 Plus S8 Note 8 S9
It’s now in promo sale until 30th of June for $12.99 ($22.99 / 44% OFF)
It’s now in promo sale until 26th of June for $9.99 ($24.99 / 60% OFF)
Baseus 10W Visible Qi Wireless Fast QC3.0 Charger Pad for iPhone X S9 S8 Note 8 Plus
It’s now in flash sale for $12.99 ($24.99 / 48% OFF)
Offer expires in 2 days and 9 hours.
This one is especially interesting from aesthetic point of view, because beside standard white and black versions there’s also one with transparent glass and visible components. Only 5 mm (0.19 in) thick.
Sup pete, I just ordered the Blitzwolf wireless charger with your link. It’s only 5W, but I prefer slow charging for my S7 Edge to be as gentle as possible for my non replaceable battery.
I’m recently also getting a lot of Blitzwolf products, so this one is for the collection as well.
Using above link price drops to $15.99 ($23.99 / –30% OFF)
Limited time offer.
Use coupon code d50d12 to get 21% discount
- Cree XP-G2 S3 + High CRI LED + RED LED
- very compact design
- max 360lm
- min 1lm
- micro USB rechargeable
- built in li-po battery
- dual switch
- only 28g (0.99 oz)
Nitecore HA40 XM-L2 U2 1000Lumens AA Battery-Based Die-cast Unibody LED Headlamp
Use coupon code 5438c2 to get 21% discount
Astrolux A01 Nichia 219B 102LM AAA Mini Waterproof Keychain EDC LED Flashlight
It’s now in flash sale for $7.88 price.
Offer ends on 30th of June.
Nitecore HC65 XM-L2 U2 1000lumens Triple Output USB Rechargeable LED Headlamp +18650
Use coupon code e99099 to get $21 discount (price drops from $74.95 to $53.95)
- max: 1000lm (main LED)
- min: 1lm moonlight
- additional flood 26lm high CRI COB LED
- auxiliary 11lm red LED
- 3400 mAh 18650 cell included
- USB rechargeable
- max runtime: 800h
- constant current driver (no PWM)
- 5 constant main LED modes + 2 auxiliary modes + 4 special (3 white and one red blinkies)
- built in LED power indicator (shows voltage accurate to 0.1V)
- full metal construction (alu with HAIII finish)
On The Road U16 XP-L V6 1A 1020LM USB Rechargeable Mini EDC LED Flashlight
Use coupon code HU16 to get $26.99 price ($32.95, -$5.96 )
Use coupon code BRANDMGSH to get 18% discount for any light form Magicshine brand.
” 2pcs Keeppower P1835C2 IMR18350 1200mAh 3.7V 10A Rechargeable 18350 Li-ion Battery With Box “:2Stücker Keeppower P1835C2 IMR18350 1200mAh 3.7V 10A Wiederaufladbare 18350 Li- Sale - Banggood Deutschland-arrival notice-arrival notice
Use coupon code 1313CE to get $10.19 price (15% OFF)
